I am a bit new to all this but my brain is absolutely broken trying to fix this. Started out with just a straight install of Garuda, installed Street Fighter 6, driver issues. Went the Hardware, installed proprietary drivers for Nvidia, run again it’s fine but in windowed mode.
Went to put it in Full Screen, it absolutely freaks out flickering. So I cut my losses to just make sure it’s working proper otherwise. Game runs fine, Multiplayer runs slow. Find " sudo sysctl kernel.split_lock_mitigate=0" on Reddit, run it, Multiplayer fixed. Full Screen or Borderless windowed still freaking out.
So I swap over to x11 like I saw in another thread. Try Full Screen, works fine. Go to play the game, little sluggish. Go to play Multiplayer, back to chugging really bad. Try the above solution, open up and the game is in window mode again, running slow as death, try to put it into borderless windows and my PC locks up.
Nothing but trouble trying to get this one particular game to run, which is funny because it’s one of the few that doesn’t need to run alongside Proton (which i’ve tried both running in steam with proton and without). Absolutely at wits end, because outside of Street Fighter 6 I’ve tried a couple indie games that worked fine and Lies of P runs smooth enough without any tinkering. It feels the more I try to do the more I’m ruining everything else.
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f61de75f-eb41-4651-b9d2-02348c872bd4 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Mobo: ASUSTeK model: PRIME B760M-A AX v: Rev 1.xx
UEFI: American Megatrends v: 1402 date: 09/08/2023
Info: model: 12th Gen Intel Core i7-12700F bits: 64 type: MST AMCP
microcode: 0x37
Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 800 min/max: 800/4800:4900:3600 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 84480
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: ZOTAC driver: nvidia
v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none off: DP-1, DP-2, DP-3, HDMI-A-1 empty: none
bus-ID: 01:00.0 chip-ID: 10de:2803 class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 5360x1440 s-dpi: 110 s-size: 1239x333mm (48.78x13.11")
s-diag: 1283mm (50.51")
Monitor-1: DP-1 note: disabled pos: left model: Elgato built: 2013
res: 1920x1080 hz: 60 dpi: 69 gamma: 1.2 size: 708x398mm (27.87x15.67")
diag: 20mm (0.8") modes: max: 1920x1080 min: 720x480
Monitor-2: DP-2 note: disabled pos: right model: Lenovo LEN G34w-10
serial: <filter> built: 2020 res: 3440x1440 hz: 60 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 640x480
Monitor-3: DP-3 mapped: DP-4 note: disabled pos: primary,left
model: MSI G32C4W serial: <filter> built: 2024 res: 1920x1080 dpi: 70
gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9
Monitor-4: HDMI-A-1 mapped: HDMI-0 note: disabled pos: left
model: Kamvas 12 built: 2020 res: 1920x1080 hz: 60 dpi: 190 gamma: 1.2
size: 256x144mm (10.08x5.67") diag: 294mm (11.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Ti driver: nvidia v: 565.57.01 device-ID: 10de:2803
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256
bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM 18.1.8)
Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA AD106M High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
Device-3: Razer USA Leviathan V2 X
lanes: 1 mode: 1.1 bus-ID: 1-8.3:4 chip-ID: 1532:054a class-ID: 0102
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 5000 bus-ID: 05:00.0
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
vendor: AzureWave driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 06:00.0 chip-ID: 10ec:b852
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 13d3:3571
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 931.51 GiB used: 155.05 GiB (16.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 800 GOLD
lanes: 4 tech: SSD serial: <filter> fw-rev: V1122B0 temp: 40.9 C
used: 155.05 GiB (16.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.43 GiB used: 1.48 GiB (9.6%)
max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 37.8 C mobo: N/A gpu: nvidia temp: 47 C
Memory: total: 16 GiB available: 15.43 GiB used: 5.03 GiB (32.6%)
Processes: 455 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1841 libs: 542 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-12-01
Last full system update: 2024-12-02
