Hi there, any good progress here?
I just realized I didn’t send you an example of info.json from my timeshift, as I intended to do, for you to try and understand how to adjust it and use it.
This is the /run/timeshift/backup/timeshift-btrfs/snapshots/2021-08-24_19-38-55/info.json file created earlier when I updated my system:
"created" : "1629826735",
"sys-uuid" : "3c9fe0e6-78b5-41ec-8f40-7afc2f674b86",
"sys-distro" : "Garuda Soaring (Bateleur)",
"app-version" : "20.11.1",
"file_count" : "0",
"tags" : "ondemand",
"comments" : "{timeshift-autosnap} {created before upgrade}",
"live" : "false",
"type" : "btrfs",
"subvolumes" : {
"523",
"8425115648",
"167624704",
I think what is really important is the sys-uuid (of your disk) at the top and bottom according to your /etc/fstab. Below my example:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=C86F-B725 /boot/efi vfat umask=0077 0 2
UUID=3c9fe0e6-78b5-41ec-8f40-7afc2f674b86 / btrfs subvol=@,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 1
UUID=3c9fe0e6-78b5-41ec-8f40-7afc2f674b86 /home btrfs subvol=@home,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3c9fe0e6-78b5-41ec-8f40-7afc2f674b86 /root btrfs subvol=@root,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3c9fe0e6-78b5-41ec-8f40-7afc2f674b86 /srv btrfs subvol=@srv,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3c9fe0e6-78b5-41ec-8f40-7afc2f674b86 /var/cache btrfs subvol=@cache,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3c9fe0e6-78b5-41ec-8f40-7afc2f674b86 /var/log btrfs subvol=@log,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
UUID=3c9fe0e6-78b5-41ec-8f40-7afc2f674b86 /var/tmp btrfs subvol=@tmp,defaults,noatime,space_cache,autodefrag,compress=zstd,ssd 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
And the 523 (in my example), according to your
sudo btrfs subvolume list /
ID 257 gen 24462 top level 5 path @home
ID 258 gen 24444 top level 5 path @root
ID 259 gen 21956 top level 5 path @srv
ID 260 gen 24396 top level 5 path @cache
ID 261 gen 24463 top level 5 path @log
ID 262 gen 24430 top level 5 path @tmp
ID 439 gen 24462 top level 5 path @
ID 520 gen 24364 top level 5 path timeshift-btrfs/snapshots/2021-08-20_22-27-15/@
ID 521 gen 24420 top level 5 path timeshift-btrfs/snapshots/2021-08-20_22-29-30/@
ID 523 gen 24420 top level 5 path timeshift-btrfs/snapshots/2021-08-24_19-38-55/@
Pay also special attention to the /etc/fstab: in a recent thread the (different) issue was linked to a wrong / mount point there.
You also may want to delete some older timeshift folders before everything.
