sh-5.2# dracut --regenerate-all --force
dracut[I]: Executing: /usr/bin/dracut --kver=6.11.8-arch1-2 --force
dracut[I]: *** Including module: bash ***
dracut[I]: *** Including module: shell-interpreter ***
dracut[I]: *** Including module: systemd ***
dracut[I]: *** Including module: systemd-ask-password ***
dracut[I]: *** Including module: systemd-initrd ***
dracut[I]: *** Including module: systemd-journald ***
dracut[I]: *** Including module: systemd-modules-load ***
dracut[I]: *** Including module: systemd-sysctl ***
dracut[I]: *** Including module: systemd-sysusers ***
dracut[I]: *** Including module: systemd-tmpfiles ***
dracut[I]: *** Including module: systemd-udevd ***
dracut[I]: *** Including module: i18n ***
dracut[I]: *** Including module: btrfs ***
dracut[I]: *** Including module: kernel-modules ***
dracut[I]: *** Including module: kernel-modules-extra ***
dracut[I]: *** Including module: btrfs-snapshot-overlay ***
dracut[I]: *** Including module: hwdb ***
dracut[I]: *** Including module: rootfs-block ***
dracut[I]: *** Including module: terminfo ***
dracut[I]: *** Including module: udev-rules ***
dracut[I]: *** Including module: dracut-systemd ***
dracut[I]: *** Including module: usrmount ***
dracut[I]: *** Including module: base ***
dracut[I]: *** Including module: fs-lib ***
dracut[I]: *** Including module: shutdown ***
dracut[I]: *** Including modules done ***
dracut[I]: *** Installing kernel module dependencies ***
dracut[I]: *** Installing kernel module dependencies done ***
dracut[I]: *** Resolving executable dependencies ***
dracut[I]: *** Resolving executable dependencies done ***
dracut[I]: *** Hardlinking files ***
dracut[I]: *** Hardlinking files done ***
dracut[I]: *** Generating early-microcode cpio image ***
dracut[I]: *** Constructing AuthenticAMD.bin ***
dracut[I]: *** Store current command line parameters ***
dracut[I]: *** Stripping files ***
dracut[I]: *** Stripping files done ***
dracut[I]: *** Creating image file '/boot/initramfs-6.11.8-arch1-2.img' ***
dracut[I]: *** Creating initramfs image file '/boot/initramfs-6.11.8-arch1-2.img' done ***
dracut[I]: Executing: /usr/bin/dracut --kver=6.11.8-zen1-2-zen --force
dracut[I]: *** Creating image file '/boot/initramfs-6.11.8-zen1-2-zen.img' ***
dracut[I]: *** Creating initramfs image file '/boot/initramfs-6.11.8-zen1-2-zen.img' done ***
At the moment you only have the zen kernel
try;
main menu
Garuda settings manager
select kernels
select refresh
install Linux kernel and watch it compile.
then open
garuda boot options
select Linux kernel as first boot
save
and if needed
garuda-update remote fix
as you can read aboveâŚ
This is the go-to resource for the issue you are describing.
Take notes as you work through it so you can update the thread with relevant information.
If the automatic chroot tool doesnât work, use arch-chroot instead as described here: chroot - ArchWiki. Be sure to mount all the subvolumes before entering the chroot. See this topic for example: Chroot into encrypted partition - #50 by BluishHumility. Iâm not sure you need to chroot to resolve this issue, but that would be how to do it if you did.
Looks like your DKMS packages are messed up. Double-check that you have the appropriate headers installed for your kernel. If not, you will need to get those installed for each kernel you are using.
sudo pacman -S linux-zen-headers
Remove all those broken Nvidia modules, then reinstall the Nvidia DKMS package.
sudo dkms remove nvidia --all
sudo pacman -S nvidia-dkms
Probably you will want to do the same with the VirtualBox DKMS package you are using.
You responded to a nearly 200-word post that contained two multi-step suggestions with only âit does not workâ? Nothing else to say?
What did you try? What happened? Where is the terminal output from your efforts?
You are the only one here who can see what is happening on your computer. If you canât be more forthcoming with information, no one is going to be able to help you.
You would need to use the -o flag to regenerate the initramfs image this way. Otherwise, this is what happens:
You created an image file named initramfs-6.11.8-zen1-2-zen.img. When your system boots, it looks for an image file named initramfs-linux-zen.img, so the image you created isnât going to be used unless you rename it first.
Instead of that, use the dracut script the distro provides:
sudo dracut-rebuild
See also: Dracut | Garuda Linux wiki
The LTS kernel is the one to try, as suggested in post 12. Donât forget the kernel headers. ![]()
I tried in a thousand ways, in the end I preferred to reinstall Garuda ![]()
