Hello,
Today I'm having this issue with my system, after a full update and reboot it remains stuck on the "Loading initial ramdisk" screen. I can boot to recovery mode and I can chroot into it from a live USB and restore it through snapper-tools
How do I fix this permanently?
This is my garuda-inxi
from recovery mode:
Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=3b52a2cf-a724-4548-b109-e2a369bab4d2
rw single rootflags=subvol=@
Console: tty 1 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7A34 v: 1.0 serial: N/A
Mobo: Micro-Star model: B350 TOMAHAWK (MS-7A34) v: 1.0 serial: <filter>
UEFI-[Legacy]: American Megatrends v: 1.M0 date: 01/23/2019
Device-1: gip0.0 model: Microsoft X-Box One pad serial: N/A charge: N/A status: not charging
Info: model: AMD Ryzen 5 1600 socket: AM4 bits: 64 type: MT MCP arch: Zen level: v3 note: check
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001137
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 576 KiB
desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3699 min/max: N/A base/boost: 3700/3700 volts: 1.2 V ext-clock: 100 MHz
cores: 1: 3699 2: 3699 3: 3699 4: 3699 5: 3699 6: 3699 7: 3699 8: 3699 9: 3699 10: 3699 11: 3699
12: 3699 bogomips: 88786
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: CardExpert driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 525.xx+ status: current (as of 2023-02) arch: Turing
code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 1c:00.0 chip-ID: 10de:1f07 class-ID: 0300
Display: server: X.org v: 1.21.1.7 with: Xwayland v: 23.1.0 driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia tty: 192x54
API: OpenGL Message: GL data unavailable in console for root.
Device-1: NVIDIA TU106 High Definition Audio vendor: CardExpert driver: snd_hda_intel
bus-ID: 1-3:2 v: kernel pcie: chip-ID: 1b1c:0a51 class-ID: 0300 gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 1c:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 1e:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Corsair VOID ELITE Wireless Gaming Dongle type: USB
Sound API: ALSA v: k6.2.8-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.67 running: no
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 19:00.0
IF: enp25s0 state: down mac: <filter>
Local Storage: total: 2.31 TiB used: 1.66 TiB (71.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: RKT303.3 temp: 28.9 C scheme: MBR
SMART: yes health: PASSED on: 357d 13h cycles: 1,011 read-units: 42,881,681 [21.9 TB]
written-units: 39,745,533 [20.3 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-00MFCA0 family: Blue
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 1A01 temp: 30 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 360d 1h cycles: 2270
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD7500BPKT-75PK4T0
family: Scorpio Black (AF) size: 698.64 GiB block-size: physical: 4096 B logical: 512 B
sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 1A01 temp: 31 C
SMART: yes state: enabled health: PASSED on: 2y 292d 9h cycles: 3583 read: 42.95 TiB
written: 15.6 TiB Old-Age: g-sense error rate: 45456
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB family: based SSDs
size: 465.76 GiB block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 2B6Q temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 330d 20h cycles: 2141 written: 32.67 TiB
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Lexar model: microSD RDR size: 29.83 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 0815 scheme: MBR
ID-1: / raw-size: 221.27 GiB size: 221.27 GiB (100.00%) used: 182.05 GiB (82.3%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 221.27 GiB size: 221.27 GiB (100.00%) used: 182.05 GiB (82.3%) fs: btrfs
ID-3: /var/log raw-size: 221.27 GiB size: 221.27 GiB (100.00%) used: 182.05 GiB (82.3%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/tmp raw-size: 221.27 GiB size: 221.27 GiB (100.00%) used: 182.05 GiB (82.3%)
ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 31.2 C mobo: N/A gpu: nvidia temp: 38 C
Processes: 265 Uptime: 0m wakeups: 6 Memory: 15.57 GiB used: 657.7 MiB (4.1%) Init: systemd
v: 253 default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 2052
pm: pacman pkgs: 2024 libs: 530 tools: gnome-software,pamac,paru,yay pm: flatpak pkgs: 28
Shell: Bash v: 5.1.16 running-in: tty 1 inxi: 3.3.25
System install date: 2023-03-19
Last full system update: 2023-03-25
Relevant software: snapper mkinitcpio nvidia-dkms
Try to rebuild your initramfs and check for any errors.
sudo mkinitcpio -P
Paste the input and output into the thread. Then reboot and test again.
Hello, unfortunately it still didn't boot
Here's the mkinitcpio
output:
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img --microcode /boot/amd-ucode.img
==> Starting build: '6.2.8-zen1-1-zen'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
==> ERROR: file not found: '/usr/share/fonts/cantarell/Cantarell-VF.otf'
-> Running build hook: [resume]
-> Running build hook: [filesystems]
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-zen.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect --microcode /boot/amd-ucode.img
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-zen-fallback.img'
Aside from the font, it doesn't seem to be any significant error, or is it?
I also tried to run update-grub
, here's the output:
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-zen-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
Found Debian GNU/Linux 10 (buster) on /dev/nvme0n1p1
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-03-25 23:30:21 | @/.snapshots/788/snapshot | post | openrgb-git |
Found snapshot: 2023-03-25 23:30:17 | @/.snapshots/787/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2023-03-25 23:20:40 | @/.snapshots/786/snapshot | post | otis-theme-git proton-ge-custom-bin rtl8821au-dkms-git sweet-theme-git u |
Found snapshot: 2023-03-25 23:19:21 | @/.snapshots/785/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2023-03-25 23:16:54 | @/.snapshots/784/snapshot | post | nvidia-dkms ruffle-git |
Found snapshot: 2023-03-25 23:14:28 | @/.snapshots/783/snapshot | pre | pacman -Syu nvidia-dkms |
Found snapshot: 2023-03-25 21:46:43 | @/.snapshots/782/snapshot | post | a2ps alacritty alsa-firmware alsa-oss alsa-tools alsa-topology-conf apps |
Found snapshot: 2023-03-25 21:41:47 | @/.snapshots/781/snapshot | pre | pacman -Su |
Found snapshot: 2023-03-25 21:41:14 | @/.snapshots/780/snapshot | post | flutter |
Found snapshot: 2023-03-25 21:41:08 | @/.snapshots/779/snapshot | pre | pacman -S --overwrite * flutter |
Found snapshot: 2023-03-25 19:37:42 | @/.snapshots/778/snapshot | post | alacritty |
Found snapshot: 2023-03-25 19:37:32 | @/.snapshots/777/snapshot | pre | [kworker/u24:4-btrfs-endio] |
Found snapshot: 2023-03-25 17:55:10 | @/.snapshots/776/snapshot | post | otis-theme-git proton-ge-custom-bin rtl8821au-dkms-git sweet-theme-git u |
Found snapshot: 2023-03-25 17:53:41 | @/.snapshots/775/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2023-03-25 17:50:00 | @/.snapshots/774/snapshot | post | a2ps appstream-glib at-spi2-core bind bison calf cmake coreutils cryptse |
Found snapshot: 2023-03-25 17:45:20 | @/.snapshots/773/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2023-03-25 17:45:06 | @/.snapshots/772/snapshot | post | archlinux-keyring |
Found snapshot: 2023-03-25 17:45:01 | @/.snapshots/771/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2023-03-25 17:30:01 | @/.snapshots/770/snapshot | post | archlinux-keyring |
Found snapshot: 2023-03-25 17:29:55 | @/.snapshots/769/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2023-02-08 22:47:55 | @_backup_20232503193926275 | N/A | N/A |
Found snapshot: 2023-02-08 21:20:23 | @/.snapshots/626/snapshot | single | Before Pulseaudio |
Found snapshot: 2022-11-02 21:35:40 | @/.snapshots/296/snapshot | single | Post Restore 42 |
Found snapshot: 2022-11-02 21:32:29 | @_backup_20230802224755418 | N/A | N/A |
Found snapshot: 2022-11-02 19:51:57 | @_backup_20220211213229504_42 | N/A | N/A |
Found snapshot: 2022-09-20 23:41:34 | @_backup_20220211195157106 | N/A | N/A |
Found snapshot: 2022-08-07 21:00:50 | @/.snapshots/1/snapshot | single | Manual Snapshot |
Found snapshot: 2022-08-01 20:10:08 | @_backup_20222009234134168 | N/A | N/A |
Found 28 snapshot(s)
Unmount /tmp/grub-btrfs.eoYqECyqn4 .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
That font appears to be needed for plymouth-git
pacman -Sii cantarell-fonts
Repository : extra
Version : 1:0.303.1-1
Description : Humanist sans serif font
Architecture : any
URL : https://gitlab.gnome.org/GNOME/cantarell-fonts
Licenses : custom:SIL
Groups : None
Provides : None
Depends On : None
Optional Deps : None
Required By : all-repository-fonts gnome-themes-extra gsettings-desktop-schemas gsettings-desktop-schemas-git gtk3
gtk3-patched-filechooser-icon-view gtk4 gtk4-telegrand plymouth-git ttf-google-fonts-git
Try installing it:
pacman -S cantarell-fonts
Then rebuild the initramfs again.
Your other option would be to remove the quiet quiet splash
kernel parameters, which would allow you to get through the boot process without Plymouth–that is what your fallback image is doing.
Unfortunately it didn't work, I've been having that font error for months I was kinda expecting it to not be the issue
Is reinstall my only option?
Edit: I also tried removing quiet splash
(there's only one quiet in my cmd) but it's the same
Edit 2: I also tried with linux-lts
and it doesn't work either
Before reinstalling, can you try switching to Dracut and see if you get a different outcome?
sudo pacman -S garuda-dracut-support
Confirm the removals, then build a new image.
sudo dracut-rebuild
If not, lets see what's in the journal. Boot to the initial ramdisk prompt where it gets stuck, then switch to a TTY (Ctrl +Alt +F3 ), sign in and run:
sudo journalctl -b | tb
Add the termbin url to the thread so we can take a look.
filo
26 March 2023 11:10
7
Before reinstalling I’d also try restoring the latest working snapshot and holding back the Nvidia packages.
Then at the next Nvidia drivers update, I’d try removing the hold.
And before that, I’d try the dkms things here:
While there are many potential reasons why your installation doesn’t boot to a desktop, the primary reason is that the graphics drivers haven’t loaded correctly so your login/display manager (DM) doesn’t start. This is why you get a “black screen” or stuck at an
[ OK ] Started some service
message.
The normal reason for this is that you have the incorrect driver version for the kernel. This can happens when the mirror you are updating from is not fully synchronised, or times out, and so y…
Sorry guys I really needed my PC, I reinstalled (and switched to KDE just for fun)
I'll keep this in mind if I'll ever have the same issue again
No worries, I’m glad you were able to get up and running again.
palexdev:
and switched to KDE
What had you initially installed, Gnome? I wonder if it was another weird GDM bug…
Yes, I was on Gnome
I spent an entire day re-setting the PC with all the apps, scripts and so on that I need for work and gaming but...omg it was totally worth it.
I don't know why but gaming is so much smoother on KDE, I was experiencing weird stutters on Elden Ring and I had an avarage of 45/50fps, on KDE I have no stutter and i'm at 60fps all the time
Also, I was having issues with pipewire, bluetooth experience was very bad, stutters, crackling and often even stopped reproducing audio, finally on KDE it works flawlessly
system
Closed
9 April 2023 21:11
14
