Testing the speed of the connection to the available mirrors is the part of running Rate Mirrors that takes the longest amount of time. That is to say, running a connection speed test to determine if you need to run Rate Mirrors (which also runs a connection speed test) is unlikely to speed up the process in an appreciable way.
That said, there really is no reason to resort the mirrors unless you are having issues with the list you are using (it’s too slow, or has bad mirrors, etc). If your mirrors are working fine, you can just skip the Rate Mirrors piece.
Garuda Update | Garuda Linux wiki
Usage
Simply use garuda-update
or update
in your shell of choice. Both commands do the same thing. Additionally, the following parameters are available:
Parameter |
Environment variable |
Description |
–skip-mirrorlist |
SKIP_MIRRORLIST=1 |
Don’t update the mirrorlist before applying the system update. |
Skip resorting the mirrors when updating by running garuda-update --skip-mirrorlist
, or skip resorting the mirrors “permanently” by setting SKIP_MIRRORLIST=1
in /etc/garuda/garuda-update/config
I’m not sure there is a way to “pause” an update if the connection is dropping, but Pacman does typically leave behind downloaded or partially downloaded files if a download fails. When you re-run the update, it will attempt to continue downloading the remaining files.
You can also run an update with the --disable-download-timeout
option as described here: https://wiki.archlinux.org/title/Pacman/Tips_and_tricks#Installing_packages_on_bad_connection
Installing packages on bad connection
When trying to install a package from a bad connection (e.g. a train using a cell phone), use the --disable-download-timeout
option to lessen the chance of receiving errors such as:
error: failed retrieving file […] Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
or
error: failed retrieving file […] Operation timed out after 10014 milliseconds with 0 out of 0 bytes received
That may help prevent the update from failing if you have a spotty connection.
garuda-update --skip-mirrorlist -- --disable-download-timeout
