Recently migrated to Garuda and having these stuttering issues. First, had massive issues with wayland so moved to X11 and those issues were resolved. But now, something as simple as opening settings and it just stutters and briefly freezes up. This happens whether I have multiple things open or on a fresh reboot. Not sure what to check as this is the only distro I have this issue with. Thanks
Kernel: 6.8.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e3ff2d8e-e0d8-41f9-b45b-5f7c2914aedb rw rootflags=subvol=@
Type: Desktop System: Micro-Star product: MS-7C56 v: 1.0
Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
Megatrends LLC. v: 1.G0 date: 01/30/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
Device-2: hidpp_battery_1 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 95% rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3437 high: 3608 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3608
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400
12: 3400 13: 3400 14: 3400 15: 3597 16: 3400 bogomips: 108805
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-1,DP-2,HDMI-A-1 empty: DP-3
bus-ID: 2b:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Screen-1: 0 s-res: 6400x1440 s-dpi: 108 s-size: 1505x333mm (59.25x13.11")
s-diag: 1541mm (60.69")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,left
model: 27E1QA serial: <filter> built: 2022 res: 2560x1440 hz: 60 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 640x480
Monitor-2: DP-2 mapped: DP-3 note: disabled pos: right model: 40S305
built: 2018 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
size: 698x392mm (27.48x15.43") diag: 1021mm (40.2") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-3: HDMI-A-1 mapped: HDMI-0 note: disabled pos: center
model: 100002480 serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 103
gamma: 1.2 size: 474x296mm (18.66x11.65") diag: 552mm (21.7") ratio: 16:10
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
memory: 11.72 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.76 device-ID: 10de:2504
surfaces: xcb,xlib
Device-1: NVIDIA GA106 High Definition Audio vendor: ZOTAC
bus-ID: 2b:00.1 chip-ID: 10de:228e class-ID: 0403
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.8-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.3:6
chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.93 TiB used: 661.52 GiB (33.4%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: HP model: SSD EX900 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103L0L temp: 24.9 C
ID-3: /dev/sda maj-min: 8:0 model: General USB Flash Disk size: 116.06 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1.00
scheme: MBR
used: 135.01 GiB (14.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.71 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.8 C mobo: N/A gpu: nvidia temp: 48 C
Memory: total: 64 GiB note: est. available: 62.72 GiB used: 8.38 GiB (13.4%)
Processes: 383 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.05 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1692 libs: 515 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-04-27
Last full system update: 2024-04-30
