Hello.
I recently started using garuda as my first linux system, I installed everything and after installing everything I updated my system, and restarted computer. The problem was that my wallpaper turned black, all icons disappeard and I guess that is a problem with nvidia drivers, but after reinstalling them and restarting I am now stuck on "loading initial ramdisc" screen.
If anyone has any idea what could I do to make it work, I would be really grateful.
With love, Rosemary.
TNE
14 February 2022 14:34
2
Have you tried restoring a snapshot from before you reinstalled your NVIDIA drivers?
FGD
14 February 2022 14:36
3
Are you able to post the output of garuda-inxi?
This will give important information about your hardware which is quite required in that type of issue... you could boot from live ISO and issue the command there if you cannot boot from a Snapshot of you already installed Garuda.
Also WELCOME to the Forums!
yes, but the same thing happens, black wallpaper
Thanks for welcoming!
Here's the output:
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/.snapshots/10/snapshot/boot/vmlinuz-linux-zen
root=UUID=72b279c1-3f0d-4415-9d7b-a4ea6e77c4b0 quiet splash
resume=UUID=58cc8b03-c348-490c-a855-876f6c4b2546 loglevel=3
rootflags=defaults,noatime,noautodefrag,compress=zstd,subvol=@/.snapshots/10/snapshot
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: Micro-Star model: H310M PRO-M2 PLUS (MS-7C08) v: 1.1
serial: <superuser required> UEFI: American Megatrends v: D.30
date: 05/06/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 4018 high: 4098 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4000 2: 4004 3: 4000
4: 4098 5: 4003 6: 4004 bogomips: 34798
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2184 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5")
s-diag: 693mm (27.3")
Monitor-1: DP-0 res: 1920x1080 dpi: 82 size: 595x336mm (23.4x13.2")
diag: 683mm (26.9")
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel bus-ID: 03:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-9:4 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 1.14 TiB used: 19.64 GiB (1.7%)
model: PC SN520 SDAPNUW-256G-1032 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20140000 temp: 43.9 C scheme: GPT
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-1: /boot/efi raw-size: 5 GiB size: 4.99 GiB (99.80%)
used: 576 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 376.2 MiB (0.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 223.47 GiB size: 223.47 GiB (100.00%)
used: 19.27 GiB (8.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/tmp raw-size: 223.47 GiB size: 223.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.69 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 258 Uptime: 0m wakeups: 0 Memory: 7.69 GiB used: 1.6 GiB (20.8%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.1
Packages: pacman: 1926 lib: 543 Shell: fish v: 3.3.1 running-in: konsole
inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-14
Last full system update: 2022-02-14
TNE
14 February 2022 15:03
7
Black wallpaper is a lot less bad than a non booting system though, isn't it?
I suggest you:
Boot the snapshot
Restore the snapshot using btrfs-assistant
Reboot into your normal system (which should now be the one you restored from)
Open Garuda Assistant and reset all configs (tick the all checkbox at the bottom and then press Reset Selected Configs)
Reboot
Yes, but still I couldn't do many tasks, if I would want to play games then the whole bottom part of the screen is just... black so I can't really see about 1/8th of the screen
Click here for more info
Make sure that you are currently booting in ACHI SATA configureation mode
I also got same kind of loading problem when I dual booted Garuda Linux with Windows 7
I was booting with IDE SATA configureation and it took nearly 30 mins to load the login screen [SDMM]
By Default if ACHI SATA configureation is not selected then go and select it in your BIOS / UEFI
I am and have been using only ACHI, no other SATA configuration
Bro
16 February 2022 01:45
11
Your BIOS is dated 2019. Are there (Micro-Star?) any manufacturer updates for it?
P.S. You don't have to sign "with love," but I think it's cute as hell. Welcome to the Garuda Linux Forums.
