Stuck after login Hyperland
Hey iam trying to setup garuda hyperland after using hyperland on mokka for an year,
now iam stuck after login on the hyperland iso, tried with mokka isso everythink works
i tried to disable the local script in hyperland.conf and set the monitor manuel(not shure if done right) also tried with an 1080p monitor
i think its a problem with the conf if i start hyprstart in tty4 it freeze after loading the hyperland.conf
nvidia rtx 5070ti and some ryzen cpu 97
  Kernel: 6.16.8-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=garuda root=miso:LABEL=GARUDA_HYPRLAND_BROADWING quiet systemd.show_status=1
    checksum=y driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
    rdinit=/vtoy/vtoy
  Console: pty pts/0 DM: SDDM Distro: Garuda base: Arch Linux
  Type: Desktop Mobo: ASRock model: B850I Lightning WiFi serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 3.30 date: 06/16/2025
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MCP arch: Zen 5 gen: 5 level: v4 note: check
    built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26) model-id: 0x44 (68) stepping: 0
    microcode: 0xB404032
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache: L1: 640 KiB
    desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 3624 min/max: 603/5272 boost: enabled scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 3624 2: 3624 3: 3624 4: 3624 5: 3624 6: 3624 7: 3624 8: 3624
    bogomips: 75054
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  Device-1: NVIDIA GB203 [GeForce RTX 5070 Ti] vendor: Palit Microsystems driver: nvidia
    v: 580.82.09 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-08) arch: Lovelace code: AD1xx process: TSMC n4 (5nm)
    built: 2022+ pcie: gen: 5 speed: 32 GT/s lanes: 16 ports: active: DP-3
    empty: DP-4,DP-5,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:2c05 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics] vendor: ASRock
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2,
    Writeback-1 bus-ID: 0d:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 42.0 C
  Display: unspecified server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: radeonsi
    gpu: nv_platform,nvidia,nvidia-nvswitch tty: 99x33
  Monitor-1: DP-3 model: AOC AG456UCZD serial: <filter> built: 2024 res: 3440x1440 dpi: 84
    gamma: 1.2 size: 1043x436mm (41.06x17.17") diag: 1130mm (44.5") modes: max: 3440x1440
    min: 640x480
  API: OpenGL Message: GL data unavailable in console, glxinfo missing.
  Info: Tools: gpu: nvidia-smi wl: kanshi, wdisplays, wlr-randr x11: xprop
  Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:22e9 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio [Rembrandt/Strix]
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: ASRock
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.6
  API: ALSA v: k6.16.8-zen3-1-zen status: kernel-api tools: alsactl,alsamixer,amixer
  Server-2: PipeWire v: 1.4.8 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter driver: mt7921e
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 14c3:0616 class-ID: 0280
  Device-2: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0 chip-ID: 10ec:3000 class-ID: 0200
  IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-12:3 chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4 lmp-v: 13 status:
    discoverable: no pairing: no class-ID: 104
  Local Storage: total: 1.48 TiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P310SSD8 size: 931.51 GiB
    fw-rev: V8CR000 temp: 47.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Fanxiang model: S660 500GB size: 465.76 GiB
    fw-rev: SN14728 temp: 39.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Patriot model: N/A size: 115.5 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
  ID-1: swap-1 type: zram size: 30.43 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
  System Temperatures: cpu: 48.8 C mobo: 46.0 C gpu: amdgpu temp: 46.5 C
  Memory: total: 32 GiB note: est. available: 30.43 GiB used: 3.63 GiB (11.9%)
  Processes: 234 Power: uptime: 10m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.14 GiB
    Init: systemd v: 258 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1226 libs: 322 tools: pacseek,paru Compilers: gcc: 15.2.1
    Shell: Bash v: 5.3.3 running-in: pty pts/0 (SSH) inxi: 3.3.39
Garuda (2.11.1-1):
  System install date:     2025-10-18
  Garuda release:          251002
  Last full system update: 2025-10-18 ↻
  Is partially upgraded:   Yes
  Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
21/24 checks run in 0.67 seconds ⌛
Powered by garuda-health 🦅
--- CRITICAL ---
 - System is partially upgraded (fix available)
--- HIGH ---
 - Snapper snapshots directory is missing (fix available)
--- LOW ---
 - Failed systemd services found: snapper-cleanup.service
--- INFO ---
Did you run in terminal
garuda-health --fix
Just start from fresh install, there is one line in the config file for monitor settings.
thanks for your answer, yeah tried it now “1 of 3 errors got solved” but not really after run health --fix again it still trys to fix the same problem, still black screen after login on other tty, on cli one freeze after run hyperstart, output
i will try to run upgrade and hyprstart, after that looking more into the errors from health…
Health:
[garuda@garuda-hyprland ~]$ sudo garuda-health --fix --debug
Check took 0.00 seconds
Check returned a result with severity NO_ISSUE, which is not printable.
Check took 0.02 seconds
Check returned a result with severity ERROR, which is not printable.
Check took 0.04 seconds
Check took 0.19 seconds
Check took 0.07 seconds
Check took 0.09 seconds
Check took 0.01 seconds
22/24 checks run in 0.48 seconds ⌛
--- HIGH ---
--- INFO ---
--- Applying Fixes ---
Fixing "Snapper snapshots directory is missing":
The following command will be executed:
  garuda-update remote reset-snapper
Continue? [y/N]: y
You are still booted into a snapshot.
Snapper configuration reset to default successfully.
--- Re-running checks after applying fixes ---
Check took 0.06 seconds
Check took 0.08 seconds
22/24 checks run in 0.26 seconds ⌛
--- HIGH ---
--- INFO ---
but if i run it again, same problem…
[garuda@garuda-hyprland ~]$ garuda-inxi
    rdinit=/vtoy/vtoy
  Speed (MHz): avg: 3623 min/max: 603/5272 boost: enabled scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 3623 2: 3623 3: 3623 4: 3623 5: 3623 6: 3623 7: 3623 8: 3623
    bogomips: 75054
    built: 2022+ pcie: gen: 5 speed: 32 GT/s lanes: 16 ports: active: HDMI-A-3
    empty: DP-3,DP-4,DP-5 bus-ID: 01:00.0 chip-ID: 10de:2c05 class-ID: 0300
  Monitor-1: HDMI-A-3 model: Acer R231 serial: <filter> built: 2016 res: 1920x1080 dpi: 96
    gamma: 1.2 size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes: max: 1920x1080
    min: 624x464
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3 lmp-v: 12 status:
    fw-rev: V8CR000 temp: 42.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Fanxiang model: S660 500GB size: 465.76 GiB
  System Temperatures: cpu: 48.4 C mobo: 40.5 C gpu: amdgpu temp: 41.0 C
  Memory: total: 32 GiB note: est. available: 30.43 GiB used: 3.59 GiB (11.8%)
  Processes: 250 Power: uptime: 5m states: freeze,mem,disk suspend: deep avail: s2idle
Garuda (2.11.1-1):
21/24 checks run in 0.36 seconds ⌛
--- HIGH ---
--- INFO ---
after update and creating /.snapshots folder
22/24 checks run in 0.43 seconds ⌛
--- LOW ---
 - Failed systemd services found: grub-btrfs-snapper.service, snapper-cleanup.service
--- INFO ---
No issues with available fixes were found.
The output from garuda-health is irrelevant in a live environment.
You don’t mention anything about the login screen, but I assume that the black screen appears after the login screen. Have you tried the different desktop sessions in the login screen?
Have you tried booting the live.iso with open source drivers (Grub menu)?
If that doesn’t help, connect the monitor to the HDMI port on your motherboard to use the AMD iGPU, boot the live.iso again with open source drivers, and check if the issue persists.
