So I have been using Garuda for a few months and have been having a good time with it, however, recently it looks like I am unable to just boot into the regular "Garuda Linux" entry from grub. I am able to go into the snapshots, select the latest one, and then choose the regular linux-zen kernel and initramfs (not the fallback ones) and it boots just fine. I think this started happening after I did a pacman -Syu but I am not entirely sure. When it originally happened I thought to just restore a snapshot. So I boot into an older snapshot (From anywhere from a week to a month ago) and click the "Restore" button on the popup that says I am running on a snapshot and would I like to restore it. I immediately do a reboot and still nothing. Stuck on loading initial ramdisk at boot.
I initially thought it was something with my grub install. So I blew the old partition away, and then reinstalled grub to no avail. Thought that maybe I should just rebuild the initramfs so I ran sudo mkinitcpio -P and that still didn't work. Then I thought to just reinstall the linux headers using sudo pacman -S linux-zen linux-zen-headers to maybe grab the newest version that might fix it, but still nothing. I also went in to btrfs-assistant and checked the diffs on each of my files in the /boot directory and it showed that there were no changes between my snapshots and the latest snapshot which I thought was weird, since in the grub menu it is booting using one of my older snapshots' /boot folder with success.
So far my solution has been to going into the "Garuda Snapshots" entry within grub, and selecting the vmlinuz-linux-zen & initramfs-linux-zen.img & amd-ucode.img entry which boots using initrd "/@_backup_20220112230608429/boot/amd-ucode.img" "/@_backup_20220112230608429/boot/initramfs-linux-zen.img". I am able to get into my computer using this method, and it seems like it isn't detected as a snapshot and I can actually install things and have it persist so I am not complaining a whole lot. But I think it would be great to get back to a state where I am able to just click enter without thinking about it. Is there anything that I am missing at all? Or is my only option to reinstall?
This is the output from garuda-inxi as well. I tried to include as much as I could, but if I missed anything I would be glad to add! Thanks!
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@_backup_20222712220721796/boot/vmlinuz-linux-zen
root=UUID=926ca3a3-eac8-45e1-b0cb-ec0ecc0d7019 quiet quiet splash
rootflags=defaults,noatime,compress=zstd,discard=async,ssd,subvol=@_backup_20222712220721796
Desktop: i3 v: 4.21.1 info: i3bar dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-I GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 4901 date: 07/25/2022
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 7 3700X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3600 min/max: 2200/4426 boost: enabled
base/boost: 3600/4400 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 115203
protection
Device-1: NVIDIA GA104 [GeForce RTX 3070] driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.0 chip-ID: 10de:2484
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-98a5c
driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x333mm (47.40x13.11")
s-diag: 1249mm (49.18")
Monitor-1: DP-4 pos: right res: 2560x1440 hz: 60 dpi: 93
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1440 hz: 60 dpi: 109
size: 597x335mm (23.5x13.19") diag: 685mm (26.95") modes: N/A
missing.
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 07:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-8:5 chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Local Storage: total: 1.82 TiB used: 196.46 GiB (10.5%)
rev: 2B2QEXM7 temp: 51.9 C scheme: GPT
ID-1: / raw-size: 1022.45 GiB size: 1022.45 GiB (100.00%)
used: 196.46 GiB (19.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /home raw-size: 1022.45 GiB size: 1022.45 GiB (100.00%)
maj-min: 259:2
ID-3: /var/log raw-size: 1022.45 GiB size: 1022.45 GiB (100.00%)
maj-min: 259:2
ID-4: /var/tmp raw-size: 1022.45 GiB size: 1022.45 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 68.0 C mobo: 52.0 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): cpu: 1708 case-1: 1196 gpu: nvidia fan: 0%
Power: 12v: 9.87 5v: N/A 3.3v: N/A vbat: 3.27
Processes: 399 Uptime: 4m wakeups: 2 Memory: 31.27 GiB
used: 3.94 GiB (12.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1753
libs: 430 tools: pamac,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: kitty inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-26
Last full system update: 2022-11-29
Is partially upgraded: Yes
Windows dual boot: Yes
