Hello! My linux was working perfectly fine and displaying at 165Hz while setting it up until i plugged my windows drive back in. Now it refuses to post at anything over 120Hz (main monitor goes black and goes to sleep after a couple seconds despite still being detected in display settings). Could the issue be related to the newly added drive and how can i fix it? It’s making my monitor look extremely choppy due to lack of GSync or Freesync.
garuda-inxi:
Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=7081c9d1-ff57-4da8-849a-0aa0f5367a85 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A wm: kwin_x11 with: krunner
Mobo: ASUSTeK model: TUF GAMING B650M-E WIFI v: Rev 1.xx serial: <filter>
part-nu: SKU uuid: ab7bd46b-b5e0-e991-3ff4-60cf84a65600
UEFI: American Megatrends v: 3035 date: 09/05/2024
ID-1: hidpp_battery_0 charge: 90% condition: N/A volts: 3.9 min: N/A
model: Logitech G935 Gaming Headset type: N/A serial: <filter>
Device-1: wacom_battery_0 model: Wacom Intuos BT S serial: N/A
charge: 100% status: discharging
Info: model: AMD Ryzen 7 7700X socket: AM5 bits: 64 type: MT MCP arch: Zen 4
gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 5111 min/max: 545/5573 boost: enabled
base/boost: 4500/5550 scaling: driver: amd-pstate-epp governor: performance
volts: 1.3 V ext-clock: 100 MHz cores: 1: 5111 2: 5111 3: 5111 4: 5111
5: 5111 6: 5111 7: 5111 8: 5111 9: 5111 10: 5111 11: 5111 12: 5111
13: 5111 14: 5111 15: 5111 16: 5111 bogomips: 143731
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 570.124.04 alternate: nouveau,nvidia_drm
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:2488 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
empty: DP-4, DP-5, HDMI-A-3, Writeback-1 bus-ID: 0d:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 40.0 C
Display: unspecified server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2970x1680 s-dpi: 91 s-size: 827x468mm (32.56x18.43")
s-diag: 950mm (37.41")
Monitor-1: DP-1 note: disabled pos: top-right model: HP w2207
serial: <filter> built: 2009 res: mode: 1680x1050 hz: 60 scale: 160% (0.625)
to: 1050x1680 dpi: 90 gamma: 1.2 size: 473x296mm (18.62x11.65")
diag: 558mm (22") ratio: 16:10 modes: max: 1680x1050 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,bottom-l
model: Acer QG241Y serial: <filter> built: 2022 res: 1680x1050 dpi: 93
gamma: 1.2 size: 530x300mm (20.87x11.81") diag: 604mm (23.8") ratio: 16:9
drv: nvidia device: 1 drv: radeonsi gbm: drv: radeonsi surfaceless:
drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 570.124.04
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.304 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: N/A device-ID: 10de:2488
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640
lanes: 16 bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Logitech G935 Gaming Headset
driver: logitech-hidpp-device,snd-usb-audio,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:6 chip-ID: 046d:0a87
Device-5: Creative Sound Blaster Play! 3
lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 041e:324d class-ID: 0300
API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
Device-2: MEDIATEK vendor: AzureWave driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 14c3:7902
Device-3: TP-Link Archer T2U PLUS [RTL8821AU] driver: rtl8821au type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:2 chip-ID: 2357:0120
IF: wlp14s0u1 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 13d3:3596
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 1.82 TiB used: 152.64 GiB (8.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.3 temp: 33.9 C
SMART: yes health: PASSED on: 317d 22h cycles: 1,478
read-units: 180,723,132 [92.5 TB] written-units: 146,522,360 [75.0 TB]
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 46.9 C scheme: GPT
SMART: yes health: PASSED on: 9 hrs cycles: 19
read-units: 80,641 [41.2 GB] written-units: 370,034 [189 GB]
used: 152.64 GiB (16.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
maj-min: 259:7
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:6
maj-min: 259:7
maj-min: 259:7
maj-min: 259:7
ID-1: swap-1 type: zram size: 30.49 GiB used: 1.65 GiB (5.4%)
System Temperatures: cpu: 47.9 C mobo: 41.5 C
GPU: device: nvidia screen: :0.0 temp: 51 C fan: 53% device: amdgpu
temp: 40.0 C
Memory: total: 32 GiB note: est. available: 30.49 GiB used: 9.65 GiB (31.7%)
Processes: 491 Power: uptime: 3h 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.13 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1674 libs: 543
tools: gnome-software,octopi,paru pm: appimage pkgs: 0 pm: flatpak pkgs: 0
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi (sudo)
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
System install date: 2025-03-05
Last full system update: 2025-03-06 ↻
Windows dual boot: Yes
