Stuttering and audio crackling in cyberpunk 2077 with vkbasalt
i’m trying to use vkbasalt to add CAS to cyberpunk 2077 (heroic proton GE) but it causes stutters and audio crackling when I enable it.
  Kernel: 6.5.6-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=1e0ad18c-0993-40e1-b5e4-31a3b75f8dad rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
  Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 2.H0
    date: 09/21/2023
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3615 high: 3775 min/max: 2200/4426 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
    3: 3600 4: 3600 5: 3600 6: 3599 7: 3600 8: 3775 9: 3598 10: 3600 11: 3600
    12: 3600 13: 3600 14: 3681 15: 3600 16: 3600 bogomips: 115200
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
    bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
    16.0.6 DRM 3.54 6.5.6-zen2-1-zen) device-ID: 1002:73df memory: 11.72 GiB
    unified: no display-ID: :1.0
  API: Vulkan v: 1.3.264 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
    bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
    chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
  Device-4: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 2972:0047 class-ID: fe01
  API: ALSA v: k6.5.6-zen2-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 2.96 TiB used: 95.46 GiB (3.2%)
    fw-rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
    size: 232.97 GiB block-size: physical: 512 B logical: 512 B type: USB
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 95.46 GiB (5.1%)
    used: 95.46 GiB (5.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 44.1 C mobo: N/A gpu: amdgpu temp: 58.0 C
    mem: 64.0 C
  Processes: 396 Uptime: 23m wakeups: 0 Memory: total: 32 GiB
  available: 31.27 GiB used: 4.63 GiB (14.8%) Init: systemd v: 254
  pm: pacman pkgs: 1671 libs: 471 tools: pamac,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
  System install date:     2023-10-10
  Last full system update: 2023-10-12 ↻
Please post any code or terminal output between three tildes (~~~), as per the template. You should edit your posts that don’t have this for the sake of readability.
So it will look like
text
text
Give a try to the linux-lts kernel.
The zen is more recent and performant, but you never can say if this was due to some kind of regression.
Try other kernels as well, if necessary.
