Stuck at 640x480 resolution
I’ve just installed garuda and am met with an issue: 640x480 screen resolution, which I can’t change.
The login screen displays at 1080p.
I have scaled the resolution back to 50% which enables me to navigate the windows.
root=UUID=c993c2e3-8331-41a3-bd0e-acb1b062c392 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450 AORUS M serial: N/A
uuid: 032e02b4-0499-0541-2c06-250700080009 BIOS: American Megatrends LLC.
v: F62 date: 01/24/2022
Info: model: AMD Ryzen 5 5500 socket: AM4 bits: 64 type: MT MCP arch: Zen 3
gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1462 high: 3670 min/max: 400/4267 base/boost: 3600/4250
scaling: driver: amd-pstate-epp governor: performance volts: 1.4 V
ext-clock: 100 MHz cores: 1: 3540 2: 400 3: 400 4: 3567 5: 3568 6: 400
7: 400 8: 400 9: 3670 10: 400 11: 400 12: 400 bogomips: 86238
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia
v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c03
Display: server: X.Org v: 23.2.2 with: Xwayland v: 23.2.4
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1280x960 s-dpi: 96 s-size: 338x254mm (13.31x10.00")
s-diag: 423mm (16.65")
Monitor-1: Unknown-1 res: 1280x960 hz: 60 dpi: 192
size: 169x127mm (6.65x5") modes: 640x480
API: EGL v: 1.5 platforms: device: 1 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast x11: drv: swrast inactive: wayland,device-0
API: OpenGL v: 4.5 vendor: mesa v: 24.0.1-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 15.12 GiB unified: yes
Device-1: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f1
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.26 TiB used: 18.47 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA1000M8480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: E8FK11.R temp: 37.9 C
scheme: MBR
SMART: yes health: PASSED on: 1y 283d 22h cycles: 2,857
read-units: 77,697,771 [39.7 TB] written-units: 38,572,621 [19.7 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD120
family: P300 (CMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: ACF0 temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 342d 22h cycles: 1783
ID-1: / raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
used: 18.47 GiB (4.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-2: /home raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
maj-min: 259:1
ID-3: /var/log raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
maj-min: 259:1
ID-4: /var/tmp raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
maj-min: 259:1
ID-1: swap-1 type: zram size: 15.49 GiB used: 1.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 54.9 C mobo: N/A
Memory: total: 16 GiB available: 15.49 GiB used: 4.51 GiB (29.1%)
Processes: 294 Power: uptime: 35m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1799 libs: 537 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date:     2024-02-26
Last full system update: 2024-02-26 ↻
Failed units:~~~
At the login screen can you try X11 and not wayland?
I’ve only noticed the prompt for the username and password, not sure how I would go about that.
It’s in the lower left hand corner of the login screen I think
All right, one restart through, and I’ve switched to x11 and I’m getting a 1080p resolution.
Many thanks!
