Sup guys! Can u help me? Got picture but no sound
Sup! I really appreciate your efforts ! Wanna say something like “thanks” cuz u makes awesome O.P.
Sorry for my language problems. Can u help me a little bit?
May be i did misstake when i wrote here but i don’t wanna use some transates.
So I set this awesome garuda on my old notebook ‘n’ Im tryin connect this trash to TV by VGA ‘n’ 3.5 mm headphones cable. So I got picture but no sound. Do u have opportunity to help me? Do i need download something else or Im just stupid?
Thanks guys! Wish u be happy
Type garuda-inxi in terminal and post the entire output in this icon:
Screenshot_20231203_234019
It contains all the information with which people can help you :smiley:
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=997e41e0-a551-43cb-8925-7a8eede020a6 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Laptop System: HP product: HP ProBook 650 G2 v: N/A
Mobo: HP model: 80FD v: KBC Version 22.74 serial: <superuser required>
UEFI: HP v: N76 Ver. 01.57 date: 07/28/2022
ID-1: BAT0 charge: 18.1 Wh (56.4%) condition: 32.1/48.0 Wh (66.8%)
volts: 11.1 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 330
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1368 high: 2383 min/max: 400/2800 scaling:
driver: intel_pstate governor: performance cores: 1: 2291 2: 400 3: 2383
4: 400 bogomips: 19200
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: Lite-On HP HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 04ca:7054
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c3 built: 2014 res: 1920x1080
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.46 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 9 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:1916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1570 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 19 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 186.74 GiB (78.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: L8H-256V2G-HP
tech: SSD serial: <filter> fw-rev: 2803 scheme: GPT
used: 186.74 GiB (78.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.64 GiB used: 1.03 GiB (13.4%)
System Temperatures: cpu: 36.0 C pch: 31.0 C mobo: N/A
Processes: 199 Uptime: 6d 18h 27m wakeups: 18 Memory: total: 8 GiB
available: 7.64 GiB used: 3.46 GiB (45.3%) Init: systemd v: 255
pm: pacman pkgs: 1972 libs: 553 tools: octopi,paru Shell: fish v: 3.7.0
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.31
Garuda (2.6.23-1):
System install date:     2023-02-12
Last full system update: 2024-02-15 ↻
Failed units:            archlinux-keyring-wkd-sync.service
thanks m8 that u waste ur time! If u wanna know something else i can make some screenshots
Thanks that u trying to help!
I really appreciate that!
When i connect headphones (by for example bluetooth or 3.5mm cable) to notebook ‘n’ VGA to TV - there is no problem! I can hear da sound in headphones. I can see da picture on TV! Sound is awesome ‘n’ i got big picture! No delay! But when i connect notebook to Tv with 3.5 mm headphones cabel ‘n’ VGA at da same time to TV -no sound. I know that my this notebook is f***** old! Can u tell me this pc i must drop it to trashbox or i can do something with this?
Try with lts kernel and see if issue persists?
then while booting from grub screen goto advanced options → select linux-lts
IF this works make linux-lts the default kernel you boot with using garuda boot options GUI.
If this doesn’t help try downloading
sudo pacman -S alsa-utils
and check using
alsamixer
that all output sounds are maxed when you are facing the audio issue and that nothing is mute.
Also make sure that correct sound card is selected while this issue is happening,
useless! maybe my Tv holes is broken.
Gimme one day i want to test tv… I need some tools…
I did all things u said. No sound only picture. But when i connect headphones to notebook i got picture on TV ‘n’ sound in headphone!
Thanks 4 ur desire 2 help.
And please, stop writing slang, many of our users need a translation app (like me), plus you can edit your post until someone replies.
It’s unnecessary and just bloats the topic.
Thank you :slight_smile: and
garuda welcome 2
WTH is ‘n’?
Sorry! Im newbie on any forum. If you can not understand me thats my problem. Thats cool that you are trying to understand my slang! Can i apologise for my bad language skills. I’am trying to find some help. I don’t want to disturb you by my stupid questions. I really need some help so if you can help that’s awesome! If you not i just wanted give to you my regrets that you wasting your time.
Do not be upset! Wish you always be cool! Because this is awesome O.P. And people in this forum awesome too! May be my languge skills not so good but i think you can understand what i thinking about! X)
Thanks that you reading this sh”t!
The ‘swoosh’ indicates you need to reboot. Do so, then fix your failed units.
