Hello all!
Some really weird happened when trying to install Garuda Gnome using the latest ISO as of now (garuda-gnome-linux-zen-230501.iso) and I would like to share the experience and ask if anyone knows what exactly happened and maybe how to fix it.
I have a small convertible (Atomx5, 4GB RAM,128GB eMMC) that had Win10 and some other distro installed, and using rEFInd as boot manager. Everything was fine, I booted the Garuda ISO a few times to test how it would run on the device, no problems. I was planning to replace the Linux distro with another one.
But then I tried to install an Ubuntu based distro, and it was not able to finish the installation when it tried to install the bootloader. I then decided to try installing Garuda Gnome (garuda-gnome-linux-zen-230501.iso) but it would just hang after choosing the USB device to boot.
I thought maybe the ISO was corrupted, checked the SHA256 sum, burned the ISO again, same thing. Tried to boot from Ventoy, same problem. All other distros, including Ventoy, display the GRUB right away, just not Garuda. I even re-formatted the partitions meant for Linux, removed all other EFI boot entries besides Win10, same problem... I also went to the BIOS, loaded the default settings, no deal.
Then I gave up and let the computer showing the black screen and went to search for info online, and after some minutes the Garuda GRUB menu was displayed! So something is making GRUB hang for a very long time, and only on this computer (I tested the same USB stick with another computer and it was fine).
Everything else in the computer is fine, I installed Ubuntu fine, Windows boots fine, no errors, it is just this version of GRUB in this image that has this issue. If I wait long enough I can then boot the Live ISO fine too.
Anyone else experienced something similar? Any ideas how to troubleshoot/fix this?
Regards
