Looked this up; most of the solutions are from 2013; should not be asking to install a 32 bit package. ~ [SOLVED] steam: missing libc.so.6 / Multimedia and Games / Arch Linux Forums
Seems like this is some sort of issue with KDE; steam crashed before this happened; also likely that it is do to manipulation of some sort.
Attacker could also be trying to get 32bit libraries installed on the system as well.
Probably need to do a fresh install to fix this.
Much appreciated.
Kernel: 6.7.9-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=ee9d8e46-88f6-40bb-a345-3b374ebb4edb rw rootflags=subvol=@
quiet rd.luks.uuid=5d766ada-bbea-4479-b984-c5950293753b quiet
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASUSTeK model: A88XM-PLUS v: Rev X.0x
UEFI-[Legacy]: American Megatrends v: 3004 date: 04/14/2017
Device-1: ps-controller-battery-1c:96:5a:c3:bb:50 model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD A10-7850K Radeon R7 12 Compute Cores 4C+8G bits: 64
type: MT MCP arch: Steamroller level: v2 built: 2014 process: GF 28nm
family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003106
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3672 high: 3877 min/max: 1700/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3472 2: 3713
3: 3877 4: 3626 bogomips: 29539
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: XFX Pine
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:687f
Monitor-1: DP-3 res: 1360x768 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX Vega (radeonsi vega10
LLVM 17.0.6 DRM 3.57 6.7.9-hardened1-1-hardened) device-ID: 1002:687f
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX Vega (RADV VEGA10) driver: mesa radv v: 24.0.3-arch1.2
device-ID: 1002:687f surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD FCH Azalia vendor: ASUSTeK AM1I-A driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-2: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:aaf8 class-ID: 0403
API: ALSA v: k6.7.9-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.14 TiB used: 30.07 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
tech: SSD serial: <filter> fw-rev: 3B0Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
used: 30.07 GiB (12.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5d766ada-bbea-4479-b984-c5950293753b
ID-2: /home raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-3: /var/log raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 18.9 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 25.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 805
Memory: total: 32 GiB available: 31.3 GiB used: 3.31 GiB (10.6%)
Processes: 231 Power: uptime: 23m states: freeze,mem suspend: deep
avail: s2idle wakeups: 0 services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1493 libs: 478 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-03-11
Last full system update: 2024-03-30
