Hi there, recently I’m experiencing a strange (not fatal) error during boot.
After saying it’s loading linux-zen, a couple of light blue lines appear:
NVRM: loading NVIDIA UNIX etc etc...
TC 2023
usb 3.-2.4: can't set config #1, error -28
The system boots, but what gives? I tried waiting for updates, but it’s been a couple of weeks and it’s not fixed.
Btw, as usual for me ^^, it freezes for a minute instead of going to sleep if try to sleep the system, but I think it’s the same old problem I already try - and failed - to solve with your kind help.
Oh, and I noticed at the same time the option to hybernate disappeared: since it never worked maybe I could just delete the swap partition? But I guess it’s a separate issue.
Here’s the inxi:
tSystem:
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1930b164-e875-487b-9e15-d08dfb606021 rw rootflags=subvol=@
ibt=off resume=UUID=290da5e7-6510-4b46-9fa1-14463cba09cf
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASRock model: P67 Extreme4 serial: <superuser required>
BIOS: American Megatrends v: P3.10 date: 04/24/2012
Info: model: Intel Core i5-2500K bits: 64 type: MCP arch: Sandy Bridge
desc: 1x6 MiB
Speed (MHz): avg: 1596 high: 1600 min/max: 1600/3700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1595 2: 1600 3: 1596
4: 1596 bogomips: 26340
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ZOTAC driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none off: DP-1,DVI-I-1 empty: DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Screen-1: 0 s-res: 1920x1080 s-dpi: 97 s-size: 503x283mm (19.80x11.14")
s-diag: 577mm (22.72")
Monitor-1: DP-1 note: disabled model: Panasonic Panasonic-TV
serial: <filter> built: 2010 res: 1920x1080 dpi: 70 gamma: 1.2
size: 698x392mm (27.48x15.43") modes: max: 1920x1080 min: 640x480
Monitor-2: DVI-I-1 note: disabled pos: primary model: LG (GoldStar) W2363D
serial: <filter> built: 2011 res: 1920x1080 dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 582mm (22.9") ratio: 16:9 modes:
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 970 driver: nvidia v: 545.29.06
device-ID: 10de:13c2 surfaces: xcb,xlib
vendor: ASRock 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GM204 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: Logitech G430 Surround Sound Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 2-1.2:4 chip-ID: 046d:0a4d class-ID: 0300
Device-4: M-Audio AIR 192 6 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.3:3 chip-ID: 0763:410c
class-ID: fe01
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: b000 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.6:4
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.85 TiB used: 610.59 GiB (21.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX001-1NS164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: M4-CT128M4SSD2
tech: SSD serial: <filter> fw-rev: 070H scheme: MBR
ID-1: / raw-size: 50 GiB size: 46.57 GiB (93.13%) used: 31.55 GiB (67.8%)
ID-2: /home raw-size: 414.91 GiB size: 414.91 GiB (100.00%)
used: 155.64 GiB (37.5%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-3: /var/log raw-size: 50 GiB size: 46.57 GiB (93.13%)
used: 31.55 GiB (67.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/tmp raw-size: 50 GiB size: 46.57 GiB (93.13%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 31%
Processes: 262 Uptime: 7m wakeups: 0 Memory: total: 16 GiB
available: 15.58 GiB used: 4.63 GiB (29.7%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1471 libs: 475 tools: octopi,paru Shell: fish
v: 3.6.4 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-10-26
Last full system update: 2023-12-16
