I was doing a routine update, and suddenly see many packages marked 'orphaned'. I've seen something similar happen when my local repo distrusts packages in routine due to maintainer change. Generally this is easy enough to handle en masse with aurto add $(pacman -Qqm) however this time is different... The packages marked orphaned here are NOT ones that I've added to a local repo, they're from Chaotic-AUR!
Upon reinstallation they are still marked orphans; why would this happen?
[tech@mango ~]$ pacman -Ss brave-bin
chaotic-aur/brave-bin 1:1.42.88-1 [installed]
Web browser that blocks ads and trackers by default (binary release)
[tech@mango ~]$ sudo pacman -Syu brave-bin
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
aurto is up to date
chaotic-aur is up to date
warning: brave-bin-1:1.42.88-1 is up to date -- reinstalling
warning: reflector-simple: local (3.2-1) is newer than garuda (2.0-1)
resolving dependencies...
Package (1) Old Version New Version Net Change
chaotic-aur/brave-bin 1:1.42.88-1 1:1.42.88-1 0.00 MiB
Total Installed Size: 301.03 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [--------------------------------------------------------] 100%
(1/1) checking package integrity [--------------------------------------------------------] 100%
(1/1) loading package files [--------------------------------------------------------] 100%
(1/1) checking for file conflicts [--------------------------------------------------------] 100%
(1/1) checking available disk space [--------------------------------------------------------] 100%
(1/2) Checking Arch News with Informant ...
There are no unread news items
==> root: 13686
(1/1) reinstalling brave-bin [--------------------------------------------------------] 100%
( 1/10) Arming ConditionNeedsUpdate...
( 2/10) Refreshing PackageKit...
( 3/10) Foreign/AUR package notification
gmail-desktop-dev 3.0.0_alpha.34-1
( 4/10) Updating icon theme caches...
( 5/10) Orphaned package notification...
appimagelauncher 2.2.0-6
corectrl 1.2.7-1
cpupower 5.19-1
croc-git 9.6.0.r6.g1517767-1
dxvk-mingw-git 1.10.1.r573.gde8d2b37-1
freecad 0.20.1-2
fuse-overlayfs 1.9-1
garuda-settings-manager-kcm-git 1.0.1.r2.ga885a4b-1
goverlay-git 0.9.r12.g1ab728d-1
grype-bin 0.46.0-1
gtest 1.12.1-1
gtkhash 1.4-5
gtkmm-4.0 4.6.1-1
gtksourceview5 5.4.2-1
imhex 1.20.0-2
js78 78.15.0-4
kotatogram-desktop-beta-dynamic-bin 1.4.9-4
latte-dock-git 0.10.6.r274.ga9d86870-1
lib32-libgudev 237-2
lib32-speex 1.2.1-1
libofa 0.9.3-9
linux-lts 5.15.60-1
lutris-git 0.5.11.beta1.r17.ged2f14e9-1
neard 0.18-1
nicotine-plus-git 3.3.0.dev2.r7860.d6a726e6-1
nm-connection-editor 1.28.0-1
ntp 4.2.8.p15-1
olive-git continuous.r2165.g402c4e169-1
python-contextlib2 21.6.0-1
python-progress 1.6-5
python-retrying 1.3.3-13
python-toml 0.10.2-7
python-zipfile-deflate64 0.2.0-1
ttf-nerd-fonts-hack-complete-git 20220813-1
turbostat 5.19-1
ulauncher 5.14.7-2
unvanquished 0.53.1-2
ytfzf-git r1662.67e7cad-1
( 6/10) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/bluetooth/main.conf.pacnew
/etc/locale.gen.pacnew
/etc/default/grub.pacnew
/etc/default/grub-btrfs/config.pacnew
/etc/nohang/nohang-desktop.conf.pacsave
/etc/sudoers.pacnew
/etc/systemd/system.conf.pacnew
Please check and merge
( 7/10) Checking which packages need to be rebuilt
( 8/10) Updating the desktop file MIME type cache...
( 9/10) Performing snapper post snapshots for the following configurations...
==> root: 13687
(10/10) Syncing all file systems...
[tech@mango ~]$ pacman -Qi brave-bin
Version : 1:1.42.88-1
Description : Web browser that blocks ads and trackers by default
(binary release)
Architecture : x86_64
URL : https://brave.com
Licenses : MPL2 BSD custom:chromium
Groups : None
Provides : brave=1.42.88 brave-browser
Depends On : alsa-lib gtk3 libxss nss ttf-font
Optional Deps : cups: Printer support [installed]
libgnome-keyring: Enable GNOME keyring support
[installed]
libnotify: Native notification support [installed]
Required By : None
Optional For : None
Conflicts With : brave
Replaces : None
Installed Size : 301.03 MiB
Packager : Nico Jensch <dr460nf1r3@chaotic.cx>
Build Date : Sun 07 Aug 2022 03:01:02 AM EDT
Install Date : Sat 13 Aug 2022 11:32:08 AM EDT
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
garuda-inxi:
[tech@mango ~]$ garuda-inxi
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=1748cca7-e422-4ed9-bd5c-3d12856f8671 rw rootflags=subvol=@
resume=UUID=dbb7a323-f52a-40d2-8ad1-ca512a750c83 loglevel=3
sysrq_always_enabled=1
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.30 date: 04/14/2021
Info: model: AMD Ryzen 9 3900XT bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3999 high: 4335 min/max: 2200/4776 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4250 2: 4153
3: 4312 4: 4143 5: 4335 6: 4259 7: 4011 8: 3901 9: 3722 10: 3840 11: 4253
12: 4086 13: 3754 14: 3695 15: 4234 16: 4112 17: 4157 18: 4030 19: 3872
20: 4033 21: 3596 22: 3600 23: 3671 24: 3960 bogomips: 182407
protection
always-on, RSB filling
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1, DP-2, DP-3, HDMI-A-1 empty: none
bus-ID: 0f:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 046d:085c
alternate: fbdev,vesa gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 7680x1971 s-dpi: 96 s-size: 2026x520mm (79.76x20.47")
s-diag: 2092mm (82.35")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: 2-1 model: Acer G246HL
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-2: DP-2 mapped: DisplayPort-1 pos: primary,1-2 model: LG
(GoldStar) QHD serial: <filter> built: 2021 res: 2560x1440 hz: 144
dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
Monitor-3: DP-3 mapped: DisplayPort-2 pos: 3-4 model: Samsung SyncMaster
serial: <filter> built: 2006 res: 1280x1024 hz: 60 dpi: 86 gamma: 1.2
size: 376x301mm (14.8x11.85") diag: 482mm (19") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
Monitor-4: HDMI-A-1 mapped: HDMI-A-0 pos: 4-3 model: LCD TV built: 2011
res: 1920x1080 hz: 60 dpi: 3048 gamma: 1.2 size: 16x9mm (0.63x0.35")
diag: 6mm (0.2") ratio: 15:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 14.0.6 DRM
3.46 5.18.16-zen1-1-zen) v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 3-5:4 pcie: chip-ID: 0d8c:013a gen: 4 speed: 16 GT/s class-ID: 0300
lanes: 16 bus-ID: 0f:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 11:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media USB PnP Sound Device type: USB
Device-4: Logitech C922 Pro Stream Webcam type: USB
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
bus-ID: 3-2:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 2.27 TiB used: 1.6 TiB (70.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 500GB
type: SSD serial: <filter> rev: DB6Q scheme: GPT
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.6 TiB (91.5%)
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.6 TiB
(91.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.6 TiB
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.6 TiB
ID-1: swap-1 type: zram size: 62.73 GiB used: 7.53 GiB (12.0%)
ID-2: swap-2 type: partition size: 69.07 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 39.5 C mobo: 39.0 C gpu: amdgpu temp: 58.0 C
mem: 56.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1056 fan-3: 0 fan-4: 1491 fan-5: 1171
fan-6: 2272 fan-7: 0 gpu: amdgpu fan: 0
Processes: 598 Uptime: 1d 11h 45m wakeups: 0 Memory: 62.73 GiB used: 15.24
GiB (24.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 2917 lib: 631
flatpak: 0 Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2021-06-18
Last full system update: 2022-08-13 âť
** Please move this to unsupported software if that's where it belongs, I wasn't certain which category is most accurate. Thanks for moving this to the right place SGS.
