After trying everything I found in other topics and not finding a solution, I turn to here.
I was very tired and let Octopi run updates. However, probably before it was done, I shut the PC down. Now I get the issue outlined in this thread: WARNING: community/qtermwidget 0.17.0-2 -> 1.0.0-1 Breaks Octopi - #25 with the following message:
octopi: error while loading shared libraries: libqtermwidget5.so.1: cannot open shared object file: No such fi
le or directory
As outlined in the thread, I tried rebuilding octopi using pacman, which did not let me finish the command because snapper didn’t manage to set a locale.
: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [------------------------------------] 100%
(1/1) checking package integrity [------------------------------------] 100%
(1/1) loading package files [------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------] 100%
(1/1) checking available disk space [------------------------------------] 100%
Failed to set locale.
==> root: 65
(1/1) reinstalling octopi [------------------------------------] 100%
(1/9) Arming ConditionNeedsUpdate...
(2/9) Refreshing PackageKit...
(3/9) Foreign/AUR package notification
xivlauncher 1:1.0.8-2
(4/9) Orphaned package notification...
dotnet-sdk 8.0.4.sdk104-1
gcab 1.6-1
gtkmm3 3.24.9-1
libsmbios 2.4.3-7
python-natsort 8.4.0-2
qt5-quickcontrols 5.15.13-1
qt6-webview 6.7.0-1
qtkeychain-qt5 0.14.3-1
(5/9) Checking for .pacnew and .pacsave files...
(6/9) Updating icon theme caches...
(7/9) Updating the desktop file MIME type cache...
==> root: 66
Now the fun part. I tried everything outlined in the other threads (and several other non-Garuda threads) where I tried running locale-gen, making sure that the right locales are uncommented (they are). I even went into locale.conf and set LC_ALL there, making sure to reboot after that.
The error I get is still the same.
What else is there to do?
Garuda-inxi output
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "en_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_TIME = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=4a466e50-60d7-4073-b8c9-b66e1af59a62 rw rootflags=subvol=@
quiet resume=UUID=3ffce4e8-7a4f-4b8c-bdbd-112904b36efa loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> uuid: <superuser required> BIOS: American
Megatrends LLC. v: B.G0 date: 07/26/2022
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3741 high: 4059 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4050 2: 3600
3: 3600 4: 3600 5: 3600 6: 3672 7: 3600 8: 4059 9: 4048 10: 4050 11: 3600
12: 3415 bogomips: 86408
Device-1: NVIDIA TU104 [GeForce RTX 2060] driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 29:00.0 chip-ID: 10de:1e89
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.1:4
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11")
s-diag: 868mm (34.19")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: Huawei ZQE-CBA
serial: <filter> built: 2022 res: 3440x1440 hz: 100 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.279 layers: 12 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.78 device-ID: 10de:1e89
surfaces: xcb,xlib
Device-1: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 29:00.1 chip-ID: 10de:10f8 class-ID: 0403
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 5-3.3.1:8 chip-ID: 1038:12ad class-ID: 0300
Device-5: fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3.3.3:10
chip-ID: 3142:a601 class-ID: 0300 serial: <filter>
Device-6: Creative Sound Blaster Play!
lanes: 1 mode: 1.1 bus-ID: 5-3.3.4:11 chip-ID: 041e:30d3 class-ID: 0300
API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.2:5
IF: enp43s0f3u3u2 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 2.73 TiB used: 1.55 TiB (56.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 49.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Extreme 55AE
size: 465.73 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 3000 scheme: GPT
model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1028 scheme: GPT
ID-1: / raw-size: 448.67 GiB size: 448.67 GiB (100.00%)
used: 222.24 GiB (49.5%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 448.67 GiB size: 448.67 GiB (100.00%)
ID-3: /var/log raw-size: 448.67 GiB size: 448.67 GiB (100.00%)
ID-4: /var/tmp raw-size: 448.67 GiB size: 448.67 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 3.1 GiB (19.9%)
ID-2: swap-2 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 78.0 C mobo: N/A gpu: nvidia temp: 53 C
Memory: total: 16 GiB available: 15.54 GiB used: 4.67 GiB (30.1%)
Processes: 518 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2054 libs: 560 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-05-03
Last full system update: 2024-05-20
