garuda-inxi:
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c1186269-b621-4cd3-84a8-69b7dce0c70d rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME H310-PLUS v: Rev X.0x
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 0401 date: 02/28/2018
Info: model: Intel Core i5-9500 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
desc: 1x9 MiB
Speed (MHz): avg: 4098 high: 4100 min/max: 800/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 4100 2: 4097 3: 4100
4: 4100 5: 4100 6: 4094 bogomips: 36000
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300
Screen-1: 0 s-res: 1366x768 s-dpi: 80 s-size: 434x241mm (17.09x9.49")
s-diag: 496mm (19.54")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer K202HQLA
serial: <filter> built: 2016 res: 1366x768 hz: 60 dpi: 80 gamma: 1.2
size: 434x236mm (17.09x9.29") diag: 494mm (19.4") ratio: 16:9 modes:
max: 1366x768 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 550.54.14 device-ID: 10de:1c82
surfaces: xcb,xlib
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
Device-3: Elite Silicon USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-6:9 chip-ID: 18c3:1008 class-ID: 0300
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api tools: N/A
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Ralink RT5370 Wireless Adapter driver: rt2800usb type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 148f:5370
IF: wlp0s20f0u4 state: down mac: <filter>
Local Storage: total: 2.05 TiB used: 723.97 GiB (34.5%)
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM2 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: UDore 256GB size: 238.47 GiB
serial: <filter> fw-rev: 1A0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: <filter> fw-rev: A8A0 scheme: GPT
ID-1: / raw-size: 237.5 GiB size: 237.5 GiB (100.00%)
used: 88.03 GiB (37.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 1001 MiB size: 999 MiB (99.80%)
used: 25.9 MiB (2.6%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 416.12 GiB (44.7%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 237.5 GiB size: 237.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 237.5 GiB size: 237.5 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.38 GiB used: 222.8 MiB (0.9%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6
System Temperatures: cpu: 96.0 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
Memory: total: 24 GiB available: 23.39 GiB used: 7.05 GiB (30.2%)
Processes: 370 Power: uptime: 1d 1h 35m states: freeze,mem,disk
reboot, suspend, test_resume image: 9.29 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1761 libs: 465 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
running-in: yakuake inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-12-22
Last full system update: 2024-03-12 ↻
Failed units: postgresql.service
steam stopped starting on the 10th, it was already after the upgrade to kde plasma 6, but for the first couple of days it stopped starting normally, once when trying to launch it, a window appeared with the phrase something like “steamwebhelper is not responding”, but it no longer appeared. Restarting the system did not help, updating the system via garuda-update, as well as reinstalling the steam package and steam-native-runtime. Steam is displayed in the tray, but the client itself does not open, as well as games do not start from the desktop. When trying to run through the terminal, it writes:
steam.sh[98749]: Running Steam on garuda Soaring 64-bit
steam.sh[98749]: STEAM_RUNTIME is enabled automatically
setup.sh[98821]: Steam runtime environment up-to-date!
steam.sh[98749]: Steam client's requirements are satisfied
tid(98878) burning pthread_key_t == 0 so we never use it
Do you have any ideas how to fix this and what it might be related to?
