I’ve been trying to diagnose and solve something. I need to run Intel Quartus Prime Lite for FPGA development, and Garuda KDE Dragonized is my OS of choice… I have no intention of switching to anything else… but I’ve run into a weird problem…
There is some kind of weird glitch when running Quartus, where some important menu options are permanently greyed out and non-functional (everything in the “Create / Update” menu under File). Quartus is not officially supported on Arch Linux, but it does work fine except for this menu. The super weird thing is that I discovered this only happens on X11, not Wayland. There’s no way I’m switching to Wayland though, not for quite some time anyway.
The important point about this issue, is that I have tried EndeavourOS with KDE and X11 and Quartus functions completely normally. So there is some unknown difference between the two distros that is affecting Quartus… even though they are both Arch-based. I just have run out of ideas on how to diagnose what is causing this. Starting Quartus from a terminal doesn’t produce any console errors unfortunately. Also both the AUR quartus-free package and Intel’s installer behave exactly the same.
Anyway, I just wanted to post this and see if anyone had any thoughts on what could be different with Garuda’s X11 server. For now I am using Quartus in a Virtualbox VM running EndeavourOS… but obviously that is not ideal.
I will include my garuda-inxi in case it means something to someone…
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw rootflags=subvol=@
drm.edid_firmware=DisplayPort-0:/edid/Samsung-EDID-RGB.bin ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
UEFI: American Megatrends LLC. v: F28 date: 12/14/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 937 high: 1100 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1100 3: 1100
4: 800 5: 1099 6: 800 7: 800 8: 800 9: 1097 10: 1100 11: 1100 12: 800
13: 1100 14: 800 15: 1100 16: 800 17: 800 18: 1100 19: 1100 20: 800
21: 800 22: 800 23: 800 24: 800 bogomips: 164044
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73a5
Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.1:5
chip-ID: 1532:0e03 class-ID: 0102
Device-3: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.4:8 chip-ID: 534d:2109
Device-4: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.2:6
chip-ID: 07ca:0110 class-ID: 0102 serial: <filter>
Device-5: Elgato Systems GmbH Game Capture HD60 X
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.1:5
chip-ID: 0fd9:0082 class-ID: 0300 serial: <filter>
s-diag: 1165mm (45.88")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Samsung serial: <filter>
built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 16.0.6 DRM 3.56 6.7.0-zen3-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.274 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-4: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-5: MacroSilicon USB Video
Device-6: Focusrite-Novation Scarlett 4i4 USB driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:12
chip-ID: 1235:8212 class-ID: 0103 serial: <filter>
Device-7: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
Device-8: Elgato Systems GmbH Game Capture HD60 X
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 port: N/A bus-ID: 08:00.0 chip-ID: 1d6a:14c0 class-ID: 0200
temp: 43.0 C
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:25 chip-ID: 8087:0033
Local Storage: total: 9.56 TiB used: 1.48 TiB (15.5%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 52.9 C scheme: GPT
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 48.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Western Digital
fw-rev: 731100WD temp: 54.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Corsair model: Performance Pro
tech: SSD serial: <filter> fw-rev: 1.0 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: X110 2.5 7MM 256GB
tech: SSD serial: <filter> fw-rev: 412 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.43 TiB (78.7%)
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
used: 1.43 TiB (78.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.61 GiB used: 527.8 MiB (0.8%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 545
Processes: 547 Uptime: 1h 4m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.62 GiB used: 8 GiB (12.8%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2192 libs: 593 tools: octopi,paru,yay pm: rpm
pkgs: 0 Shell: fish v: 3.7.0 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-05-03
Last full system update: 2024-01-18 ↻
