p2501
6 December 2022 06:38
1
Okay something was updated on the 30th of Novembre that keeps my system from booting. At fist I thought it was the new nvidia drivers, so I masked them. That didn't help tho, so I haven't been updating since then. There was no error whatsoever displayed while running the update. Reverting to before the update let's me boot just fine but I'm stuck there and I don't like not being able to update so... halp plez?
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=66e5d40a-2370-44f3-b3b6-ddff5b2046cf rw rootflags=subvol=@
ipv6.disable=1 quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=e5f09ca4-2e13-4405-b97d-9a69816c4515 ipv6.disable=1
loglevel=3 ibt=off
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: bspwm
v: 0.9.10 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS PRO V2
serial: <superuser required> UEFI: American Megatrends LLC. v: F14e
date: 10/14/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3411 high: 3689 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3587 2: 3578
3: 3573 4: 3689 5: 3577 6: 3566 7: 2200 8: 3570 9: 3580 10: 3576 11: 2200
12: 3565 13: 3580 14: 3583 15: 3591 16: 3566 bogomips: 121369
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.0 chip-ID: 10de:2504
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-c4107
driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.00x22.52")
s-diag: 1166mm (45.9")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 140
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 1-6.3:6 chip-ID: 19f7:0015 pcie:
gen: 4 class-ID: 0300 serial: <filter> speed: 16 GT/s lanes: 16
bus-ID: 07:00.1 chip-ID: 10de:228e class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: RODE Microphones RĂDE NT-USB Mini type: USB
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Device-1: ASUSTek ASUS USB-BT500 type: USB driver: btusb v: 0.8
bus-ID: 1-10.2:9 chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-1: sink type: zfs status: ONLINE level: raidz1-0 raw: size: 49.1 TiB
free: 26.2 TiB allocated: 22.9 TiB zfs-fs: size: 32.58 TiB free: 17.3 TiB
Components: Online:
1: sda maj-min: 8:0 size: 16.37 TiB
2: sdb maj-min: 8:16 size: 16.37 TiB
3: sdc maj-min: 8:32 size: 16.37 TiB
Local Storage: total: raw: 50.93 TiB usable: 34.4 TiB
used: 15.88 TiB (46.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO XT
lanes: 4 type: SSD serial: <filter> rev: EIFM31.2 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MG09ACA18TE
size: 16.37 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0104 temp: 36 C scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MG09ACA18TE
type: HDD rpm: 7200 serial: <filter> rev: 0104 temp: 39 C scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MG09ACA18TE
type: HDD rpm: 7200 serial: <filter> rev: 0104 temp: 34 C scheme: GPT
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 616.05 GiB (34.3%)
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 616.05 GiB (34.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 69.05 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 62.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.6 C mobo: N/A gpu: nvidia temp: 46 C
Processes: 479 Uptime: 1h 7m wakeups: 0 Memory: 62.7 GiB
used: 14.19 GiB (22.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 2054
pm: pacman pkgs: 2033 libs: 393 tools: pamac,paru pm: flatpak pkgs: 21
Shell: fish v: 3.5.1 running-in: alacritty inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-02-13
Last full system update: 2022-11-29
Failed units: plymouth-start.service
How are you running update? The Pamac GUI? or what command in terminal?
p2501
6 December 2022 06:46
3
Happens both with yay and garuda-update
filo
6 December 2022 07:15
5
Have you checked what else was updated on that day? E.g.:
cat /var/log/pacman.log | grep '2022-11-30' | egrep 'installed|upgraded|removed'
You could also try switching to the linux-lts kernel, garuda-update and see how it goes.
Pay also attention to the pacnew files: for example recently there was an update to mkinitcpio.conf that might have brought issues if you simply replaced the file with the pacnew version instead of merging (you could have e.g. removed nvidia and related stuff from the modules array).
Finally, please use garuda-inxi instead of inxi -Faz in the first post (unless something got truncated).
p2501
6 December 2022 07:57
6
Thank you. I have corrected the first post. I have checked both the 29th and 30th of Novembre, I can't see anything that could produce this behaviour. I mean if the systemd update is safe..
[2022-11-30T05:37:32+0100] [ALPM] upgraded alsa-card-profiles (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:32+0100] [ALPM] upgraded systemd-libs (252.2-1 -> 252.2-2)
[2022-11-30T05:37:32+0100] [ALPM] upgraded cryptsetup (2.5.0-4 -> 2.6.0-1)
[2022-11-30T05:37:32+0100] [ALPM] upgraded libcamera (0.0.1-3 -> 0.0.2-1)
[2022-11-30T05:37:32+0100] [ALPM] upgraded glib2 (2.74.1-1 -> 2.74.2-1)
[2022-11-30T05:37:32+0100] [ALPM] upgraded pipewire (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:32+0100] [ALPM] upgraded pipewire-audio (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:32+0100] [ALPM] installed libwireplumber (0.4.12-2)
[2022-11-30T05:37:32+0100] [ALPM] upgraded wireplumber (0.4.12-1 -> 0.4.12-2)
[2022-11-30T05:37:32+0100] [ALPM] upgraded pipewire-jack (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:32+0100] [ALPM] upgraded systemd (252.2-1 -> 252.2-2)
[2022-11-30T05:37:32+0100] [ALPM] upgraded ffmpeg-git (5.2.r109252.g90c17a05aa-1 -> 5.2.r109266.gd34c1b389e-1)
[2022-11-30T05:37:32+0100] [ALPM] upgraded goverlay-git (0.9.r12.g1ab728d-1.1 -> 0.9.r15.g2e5abe1-1)
[2022-11-30T05:37:32+0100] [ALPM] upgraded gst-plugin-pipewire (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded haskell-megaparsec (9.2.2-10 -> 9.3.0-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded haskell-neat-interpolation (0.5.1.3-96 -> 0.5.1.3-97)
[2022-11-30T05:37:33+0100] [ALPM] upgraded lib32-glib2 (2.74.1-1 -> 2.74.2-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded netpbm (10.73.37-2 -> 10.73.41-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ostree (2022.6-4 -> 2022.7-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded pipewire-alsa (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded pipewire-pulse (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded pipewire-v4l2 (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded pipewire-x11-bell (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded pipewire-zeroconf (1:0.3.60-3 -> 1:0.3.61-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded plymouth-git (22.02.122.r117.gca15d30c-1 -> 22.02.122.r144.ga3f9824d-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded python-jsonschema (4.17.1-1 -> 4.17.2-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-base64 (0.1.1-3 -> 0.1.1-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-benchmark (0.2.0-3 -> 0.2.0-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-bigdecimal (3.1.2-3 -> 3.1.2-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-cgi (0.3.3-1 -> 0.3.6-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-csv (3.2.5-3 -> 3.2.5-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-date (3.2.2-3 -> 3.2.2-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-delegate (0.2.0-3 -> 0.2.0-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-did_you_mean (1.6.1-3 -> 1.6.1-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-digest (3.1.0-5 -> 3.1.0-6)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-drb (2.1.0-4 -> 2.1.0-5)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-english (0.7.1-3 -> 0.7.1-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-erb (2.2.3-4 -> 4.0.2-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-etc (1.3.0-5 -> 1.3.0-6)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-fcntl (1.0.1-3 -> 1.0.1-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-fiddle (1.1.0-3 -> 1.1.0-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-fileutils (1.6.0-3 -> 1.6.0-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-find (0.1.1-3 -> 0.1.1-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-forwardable (1.3.2-5 -> 1.3.2-6)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-getoptlong (0.1.1-2 -> 0.1.1-3)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-io-console (0.5.11-2 -> 0.5.11-3)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-io-nonblock (0.1.0-2 -> 0.1.0-3)
[2022-11-30T05:37:33+0100] [ALPM] upgraded ruby-abbrev (0.1.0-3 -> 0.1.0-4)
[2022-11-30T05:37:33+0100] [ALPM] upgraded stack (2.7.5-199 -> 2.7.5-200)
[2022-11-30T05:37:33+0100] [ALPM] upgraded systemd-sysvcompat (252.2-1 -> 252.2-2)
[2022-11-30T05:37:33+0100] [ALPM] upgraded wine-tkg-staging-fsync-git (7.22.r0.gd8881486-327 -> 7.22.r2.gd007ef33-327)
[2022-11-30T05:37:33+0100] [ALPM] upgraded xdg-desktop-portal-gtk (1.14.0-1 -> 1.14.1-1)
[2022-11-30T05:37:33+0100] [ALPM] upgraded xmlsec (1.2.36-2 -> 1.2.37-1)
[2022-11-29T05:41:50+0100] [ALPM] upgraded bind (9.18.8-2 -> 9.18.9-1)
[2022-11-29T05:41:50+0100] [ALPM] upgraded btrfs-progs (6.0.1-1 -> 6.0.2-1)
[2022-11-29T05:41:50+0100] [ALPM] upgraded ffmpeg-git (5.2.r109236.g2324b917fc-1 -> 5.2.r109252.g90c17a05aa-1)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-mono-traversable (1.0.15.3-95 -> 1.0.15.3-96)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-conduit (1.3.4.3-10 -> 1.3.4.3-11)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-conduit-extra (1.3.6-42 -> 1.3.6-43)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-monad-logger (0.3.37-28 -> 0.3.37-29)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-persistent (2.13.3.5-9 -> 2.13.3.5-10)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-casa-types (0.0.2-310 -> 0.0.2-311)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-http-conduit (2.3.8-258 -> 2.3.8-259)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-casa-client (0.0.1-529 -> 0.0.1-530)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-xml-conduit (1.9.1.1-156 -> 1.9.1.1-157)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-citeproc (0.8.0.2-9 -> 0.8.0.2-10)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-cryptonite-conduit (0.2.2-537 -> 0.2.2-538)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-githash (0.1.6.3-6 -> 0.1.6.3-7)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-libyaml (0.1.2-264 -> 0.1.2-265)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-yaml (0.11.8.0-72 -> 0.11.8.0-73)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-hpack (0.35.0-19 -> 0.35.0-20)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-http-download (0.2.0.0-524 -> 0.2.0.0-525)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-mustache (2.4.1-94 -> 2.4.1-95)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-optparse-simple (0.1.1.4-197 -> 0.1.1.4-198)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-persistent-sqlite (2.13.1.0-16 -> 2.13.1.0-17)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-rio-orphans (0.1.2.0-195 -> 0.1.2.0-196)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-tar-conduit (0.3.2-347 -> 0.3.2-348)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-pantry (0.5.7-33 -> 0.5.7-34)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-project-template (0.2.1.0-257 -> 0.2.1.0-258)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-wai-logger (2.4.0-159 -> 2.4.0-161)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-simple-sendfile (0.2.30-325 -> 0.2.30-326)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-warp (3.3.23-14 -> 3.3.23-15)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-wai-extra (3.1.13.0-8 -> 3.1.13.0-10)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-wai-app-static (3.1.7.4-95 -> 3.1.7.4-96)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-servant-server (0.19.2-5 -> 0.19.2-6)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-skylighting-core (0.13.1.1-5 -> 0.13.1.1-6)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-skylighting-format-ansi (0.1-19 -> 0.1-20)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-skylighting-format-blaze-html (0.1.1-15 -> 0.1.1-16)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-skylighting-format-latex (0.1-19 -> 0.1-20)
[2022-11-29T05:41:50+0100] [ALPM] upgraded haskell-skylighting (0.13.1.1-5 -> 0.13.1.1-6)
[2022-11-29T05:41:50+0100] [ALPM] upgraded luajit (2.1.0.beta3.r455.g46aa45dc-1 -> 2.1.0.beta3.r457.g637721d0-1)
[2022-11-29T05:41:50+0100] [ALPM] upgraded pandoc (2.19.2-32 -> 2.19.2-33)
[2022-11-29T05:41:50+0100] [ALPM] upgraded pandoc-crossref (0.3.13.0-43 -> 0.3.13.0-44)
[2022-11-29T05:41:50+0100] [ALPM] upgraded python-zipp (3.10.0-1 -> 3.11.0-1)
[2022-11-29T05:41:50+0100] [ALPM] upgraded ruby-bundler (2.3.23-1 -> 2.3.25-1)
[2022-11-29T05:41:50+0100] [ALPM] upgraded sed (4.8-1 -> 4.9-1)
[2022-11-29T05:41:51+0100] [ALPM] upgraded stack (2.7.5-198 -> 2.7.5-199)
[2022-11-29T05:42:08+0100] [ALPM] upgraded tela-circle-icon-theme-git (2022.11.06.r11.g6cd76b31-1 -> 2022.11.06.r26.g1aac9cf5-1)
[2022-11-29T05:42:08+0100] [ALPM] upgraded wayland-protocols (1.28-1 -> 1.30-1)
[2022-11-29T05:42:08+0100] [ALPM] upgraded xmonad (0.17.1-51 -> 0.17.1-52)
[2022-11-29T05:42:09+0100] [ALPM] upgraded xmonad-contrib (0.17.1-50 -> 0.17.1-51)
[2022-11-29T05:42:09+0100] [ALPM] upgraded xmonad-extras (0.17.0-83 -> 0.17.0-84)
Edit: I have just checked mkinitcpio.conf. I haven't merged the pacnew, could that be the root of the problem?
filo
6 December 2022 09:06
7
I donât think so. If I remember correctly, the changes were in using () instead of ââ in thr HOOKS, but both should be supported. But there might be something else, and it is always important to take care of those merges for system administration.
I think you should do it and then give a:
sudo mkinitcpio -P
p2501
6 December 2022 09:40
8
I have just done that, thank you. I'll run an update later, can't rn because of a running scrub.
While I'm at it, can you guess at why plymouth fails? Maybe that's part of the problem?
Ă plymouth-start.service - Show Plymouth Boot Screen
Loaded: loaded (/usr/lib/systemd/system/plymouth-start.service; static)
Active: failed (Result: core-dump) since Tue 2022-12-06 07:41:15 CET; 2h 10min ago
Process: 455 ExecStart=/usr/bin/plymouthd --mode=boot --pid-file=/run/plymouth/pid --attach-to-session (code=exited, status=0/SUCCESS)
Process: 492 ExecStartPost=/usr/bin/plymouth show-splash (code=exited, status=2)
Main PID: 489 (code=dumped, signal=SEGV)
CPU: 7ms
Dez 06 07:41:14 arha systemd[1]: Starting Show Plymouth Boot Screen...
Dez 06 07:41:15 arha plymouth[492]: error: unexpectedly disconnected from boot status daemon
Dez 06 07:41:15 arha systemd[1]: plymouth-start.service: Main process exited, code=dumped, status=11/SEGV
Dez 06 07:41:15 arha systemd[1]: plymouth-start.service: Failed with result 'core-dump'.
Dez 06 07:41:15 arha systemd[1]: Failed to start Show Plymouth Boot Screen.
filo
6 December 2022 09:48
9
Recently there was a bug in plymouth-git, already fixed if I remember correctly, so the problem might disappear with the update.
In any case, installing plymouth (which will ask to remove plymouth-git) should remove the problem.
But in principle it would be wise to revert to plymouth-git as soon as possible, since the plymouth package is not updated very often, so all the recent fixes are not available there.
p2501
6 December 2022 09:57
10
I'm already running plymouth-git, so fingers crossed the update will fix that error too. I'll report afterwards.
p2501
7 December 2022 05:34
11
Okay, that didn't work. I'm still stuck at loading kernel, and I can't even get to another console. Again, no errors while running the update.
[2022-12-07T06:12:05+0100] [ALPM] installed adwaita-cursors (43-2)
[2022-12-07T06:12:05+0100] [ALPM] upgraded tzdata (2022f-1 -> 2022g-1)
[2022-12-07T06:12:05+0100] [ALPM] upgraded glib2 (2.74.1-1 -> 2.74.3-1)
[2022-12-07T06:12:05+0100] [ALPM] upgraded xz (5.2.8-1 -> 5.2.9-1)
[2022-12-07T06:12:05+0100] [ALPM] upgraded adwaita-icon-theme (43-1 -> 43-2)
[2022-12-07T06:12:05+0100] [ALPM] upgraded alsa-card-profiles (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:05+0100] [ALPM] upgraded systemd-libs (252.2-1 -> 252.2-3)
[2022-12-07T06:12:05+0100] [ALPM] upgraded libelf (0.187-2 -> 0.188-1)
[2022-12-07T06:12:05+0100] [ALPM] upgraded binutils (2.39-3 -> 2.39-4)
[2022-12-07T06:12:06+0100] [ALPM] upgraded cmake (3.25.0-1 -> 3.25.1-1)
[2022-12-07T06:12:06+0100] [ALPM] upgraded cryptsetup (2.5.0-4 -> 2.6.0-1)
[2022-12-07T06:12:06+0100] [ALPM] upgraded libxcomposite (0.4.5-4 -> 0.4.6-1)
[2022-12-07T06:12:06+0100] [ALPM] upgraded sqlite (3.40.0-1 -> 3.40.0-2)
[2022-12-07T06:12:06+0100] [ALPM] installed default-cursors (1-1)
[2022-12-07T06:12:06+0100] [ALPM] upgraded wayland (1.21.0-1 -> 1.21.0-2)
[2022-12-07T06:12:06+0100] [ALPM] upgraded libnftnl (1.2.3-1 -> 1.2.4-1)
[2022-12-07T06:12:06+0100] [ALPM] upgraded systemd (252.2-1 -> 252.2-3)
[2022-12-07T06:12:06+0100] [ALPM] upgraded xorg-xrandr (1.5.1-2 -> 1.5.2-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded nvidia-utils (520.56.06-2 -> 525.60.11-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded libxdamage (1.1.5-5 -> 1.1.6-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded xorg-xprop (1.2.5-1 -> 1.2.6-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded libice (1.0.10-4 -> 1.1.0-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded xorg-xset (1.2.4-3 -> 1.2.5-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded qt5-declarative (5.15.7+kde+r23-1 -> 5.15.7+kde+r24-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded deepin-qt5platform-plugins (5.0.68-1 -> 5.0.70-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded libxv (1.0.11-5 -> 1.0.12-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded deepin-qt5integration (5.5.24-3 -> 5.5.25-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded dnsmasq (2.87-3 -> 2.88-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded libxcursor (1.2.1-2 -> 1.2.1-3)
[2022-12-07T06:12:07+0100] [ALPM] upgraded sdl2 (2.26.0-1 -> 2.26.1-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded libcamera (0.0.1-3 -> 0.0.2-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded pipewire (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded pipewire-audio (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:07+0100] [ALPM] installed libwireplumber (0.4.12-2)
[2022-12-07T06:12:07+0100] [ALPM] upgraded wireplumber (0.4.12-1 -> 0.4.12-2)
[2022-12-07T06:12:07+0100] [ALPM] upgraded pipewire-jack (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded libass (0.16.0-1 -> 0.17.0-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded libbluray (1.3.3-1 -> 1.3.4-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded rav1e (0.5.1-2 -> 0.6.1-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded svt-av1 (1.3.0-1 -> 1.4.0-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded ffmpeg-git (5.2.r109252.g90c17a05aa-1 -> 5.2.r109369.gcb9ab38c52-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded faudio (22.11-1 -> 22.12-1)
[2022-12-07T06:12:07+0100] [ALPM] warning: /etc/pacman.d/mirrorlist installed as /etc/pacman.d/mirrorlist.pacnew
[2022-12-07T06:12:07+0100] [ALPM] upgraded pacman-mirrorlist (20221016-1 -> 20221204-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded mpfr (4.1.1-1 -> 4.1.1.p1-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded garuda-bash-config (1.0.2-1 -> 1.0.3-1)
[2022-12-07T06:12:07+0100] [ALPM] upgraded garuda-common-settings (2.6.9-1 -> 2.6.10-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded libxnvctrl (520.56.06-1 -> 525.60.11-2)
[2022-12-07T06:12:08+0100] [ALPM] upgraded tracker3 (3.4.1-1 -> 3.4.2-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded nvidia-settings (520.56.06-1 -> 525.60.11-2)
[2022-12-07T06:12:08+0100] [ALPM] upgraded opencl-nvidia (520.56.06-2 -> 525.60.11-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded lib32-libxdmcp (1.1.3-2 -> 1.1.4-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded lib32-xz (5.2.8-2 -> 5.2.9-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded lib32-libelf (0.187-1 -> 0.188-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded lib32-nvidia-utils (520.56.06-1 -> 525.60.11-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded lib32-opencl-nvidia (520.56.06-1 -> 525.60.11-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded nvidia-dkms (520.56.06-2 -> 525.60.11-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded python-cairo (1.22.0-1 -> 1.23.0-2)
[2022-12-07T06:12:08+0100] [ALPM] upgraded python-chardet (5.0.0-1 -> 5.1.0-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded garuda-nvidia-config (1:r63.2f652e8-1 -> 1:r63.2f652e8-2)
[2022-12-07T06:12:08+0100] [ALPM] upgraded gcc11-libs (11.3.0-4 -> 11.3.0-5)
[2022-12-07T06:12:08+0100] [ALPM] upgraded gcc11 (11.3.0-4 -> 11.3.0-5)
[2022-12-07T06:12:08+0100] [ALPM] upgraded goverlay-git (0.9.r12.g1ab728d-1.1 -> 0.9.r18.gd0c9768-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded netpbm (10.73.37-2 -> 10.73.41-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded graphviz (7.0.3-1 -> 7.0.4-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded gst-plugin-pipewire (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-lift-type (0.1.1.0-1 -> 0.1.1.1-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-persistent (2.13.3.5-10 -> 2.13.3.5-11)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-casa-types (0.0.2-311 -> 0.0.2-312)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-casa-client (0.0.1-530 -> 0.0.1-531)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-haddock-library (1.10.0-183 -> 1.10.0-184)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-rio-prettyprint (0.1.3.0-2 -> 0.1.4.0-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-http-download (0.2.0.0-525 -> 0.2.0.0-526)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-megaparsec (9.2.2-10 -> 9.3.0-1)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-mustache (2.4.1-95 -> 2.4.1-96)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-neat-interpolation (0.5.1.3-96 -> 0.5.1.3-98)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-persistent-sqlite (2.13.1.0-17 -> 2.13.1.0-18)
[2022-12-07T06:12:08+0100] [ALPM] upgraded haskell-pantry (0.5.7-34 -> 0.5.7-36)
[2022-12-07T06:12:08+0100] [ALPM] upgraded imagemagick (7.1.0.52-1 -> 7.1.0.53-1)
[2022-12-07T06:12:09+0100] [ALPM] upgraded kvantum (1.0.6-1 -> 1.0.7-1)
[2022-12-07T06:12:09+0100] [ALPM] upgraded lib32-faudio (22.11-1 -> 22.12-1)
[2022-12-07T06:12:09+0100] [ALPM] upgraded lib32-glib2 (2.74.1-1 -> 2.74.3-1)
[2022-12-07T06:12:09+0100] [ALPM] upgraded lib32-libsm (1.2.3-1 -> 1.2.3-2)
[2022-12-07T06:12:09+0100] [ALPM] upgraded liblouis (3.23.0-1 -> 3.24.0-1)
[2022-12-07T06:12:09+0100] [ALPM] upgraded libnewt (0.52.22-1 -> 0.52.23-1)
[2022-12-07T06:12:09+0100] [ALPM] upgraded libnm (1.40.4-1 -> 1.40.6-1)
[2022-12-07T06:12:09+0100] [ALPM] upgraded poppler (22.11.0-1 -> 22.12.0-1)
[2022-12-07T06:12:09+0100] [ALPM] upgraded xmlsec (1.2.36-2 -> 1.2.37-1)
[2022-12-07T06:12:10+0100] [ALPM] upgraded libreoffice-fresh (7.4.3-1 -> 7.4.3-2)
[2022-12-07T06:12:10+0100] [ALPM] upgraded librewolf (107.0-1 -> 107.0.1-1)
[2022-12-07T06:12:10+0100] [ALPM] upgraded libteam (1.31-5 -> 1.31-7)
[2022-12-07T06:12:10+0100] [ALPM] upgraded libxres (1.2.1-1 -> 1.2.2-1)
[2022-12-07T06:12:10+0100] [ALPM] upgraded linux-zen (6.0.10.zen2-1 -> 6.0.11.zen1-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded linux-zen-headers (6.0.10.zen2-1 -> 6.0.11.zen1-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded webkit2gtk (2.38.2-1 -> 2.38.2-2)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-trove-classifiers (2022.10.19-1 -> 2022.12.1-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-setuptools (1:65.6.2-1 -> 1:65.6.3-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded lutris (0.5.11-2 -> 0.5.12-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded mhwd-nvidia (520.56.06-1 -> 525.60.11-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded mhwd-db-garuda-git (1:r63.2f652e8-1 -> 1:r63.2f652e8-2)
[2022-12-07T06:12:12+0100] [ALPM] upgraded mujs (1.3.1-1 -> 1.3.2-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded rubberband (3.1.1-1 -> 3.1.2-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded vapoursynth-git (R60.18.g2ee76bc5-1 -> R61.2.g4c8da22d-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded mpv-full-git (0.34.1.r566.gc5b258b490-1 -> 0.35.0.r31.g25b66256d7-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded networkmanager (1.40.4-1 -> 1.40.6-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded nm-cloud-setup (1.40.4-1 -> 1.40.6-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ostree (2022.6-4 -> 2022.7-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded pandoc (2.19.2-33 -> 2.19.2-34)
[2022-12-07T06:12:12+0100] [ALPM] upgraded pandoc-crossref (0.3.13.0-44 -> 0.3.13.0-45)
[2022-12-07T06:12:12+0100] [ALPM] upgraded perl-alien-build (2.72-1 -> 2.73-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded pipewire-alsa (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded pipewire-pulse (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded pipewire-v4l2 (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded pipewire-x11-bell (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded pipewire-zeroconf (1:0.3.60-3 -> 1:0.3.61-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded plymouth-git (22.02.122.r117.gca15d30c-1 -> 22.02.122.r154.g96d050ce-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded poppler-glib (22.11.0-1 -> 22.12.0-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded poppler-qt5 (22.11.0-1 -> 22.12.0-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded protobuf (21.9-1 -> 21.10-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-cryptography (38.0.3-1 -> 38.0.4-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-installer (0.5.1-2 -> 0.6.0-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-jsonschema (4.17.1-1 -> 4.17.3-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-orjson (3.8.2-1 -> 3.8.3-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-protobuf (21.9-1 -> 21.10-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-texttable (1.6.5-1 -> 1.6.7-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded python-wxpython (1:4.1.1-3 -> 1:4.2.0-3)
[2022-12-07T06:12:12+0100] [ALPM] upgraded qt5-quickcontrols2 (5.15.7+kde+r6-1 -> 5.15.7+kde+r7-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-base64 (0.1.1-3 -> 0.1.1-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-benchmark (0.2.0-3 -> 0.2.0-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-bigdecimal (3.1.2-3 -> 3.1.2-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-cgi (0.3.3-1 -> 0.3.6-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-csv (3.2.5-3 -> 3.2.5-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-date (3.2.2-3 -> 3.2.2-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-delegate (0.2.0-3 -> 0.2.0-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-did_you_mean (1.6.1-3 -> 1.6.1-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-digest (3.1.0-5 -> 3.1.0-6)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-drb (2.1.0-4 -> 2.1.0-5)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-english (0.7.1-3 -> 0.7.1-5)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-erb (2.2.3-4 -> 4.0.2-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-etc (1.3.0-5 -> 1.3.0-6)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-fcntl (1.0.1-3 -> 1.0.1-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-fiddle (1.1.0-3 -> 1.1.0-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-fileutils (1.6.0-3 -> 1.6.0-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-find (0.1.1-3 -> 0.1.1-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-forwardable (1.3.2-5 -> 1.3.2-6)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-getoptlong (0.1.1-2 -> 0.1.1-3)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-io-console (0.5.11-2 -> 0.5.11-3)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-io-nonblock (0.1.0-2 -> 0.1.0-3)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-io-wait (0.2.3-3 -> 0.2.3-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-ipaddr (1.2.4-2 -> 1.2.4-3)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-logger (1.5.1-2 -> 1.5.1-3)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-mutex_m (0.1.1-2 -> 0.1.1-3)
[2022-12-07T06:12:12+0100] [ALPM] upgraded ruby-abbrev (0.1.0-3 -> 0.1.0-4)
[2022-12-07T06:12:12+0100] [ALPM] upgraded stack (2.7.5-199 -> 2.7.5-203)
[2022-12-07T06:12:12+0100] [ALPM] upgraded syncthingtray (1.3.0-5 -> 1.3.1-1)
[2022-12-07T06:12:12+0100] [ALPM] upgraded systemd-sysvcompat (252.2-1 -> 252.2-3)
[2022-12-07T06:12:12+0100] [ALPM] upgraded telegram-desktop (4.3.4-1 -> 4.4.0-1)
[2022-12-07T06:12:13+0100] [ALPM] upgraded thunderbird (102.5.0-1 -> 102.5.1-1)
[2022-12-07T06:12:13+0100] [ALPM] upgraded ungoogled-chromium (107.0.5304.121-1 -> 108.0.5359.94-1)
[2022-12-07T06:12:13+0100] [ALPM] upgraded usbutils (015-1 -> 015-2)
[2022-12-07T06:12:13+0100] [ALPM] upgraded vlc (3.0.17.4-11 -> 3.0.18-4)
[2022-12-07T06:12:13+0100] [ALPM] upgraded vte-common (0.70.1-1 -> 0.70.2-1)
[2022-12-07T06:12:13+0100] [ALPM] upgraded vte3 (0.70.1-1 -> 0.70.2-1)
[2022-12-07T06:12:13+0100] [ALPM] upgraded wavpack (5.5.0-1 -> 5.6.0-1)
[2022-12-07T06:12:13+0100] [ALPM] upgraded wayland-protocols (1.30-1 -> 1.31-1)
[2022-12-07T06:12:13+0100] [ALPM] upgraded webkit2gtk-4.1 (2.38.2-1 -> 2.38.2-2)
[2022-12-07T06:12:14+0100] [ALPM] upgraded whitesur-gtk-theme-git (2022.10.27.r24.ga2fed1a-1 -> 2022.10.27.r27.ge0332f2-1)
[2022-12-07T06:12:14+0100] [ALPM] upgraded wine-tkg-staging-fsync-git (7.22.r0.gd8881486-327 -> 7.22.r5.gcc4bced6-327)
[2022-12-07T06:12:14+0100] [ALPM] upgraded xapp (2.4.1-1 -> 2.4.2-1)
[2022-12-07T06:12:14+0100] [ALPM] upgraded xdg-desktop-portal-gtk (1.14.0-1 -> 1.14.1-1)
[2022-12-07T06:12:14+0100] [ALPM] upgraded xmonad (0.17.1-52 -> 0.17.1-53)
[2022-12-07T06:12:14+0100] [ALPM] upgraded xmonad-contrib (0.17.1-51 -> 0.17.1-52)
[2022-12-07T06:12:14+0100] [ALPM] upgraded xmonad-extras (0.17.0-84 -> 0.17.0-85)
[2022-12-07T06:12:14+0100] [ALPM] upgraded xorg-xinit (1.4.1-3 -> 1.4.2-1)
[2022-12-07T06:14:38+0100] [ALPM] installed gn (0.2072.1c4151ff-1)
[2022-12-07T06:15:10+0100] [ALPM] upgraded snapd (2.57.5-1 -> 2.58-1)
[2022-12-07T06:15:19+0100] [ALPM] upgraded libpdfium-nojs (5249.r4.c5f61025a7-1 -> 5359.r0.9d2c662f55-2)
filo
7 December 2022 06:23
12
There are only two ideas that come to my mind.
One would be to install and try the lts kernel:
sudo pacman -Syu linux-lts linux-lts-headers
The other is this tutorial, after updating.
Youâll have to try to boot to a tty from the grub or chroot.
While there are many potential reasons why your installation doesnât boot to a desktop, the primary reason is that the graphics drivers havenât loaded correctly so your login/display manager (DM) doesnât start. This is why you get a âblack screenâ or stuck at an
[ OK ] Started some service
message.
The normal reason for this is that you have the incorrect driver version for the kernel. This can happens when the mirror you are updating from is not fully synchronised, or times out, and so yâŚ
p2501
7 December 2022 11:01
13
So. Iâve tried installing the lts kernel, tried going back to 6.0.11 (both installs run through just fine), but now Iâm stuck with both of them at setfont KDFONT blah.
Canât restore any former working snapshot, because all this back in forth since the 29th has pushed that one too far back, so my system is dead now.
filo
7 December 2022 11:14
14
What is the exact message?
I remember this hint recently.
Is NetworkManager-wait-online.service enabled?
Can you post your /etc/fstab?
This is almost certainly unrelated, but you can resolve this by adding " setfont" to the BINARIES section of /etc/mkinitcpio.conf:
BINARIES=(setfont)
Then rebuild it.
sudo mkinitcpio -P
You will have to chroot from a live USB to try that, or other things.
Maybe try to search for the exact message.
p2501
7 December 2022 12:48
15
Iâve been booting from live cd anyway, since thatâs now the only way.
The error was
setfont: KDFONTOP: Function not implemented
which is solved now, thanks to what you linked there. Now Iâm stuck again at Loading initial ramdisk. Changed between zen and lts kernels, each install/uninstall goes through without a hitch.
p2501
7 December 2022 15:04
16
Okay, I read through the last link you posted. I thought to myself, well if I could at least get an error message or see exactly where the boot fails, it'd be a step in the right direction, right? So I took out quiet, splash, and for good measure ibt=off, since this is an AMD machine anyway. Rewrote grub, updated it. And well, now it boots with both kernel and no error whatsoever, so I guess I can conclude that something with grub was borked, something that did not throw an error, and just updating it fixed it all?
system
Closed
9 December 2022 15:04
17
