Hello.
I booted up Skyrim after doing a fresh install of KDE Dragonized Gaming Edition and I noticed that I'm only getting around half the performance that I would get on Windows 10. My output from inxi -Faz is;
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=0e5eee11-92ba-4cd6-9333-4d8024cbaa4a
systemd.unified_cgroup_hierarchy=1 loglevel=3 nouveau.modeset=0
Desktop: KDE Plasma 5.23.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: Dell product: OptiPlex 9020 v: 01 serial: <filter> Chassis: type: 15
Mobo: Dell model: 00V62H v: A01 serial: <filter> UEFI: Dell v: A12 date: 05/06/2015
CPU: Info: Quad Core model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell family: 6
model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 26339
Speed: 3293 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 3293 2: 3292 3: 3292 4: 3292
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: Micro-Star MSI driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:1380 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7") s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio: Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 02:00.1 chip-ID: 10de:0fbc class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-1.5:4 chip-ID: 0951:16a4 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel port: f040
bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: TP-Link Archer T2U PLUS [RTL8821AU] type: USB driver: rtl88XXau bus-ID: 1-1.3:3
chip-ID: 2357:0120 class-ID: 0000 serial: <filter>
IF: wlp0s26u1u3 state: up mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 70.2 GiB (14.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingfast model: N/A size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 7B0 scheme: GPT
Partition: ID-1: / raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 70.2 GiB (14.7%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 70.2 GiB (14.7%) fs: btrfs
ID-4: /var/log raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 70.2 GiB (14.7%) fs: btrfs
ID-5: /var/tmp raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 70.2 GiB (14.7%) fs: btrfs
ID-1: swap-1 type: zram size: 15.57 GiB used: 2.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 34%
Info: Processes: 232 Uptime: 17m wakeups: 0 Memory: 15.57 GiB used: 4.01 GiB (25.8%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1706 lib: 493
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.07
Some things I have already tried is to install the NVIDIA drivers as it says in the Arch Wiki, by using
sudo pacman -S nvidia
https://wiki.archlinux.org/title/NVIDIA#Installation
Is there anything else I can do? I was able to get up to 60 FPS when I was using Pop!_OS so I know it is possible to get better performance, however I admit I'm still fairly inexperienced with Linux so I'm not sure what is left to be done.
