I have installed garuda dragonized edition just 3-4 days back. I am noticing low battery life and when the battery percentage reaches around 35% there is a sudden drop in battery percentage to 5%-10%. What are the possible cause for this and How can this be fixed ?
inxi -Fza
System: Kernel: 5.12.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ed07f0e4-525f-490e-8eb6-bbd3414e5b1f
Desktop: KDE Plasma 5.22.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: Inspiron 5570 v: N/A serial: <filter> Chassis: type: 10
Mobo: Dell model: 0GHXK4 v: A00 serial: <filter> UEFI: Dell v: 1.4.1 date: 12/24/2020
Battery: ID-1: BAT0 charge: 17.3 Wh (62.5%) condition: 27.7/42.0 Wh (66.1%) volts: 11.3 min: 11.4
model: SMP DELL Y3F7Y6B type: Li-ion serial: <filter> status: Discharging
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3400 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3400 2: 3401 3: 3400 4: 3401
5: 3401 6: 3400 7: 3404 8: 3400
Graphics: Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 1bcf:28c1 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati,intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.12.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:4 chip-ID: 0cf3:e009
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
Drives: Local Storage: total: 1.82 TiB used: 13.78 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: SDM2 scheme: GPT
Partition: ID-1: / raw-size: 101 GiB size: 101 GiB (100.00%) used: 10.22 GiB (10.1%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 500 MiB size: 496 MiB (99.20%) used: 102.9 MiB (20.7%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 234.29 GiB size: 234.29 GiB (100.00%) used: 3.46 GiB (1.5%) fs: btrfs
dev: /dev/sda12 maj-min: 8:12
ID-4: /var/log raw-size: 101 GiB size: 101 GiB (100.00%) used: 10.22 GiB (10.1%) fs: btrfs
ID-5: /var/tmp raw-size: 101 GiB size: 101 GiB (100.00%) used: 10.22 GiB (10.1%) fs: btrfs
ID-1: swap-1 type: zram size: 981.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 981.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 981.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 981.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 981.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 981.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 981.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 981.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 67.0 C mobo: 50.0 C sodimm: SODIMM C gpu: amdgpu temp: 60.0 C
Fan Speeds (RPM): cpu: 3678
Info: Processes: 307 Uptime: 4m wakeups: 2 Memory: 7.67 GiB used: 2.79 GiB (36.4%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1193 lib: 293
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
