Just installed Garuda dragonized. Did an update and reboot then installed rog-core and dependencies. After rebooting again I'm stuck in this:
It's been almost half an hour now and I'm still in this screen.
Threads merged
The title says it all. When I click on the files on the dock, it says "Unknown application folder".
Barebones?
The apps are not installed. No pic needed.
This looks pretty broken, what did you do / modify?
Indeed. I updated system with sudo pacman -Syu reboot, got error about backlight somehow fixed it, tried installing packages in software manager, reboot got an error, tried snapshots, i somehow snap back into errors until I cant boot and stuck, tried Advanced options for Garuda > Garuda, on linux-tkg-bmq, got stuck again and tried snapshot, I only see 1 snapshot and used it and ended up here.
Dragonized.
Something has become very broken. I'd recommend reinstalling at this point. Then, make a note of the changes you make so if something breaks you know what caused it.
The snapshot system is good, but it's not bullet-proof.
