Still having problems suspending in Garuda Gaming
  Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=f7087ef8-b548-4e82-80a4-beb598333620 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Desktop System: ASRock product: Z790 LiveMixer v: N/A serial: N/A
  Mobo: ASRock model: Z790 LiveMixer serial: <filter>
    uuid: 04006b9c-7879-0000-0000-000000000000 UEFI: American Megatrends LLC.
    v: 14.02 date: 02/07/2024
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
  Info: model: 13th Gen Intel Core i9-13900KF bits: 64 type: MST AMCP
    microcode: 0x123
  Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
    cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
    L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
  Speed (MHz): avg: 991 high: 2420 min/max: 800/5500:5800:4300
    base/boost: 5445/8500 scaling: driver: intel_pstate governor: powersave
    volts: 1.4 V ext-clock: 100 MHz cores: 1: 1258 2: 1200 3: 800 4: 800
    5: 1199 6: 800 7: 1300 8: 800 9: 1860 10: 800 11: 2420 12: 1100 13: 1200
    14: 800 15: 1210 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
    23: 800 24: 1238 25: 800 26: 800 27: 800 28: 951 29: 800 30: 800 31: 800
    32: 800 bogomips: 191692
  Device-1: NVIDIA AD103 [GeForce RTX 4080] vendor: Gigabyte driver: nvidia
    v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-02) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
    chip-ID: 10de:2704 class-ID: 0300
  Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
  Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.64x15.43")
    s-diag: 804mm (31.65")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: MSI G321CU
    built: 2022 res: 3840x2160 dpi: 139 gamma: 1.2
    size: 700x390mm (27.56x15.35") diag: 800mm (31.5") ratio: 16:9 modes:
    max: 3840x2160 min: 640x480
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
    memory: 15.62 GiB
  API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4080 driver: nvidia v: 550.54.14
    device-ID: 10de:2704 surfaces: xcb,xlib
  Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
  Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb
  API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with:
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
  Local Storage: total: 22.3 TiB used: 10.15 TiB (45.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
    model: T-FORCE TM8FPZ004T size: 3.64 TiB block-size: physical: 512 B
    fw-rev: EIFM51.3 temp: 35.9 C scheme: GPT
  SMART: yes health: PASSED on: 26d 13h cycles: 245
    read-units: 13,939,461 [7.13 TB] written-units: 15,324,460 [7.84 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Seagate model: BarraCuda Q5
    ZP2000CV30001 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU5SH017
    temp: 32.9 C scheme: GPT
  SMART: yes health: PASSED on: 1y 111d 14h cycles: 3,207
    read-units: 27,088,854 [13.8 TB] written-units: 94,440,928 [48.3 TB]
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
    family: Barracuda 7200.12 size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: CC38 temp: 31 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 6y 193d 22h cycles: 9581
    read: 1.06 TiB written: 1023.97 GiB Pre-Fail: attribute: Spin_Retry_Count
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST12000NM0127
    size: 10.91 TiB block-size: physical: 4096 B logical: 512 B sata: 3.1
    speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: G006
    temp: 35 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 8d 0h cycles: 88
    read: 1.43 TiB written: 3.41 TiB Pre-Fail: attribute: Spin_Retry_Count
  ID-5: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MQ03UBB200
    family: 2.5" HDD MQ03UBB... size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
    sata: 3.0 speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 5438 drive-rev: JP050U temp: 27 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 4y 88d 22h cycles: 1811
  ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD40NMZW-11GX6S1 family: Elements / My Passport (USB, AF)
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 sata: 3.1 speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1018 drive-rev: 01.01A01
    temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 3y 85d 13h cycles: 645
  ID-7: /dev/sde maj-min: 8:64 vendor: Verbatim model: STORE N GO
    size: 14.46 GiB block-size: physical: 512 B logical: 512 B type: USB
    fw-rev: PMAP
  ID-1: / raw-size: 170.75 GiB size: 170.75 GiB (100.00%)
    used: 33.12 GiB (19.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
    maj-min: 259:3
  ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
    used: 17 MiB (2.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
    maj-min: 259:2
  ID-3: /home raw-size: 170.75 GiB size: 170.75 GiB (100.00%)
    maj-min: 259:3
  ID-4: /var/log raw-size: 170.75 GiB size: 170.75 GiB (100.00%)
    maj-min: 259:3
  ID-5: /var/tmp raw-size: 170.75 GiB size: 170.75 GiB (100.00%)
    maj-min: 259:3
  ID-1: swap-1 type: zram size: 46.87 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
  System Temperatures: cpu: 8.0 C mobo: 36.0 C gpu: nvidia temp: 42 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0 fan-3: 0 fan-4: 0 fan-5: 931
    fan-6: 1124 fan-7: 3154 gpu: nvidia fan: 0%
  Memory: total: 48 GiB available: 46.87 GiB used: 4.56 GiB (9.7%)
  Processes: 559 Power: uptime: 52m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 18.7 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 2258 libs: 610 tools: gnome-software, octopi,
    pamac, paru Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo)
    default: Bash v: 5.2.26 running-in: lxterminal inxi: 3.3.33
Garuda (2.6.23-1):
  System install date:     2024-03-11
  Last full system update: 2024-03-12
i have sought support or this issue before, and some suggestion were given which have not worked.
When i suspend and re-awake my computer it does not wake up but freezes the system. It must have to do with my 4080 graphic card, for with a RX 7900 XTX suspend works fine.
i have tried compatibility mode, S5 and S4 & S5 suspend states on my Asrock motherboard, without any difference.
When i first installed Garuda i could suspend fine, i found out by accident, but after the initial update is loaded, after a reboot, the problems started. (i use the November 2023 installation version from this site.)
any idea how i could fix this?
Thanks
Please!
Probably so. Try enabling the save/restore of video memory contents as described here: https://wiki.archlinux.org/title/NVIDIA/Tips_and_tricks#Preserve_video_memory_after_suspend
You can use the kernel module parameter with any of the options described here: https://wiki.archlinux.org/title/Kernel_module#Setting_module_options. For example, to use a file in /etc/modprobe.d/ first make the file:
sudo micro /etc/modprobe.d/nvidia-preserve-video-memory.conf
Add the parameter:
options nvidia NVreg_PreserveVideoMemoryAllocations=1
Save and exit the file.
Don’t forget to enable the services mentioned in the first article:
sudo systemctl enable nvidia-suspend.service
sudo systemctl enable nvidia-hibernate.service
sudo systemctl enable nvidia-resume.service
Reboot, then test again.
If that doesn’t help, check your logs to see if you have errors that look like the ones mentioned in this article: https://wiki.archlinux.org/title/NVIDIA/Troubleshooting#System_does_not_return_from_suspend. If so, try setting that kernel parameter to see if it helps.
Thanks a million that solved the problem. :partying_face:
Sorry, i will try and keep that in mind.
