Hi. I've been using Garuda (KDE Dr460nized Edition specifically) for about five months, but I recently encountered a problem where my system boots directly into emergency mode, with no successful way to exit it.
inxi results:
Kernel: 5.15.10-zen1-1-zen x86_64
bits: 64
compiler: gcc
v: 11.1.0
Console: tty 1
Distro: Garuda Linux
Type: Desktop
System: ASUS
product: N/A
v: N/A
serial: N/A
Mobo: ASUSTeK
model: ROG STRIX B450-F GAMING
v: Rev 1.xx
UEFI: American Megatrends
v: 0901
date: 11/02/2020
Logical:
Message: No logical block device data found.
Device-1: luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a
type: LUKS
dm: dm-0
Message: No RAID data found.
Local storage:
total: <...>
used: <...>
ID-1: /dev/sda
vendor: <...>
model: <...>
speed: <...>
type: SSD
rev: 2B6Q
ID-2: /dev/sdb
vendor: <...>
model: <...>
speed: <...>
type: HDD
rpm: 5400
rev: 0A80
ID-1: /
used: <...>
fs: btrfs
dev: /dev/dm-0
mapped: luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a
ID-2: /boot/efi
used: <...>
fs: vfat
dev: /dev/sda1
ID-3: /home
used: <...>
fs: btrfs
dev: /dev/dm-0
ID-4: /var/log
used: <...>
fs: btrfs
dev: /dev/dm-0
ID-5: /var/tmp
used: <...>
fs: btrfs
dev: /dev/dm-0
Processes: 269
Uptime: <...>
wakeups: 0
Memory: <...>
used: <...>
Init: systemd
v: 249
Compilers:
gcc: 11.1.0
Packages:
pacman: 1793
Shell: Bash
v: 5.1.12
running-in: tty 1
inxi: 3.3.11
# COPIED BY HAND, skipped some information when obviously irrelevant '<...>'.
cat /etc/fstab results:
<file system> <mount point> <type> <options> <dump> <pass>
UUID=26CD-D220 /boot/efi vfat umask=0077 0 2
/dev/mapper/luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a / btrfs subvol=@,noatime,space_cache,autodefrag,compress=zstd,sdd 0 0
/dev/mapper/luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a /home btrfs subvol=@home,noatime,space_cache,autodefrag,compress=zstd,sdd 0 0
/dev/mapper/luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a /root btrfs subvol=@root,noatime,space_cache,autodefrag,compress=zstd,sdd 0 0
/dev/mapper/luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a /srv btrfs subvol=@srv,noatime,space_cache,autodefrag,compress=zstd,sdd 0 0
/dev/mapper/luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a /var/cache btrfs subvol=@cache,noatime,space_cache,autodefrag,compress=zstd,sdd 0 0
/dev/mapper/luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a /var/log btrfs subvol=@log,noatime,space_cache,autodefrag,compress=zstd,sdd 0 0
/dev/mapper/luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a /var/tmp btrfs subvol=@tmp,noatime,space_cache,autodefrag,compress=zstd,sdd 0 0
/dev/sdb1 /media/sdb1 btrfs defaults 0 0
blkid results:
/dev/sdb:
PTUUID="d7cb8ea8-d8b5-8041-82fe-de7617879617"
PTTYPE="gpt"
/dev/mapper/luks-44fb6bb4-6a73-45cb-b2ed-17958221c96a:
UUID="dd885b99-d260-4c4e-b7a2-c0a8ee949b9c"
UUID_SUB="25b702a7-c190-411a-ac34-5ace9149d7f7"
BLOCK_SIZE="4096"
TYPE="btrfs"
/dev/sda2:
UUID="44fb6bb4-6a73-45cb-b2ed-17958221c96a"
TYPE="crypto_LUKS"
PARTLABEL="root"
PARTUUID="f11758a6-c1af-e542-a42f-3602229f1d03"
/dev/sda1:
LABEL_FATBOOT="NO_LABEL"
LABEL="NO_LABEL"
UUID="26CD-D220"
BLOCK_SIZE="512"
TYPE="vfat"
PARTUUID="bcca63fc-64f8-da40-966d-544be7a76f8b"
/dev/zram0:
LABEL="zram0"
UUID="db5d24a0-57bc-4ba3-8311-c165e43cb770"
TYPE="swap"
Navigating through bash with cd , I can access all my files and everything seems to be fine on that front.
Using mount -a I got:
mount: /media/sdb1: special device /dev/sdb1 does not exist.
'/dev/sdb' is an empty disk that I was previously trying to install Gentoo on, which is probably where things got screwed up. I remember using chroot and mkdir /dev/sdb1/ but none of my installation attempts went past choosing the keymap before I shut everything off.
Using fsck I got:
fsck from util-linux 2.37.2
fsck.fat (2021-31-01)
There are differences between boot sector and its backup.
This is mostly harmless. Differences: (offset:original/backup)
65:01/00
1) Copy original to backup
2) Copy backup to original
3) No action
[123?q]? 3
Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
1) Remove dirty bit
2) No action
[12?q]? 2
/dev/sda1: 6 files, 1412/524252 clusters
I chose 'No action' both times because I didn't want to risk making things worse.
Compared to pictures I've seen online, my fstab doesn't look right, but that might have to do with the fact that I use encryption on my main disk.
My first instinct would be to remove /dev/sdb1 from fstab but I don't know how to do that as vim, nano and gedit (the text editors I see recommended online) don't seem to work, probably because they were never installed in the first place).
Any help would be appreciated.
