Stuck updates on Electron32/33
I will just start with this…
 ╭─fenris@fenris in ~ as 🧙 took 0s
 ╰─λ sudo garuda-inxi
  Kernel: 6.14.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=eed48c34-1b13-4d71-bad8-04acafd7f053 rw rootflags=subvol=@
    quiet rd.luks.uuid=6e967d35-e4db-410a-a8eb-2613aa0cd353
    rd.luks.uuid=79041de9-b072-44cd-a361-6b70bf057db1
    resume=/dev/mapper/luks-79041de9-b072-44cd-a361-6b70bf057db1 loglevel=3
  Type: Desktop Mobo: AZW model: MINI S v: 10 serial: N/A part-nu: 01
    uuid: 03000200-0400-0500-0006-000700080009 UEFI: American Megatrends LLC.
    v: ADLNV104 date: 02/06/2023
  Info: model: Intel N100 socket: U3E1 bits: 64 type: MCP arch: Alder Lake
    level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
    model-id: 0xBE (190) stepping: 0 microcode: 0x1C
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 700 min/max: 700/3400 base/boost: 2871/3400 scaling:
    driver: intel_pstate governor: performance volts: 1.0 V ext-clock: 100 MHz
    cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 6451
  Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
    alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: HDMI-A-2 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46d1
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2.3:9
    chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1707x1067 s-dpi: 96 s-size: 452x283mm (17.80x11.14")
    s-diag: 533mm (21")
  Monitor-1: HDMI-A-2 mapped: HDMI-2 model: TESmart-FHD serial: <filter>
    built: 2021 res: mode: 1280x800 hz: 60 scale: 74% (1.33359375) to: 1707x1067
    dpi: 54 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL-N)
    device-ID: 8086:46d1 memory: 7.52 GiB unified: yes
  API: Vulkan v: 1.4.309 layers: 7 device: 0 type: integrated-gpu
    name: Intel Graphics (ADL-N) driver: mesa intel v: 25.0.5-arch1.1
    device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
  Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
    chip-ID: 8086:54c8 class-ID: 0403
  Device-2: C-Media CM106 Like Sound Device
    lanes: 1 mode: 1.1 bus-ID: 1-1.1:4 chip-ID: 0d8c:0102 class-ID: 0300
  Device-3: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.14.5-zen1-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 1.4.2 status: n/a (root, process) with:
  Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:54f0 class-ID: 0280
    bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3.1:11
    chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
  IF: enp0s20f0u1u3u1 state: down mac: <filter>
    wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:10 chip-ID: 8087:0026
  Local Storage: total: 2.73 TiB used: 2.07 TiB (75.8%)
    model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 731100WD temp: 62.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
    used: 411.45 GiB (45.0%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
    maj-min: 253:1 mapped: luks-6e967d35-e4db-410a-a8eb-2613aa0cd353
    used: 768 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
  ID-4: /var/log raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
  ID-5: /var/tmp raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-79041de9-b072-44cd-a361-6b70bf057db1
  ID-2: swap-2 type: zram size: 15.39 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
  System Temperatures: cpu: 73.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.39 GiB used: 4.79 GiB (31.1%)
    igpu: 60 MiB
  Processes: 326 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.14 GiB services: upowerd,xfce4-power-manager
  Packages: pm: pacman pkgs: 1988 libs: 533 tools: pamac,paru pm: appimage
    pkgs: 0 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi (sudo)
    default: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.38
  System install date:     2024-09-11
  Last full system update: 2025-05-09
  Failed units:            vmware.service
 ╭─fenris@fenris in ~ as 🧙 took 2s
 ╰─λ
So I was just doing what we always do garuda-update --aur and I get some updates for Aur:
--> Updating AUR packages with paru..
:: Looking for devel upgrades...
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating inner conflicts...
:: packages not in the AUR: python-abydos  quartus-free-hls
:: marked out of date: chatgpt-desktop-bin
:: orphans: kvirc-git
Aur (2)         Old Version  New Version    Make Only
aur/electron32  32.3.1-3     32.3.3-1       No
aur/electron33  33.4.11-1    33.4.11-2      No
:: Proceed to review? [Y/n]:
My issue is, they seem to proceed normally but just seem to stall out in the middle of the terminal screen, everytime. I tried paru electron32 and paru electron33 individually and they both seem to get stuck. I have no clue as to why, but this is what I see when I try to install:
:: Downloading PKGBUILDs...
 PKGBUILDs up to date
 nothing new to review
fetching devel info...
==> Making package: electron32 32.3.3-1 (Fri 09 May 2025 10:20:22 AM)
==> Retrieving sources...
  -> Updating electron git repo...
From https://github.com/electron/electron
 - [deleted]               (none)                   -> robo/fix_uam_xdg_portal
 - [deleted]               (none)                   -> roller/chromium/36-x-y
 - [deleted]               (none)                   -> screenshots-allowed
 - [deleted]               (none)                   -> trop/35-x-y-bp-build-update-hasher-return-value-1746729267525
 - [deleted]               (none)                   -> trop/36-x-y-bp-refactor-use-gin_helper-dictionary-valueordefault--1746731849726
 - [deleted]               (none)                   -> trop/37-x-y-bp-build-move-release-script-to-new-hasher-function-1746684916829
 - [deleted]               (none)                   -> trop/37-x-y-bp-build-update-hasher-return-value-1746729270172
 - [deleted]               (none)                   -> trop/37-x-y-bp-refactor-use-gin_helper-dictionary-valueordefault--1746731849011
 - [deleted]               (none)                   -> refs/pull/46690/merge
 - [deleted]               (none)                   -> refs/pull/46974/merge
 - [deleted]               (none)                   -> refs/pull/46993/merge
 - [deleted]               (none)                   -> refs/pull/47008/merge
 - [deleted]               (none)                   -> refs/pull/47010/merge
 - [deleted]               (none)                   -> refs/pull/47011/merge
 - [deleted]               (none)                   -> refs/pull/47014/merge
 - [deleted]               (none)                   -> refs/pull/47015/merge
 - [deleted]               (none)                   -> v38.0.0-nightly.20250508
   8696da7de8..d341a523e5  35-x-y                   -> 35-x-y
   de7cf88f17..07c0357366  36-x-y                   -> 36-x-y
   4eea6e4974..0e9c0d8c04  37-x-y                   -> 37-x-y
   2cbd968da5..75cf8ea96d  main                     -> main
   7d28a21e5a..b358693703  roller/chromium/37-x-y   -> roller/chromium/37-x-y
 + 0a871e29f0...1e17628741 roller/chromium/main     -> roller/chromium/main  (forced update)
 * [new branch]            trop/35-x-y-bp-feat-add-support-for-experimental-network-inspection--1746798263164 -> trop/35-x-y-bp-feat-add-support-for-experimental-network-inspection--1746798263164
 * [new branch]            trop/35-x-y-bp-fix-restore-previous-windows-screenshotting-1746801516952 -> trop/35-x-y-bp-fix-restore-previous-windows-screenshotting-1746801516952
 * [new branch]            trop/36-x-y-bp-feat-add-support-for-experimental-network-inspection--1746798265102 -> trop/36-x-y-bp-feat-add-support-for-experimental-network-inspection--1746798265102
 * [new branch]            trop/36-x-y-bp-fix-restore-previous-windows-screenshotting-1746801515325 -> trop/36-x-y-bp-fix-restore-previous-windows-screenshotting-1746801515325
 * [new branch]            trop/37-x-y-bp-feat-add-support-for-experimental-network-inspection--1746798269115 -> trop/37-x-y-bp-feat-add-support-for-experimental-network-inspection--1746798269115
 * [new branch]            trop/37-x-y-bp-fix-restore-previous-windows-screenshotting-1746801515958 -> trop/37-x-y-bp-fix-restore-previous-windows-screenshotting-1746801515958
 * [new branch]            white-flicker-bg-color   -> white-flicker-bg-color
 + 391950bab6...c5d5856ae8 refs/pull/38437/merge    -> refs/pull/38437/merge  (forced update)
 + 82fc15c040...1135a6c29f refs/pull/40667/merge    -> refs/pull/40667/merge  (forced update)
 + 9a72eef03f...5f971040eb refs/pull/41281/merge    -> refs/pull/41281/merge  (forced update)
 + 61a8b2a1fa...6069a63fd8 refs/pull/41314/merge    -> refs/pull/41314/merge  (forced update)
 + 3ccb799775...c1332cb773 refs/pull/41369/merge    -> refs/pull/41369/merge  (forced update)
 + 65f40bcc99...1336ff63ee refs/pull/42549/merge    -> refs/pull/42549/merge  (forced update)
 + d0fcbe1d0b...6f071b3387 refs/pull/43248/merge    -> refs/pull/43248/merge  (forced update)
 + 0f8cc5014f...8d54322bb0 refs/pull/43708/merge    -> refs/pull/43708/merge  (forced update)
 + 07a4c17c0a...0a66b23309 refs/pull/43771/merge    -> refs/pull/43771/merge  (forced update)
 + d74120ff09...d4056abb28 refs/pull/44099/merge    -> refs/pull/44099/merge  (forced update)
 + 912c8b9581...5b9dc8d644 refs/pull/44155/merge    -> refs/pull/44155/merge  (forced update)
 + 3804938147...e4f38d30cf refs/pull/44984/merge    -> refs/pull/44984/merge  (forced update)
 + 1cc3dced2b...0359d1a750 refs/pull/45050/merge    -> refs/pull/45050/merge  (forced update)
 + 4b2e03050a...112b456ade refs/pull/45186/merge    -> refs/pull/45186/merge  (forced update)
 + 6fec2ae481...872ff63dbd refs/pull/45221/merge    -> refs/pull/45221/merge  (forced update)
 + 50debb860e...c16f812f36 refs/pull/45538/merge    -> refs/pull/45538/merge  (forced update)
 + bcdce2bde6...ed1a5a9f53 refs/pull/45640/merge    -> refs/pull/45640/merge  (forced update)
 + 5298f240f5...97bb332770 refs/pull/45693/merge    -> refs/pull/45693/merge  (forced update)
 + 6ae10c778c...8424c49af1 refs/pull/45839/merge    -> refs/pull/45839/merge  (forced update)
 + 552fcdf3a7...d7f68df648 refs/pull/45861/merge    -> refs/pull/45861/merge  (forced update)
 + bf2868e40f...53fa185da5 refs/pull/45930/merge    -> refs/pull/45930/merge  (forced update)
 + 7d1bfb0a99...d6997b77ef refs/pull/45934/merge    -> refs/pull/45934/merge  (forced update)
 + 2961445670...0563b402b5 refs/pull/46227/merge    -> refs/pull/46227/merge  (forced update)
 + 0b5b835034...c8af3362f0 refs/pull/46351/merge    -> refs/pull/46351/merge  (forced update)
 + 68c7b6a13f...88e66a6374 refs/pull/46386/merge    -> refs/pull/46386/merge  (forced update)
 + bbe40219f6...e66107882a refs/pull/46518/merge    -> refs/pull/46518/merge  (forced update)
 + 72f245537d...039bb7fed7 refs/pull/46577/merge    -> refs/pull/46577/merge  (forced update)
 + 807e699975...3fd7c4f44e refs/pull/46630/merge    -> refs/pull/46630/merge  (forced update)
 + 717f5ddb6a...fd8028ffc5 refs/pull/46703/merge    -> refs/pull/46703/merge  (forced update)
 + 12dde8c6c5...537f97a749 refs/pull/46740/merge    -> refs/pull/46740/merge  (forced update)
 + 297a2c18fd...c50e1ccafd refs/pull/46747/merge    -> refs/pull/46747/merge  (forced update)
 + 12265311e9...ec90294605 refs/pull/46749/merge    -> refs/pull/46749/merge  (forced update)
 + 5255d013f7...46e814fc1e refs/pull/46760/merge    -> refs/pull/46760/merge  (forced update)
 + dd08ed4a17...7380b387df refs/pull/46807/merge    -> refs/pull/46807/merge  (forced update)
 + 4b1d63e9aa...3f58b5d680 refs/pull/46810/merge    -> refs/pull/46810/merge  (forced update)
 + 2c718a8c66...9bba34271b refs/pull/46811/merge    -> refs/pull/46811/merge  (forced update)
 + b7ab17482a...a2e5af0a3a refs/pull/46822/merge    -> refs/pull/46822/merge  (forced update)
 + 7d23fa68c2...8aa9bdd45a refs/pull/46826/merge    -> refs/pull/46826/merge  (forced update)
 + 68a3a17302...652bbce2f8 refs/pull/46855/merge    -> refs/pull/46855/merge  (forced update)
 + cdb08c93ac...7014d03e39 refs/pull/46887/merge    -> refs/pull/46887/merge  (forced update)
 + 5d66a40da7...ccec20825d refs/pull/46926/merge    -> refs/pull/46926/merge  (forced update)
 + b83a04c28b...47e112e096 refs/pull/46943/merge    -> refs/pull/46943/merge  (forced update)
 + 51a6bffb7c...f59630f5a8 refs/pull/46957/merge    -> refs/pull/46957/merge  (forced update)
 + 94a841876b...ee71197b0a refs/pull/46970/merge    -> refs/pull/46970/merge  (forced update)
 + 5977d1b116...119eaf41e3 refs/pull/46978/merge    -> refs/pull/46978/merge  (forced update)
 + 44f9a92e2f...2947f15685 refs/pull/46979/merge    -> refs/pull/46979/merge  (forced update)
   7d28a21e5a..b358693703  refs/pull/46980/head     -> refs/pull/46980/head
 + 70a41720f4...23d276f944 refs/pull/46980/merge    -> refs/pull/46980/merge  (forced update)
 + 0a871e29f0...1e17628741 refs/pull/46986/head     -> refs/pull/46986/head  (forced update)
 + 312934a2e3...48388c137e refs/pull/46986/merge    -> refs/pull/46986/merge  (forced update)
 + 0bd58f1e93...a63f0faa35 refs/pull/46987/merge    -> refs/pull/46987/merge  (forced update)
 + 300307acd8...695d59c1ba refs/pull/46997/merge    -> refs/pull/46997/merge  (forced update)
 + 15ab469d53...08155db703 refs/pull/47012/merge    -> refs/pull/47012/merge  (forced update)
 + 1fb6af9688...e5c4041384 refs/pull/47017/merge    -> refs/pull/47017/merge  (forced update)
 + 1bc9d69db8...4f7f386254 refs/pull/47018/merge    -> refs/pull/47018/merge  (forced update)
 * [new ref]               refs/pull/47020/head     -> refs/pull/47020/head
 * [new ref]               refs/pull/47022/head     -> refs/pull/47022/head
 * [new ref]               refs/pull/47022/merge    -> refs/pull/47022/merge
 * [new ref]               refs/pull/47023/head     -> refs/pull/47023/head
 * [new ref]               refs/pull/47024/head     -> refs/pull/47024/head
 * [new ref]               refs/pull/47025/head     -> refs/pull/47025/head
 * [new ref]               refs/pull/47029/head     -> refs/pull/47029/head
 * [new ref]               refs/pull/47029/merge    -> refs/pull/47029/merge
 * [new ref]               refs/pull/47030/head     -> refs/pull/47030/head
 * [new ref]               refs/pull/47030/merge    -> refs/pull/47030/merge
 * [new ref]               refs/pull/47031/head     -> refs/pull/47031/head
 * [new ref]               refs/pull/47031/merge    -> refs/pull/47031/merge
 * [new ref]               refs/pull/47032/head     -> refs/pull/47032/head
 * [new ref]               refs/pull/47032/merge    -> refs/pull/47032/merge
 * [new ref]               refs/pull/47033/head     -> refs/pull/47033/head
 * [new ref]               refs/pull/47033/merge    -> refs/pull/47033/merge
 * [new ref]               refs/pull/47034/head     -> refs/pull/47034/head
 * [new ref]               refs/pull/47034/merge    -> refs/pull/47034/merge
 * [new tag]               v38.0.0-nightly.20250509 -> v38.0.0-nightly.20250509
  -> Found chromium-patches-127-1.tar.bz2
  -> Found allow-ANGLEImplementation-kVulkan.patch
  -> Found compiler-rt-adjust-paths.patch
  -> Found increase-fortify-level.patch
  -> Found blink-fix-missing-stdlib-include.patch
  -> Found pipewire-1.4.patch
  -> Found default_app-icon.patch
  -> Found electron-launcher.sh
  -> Found electron.desktop
  -> Found jinja-python-3.10.patch
  -> Found use-system-libraries-in-node.patch
  -> Found makepkg-source-roller.py
  -> Found electron-32.3.3-adjust-context-for-fix_osr_stutter_in_both_cpu_and_gpu_capture_when_page_has_animation.patch
  -> Cloning chromium-mirror git repo...
Cloning into bare repository '/home/fenris/.cache/paru/clone/electron32/chromium-mirror'...
I could use a little help to push this along please :smiling_face:
Try
cleanup
first.
Totally forgot about the cleanup command
 there is nothing to do
System updated! 🐧
It looks like that is all it took to fix the problem, thank you!
