Steam not launching
I have tried different kernels as well as reinstalling Steam but both Native and Runtime refuse to work. When I try to open them it appears on my system monitor and then disappears.
Here are my system specs:
Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=3739a81c-810b-4758-9c2f-c45a263c5b26 rw single
rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: HP product: OMEN 25L Desktop GT12-0xxx v: N/A
Mobo: HP model: 8704 v: 00 serial: <superuser required> UEFI: AMI v: F.20
date: 08/27/2021
Info: model: Intel Core i7-10700F bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2954 high: 4604 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1792 2: 799 3: 4600
4: 4604 5: 2086 6: 2105 7: 3183 8: 4142 9: 1630 10: 4506 11: 2629 12: 4601
13: 3406 14: 2900 15: 801 16: 3488 bogomips: 92796
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti] vendor: Hewlett-Packard
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2486
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 23.1.0
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-4 res: 2560x1440 hz: 165 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 3060
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 1-2.2:7
alternate: snd_soc_skl,snd_sof_pci_intel_cnl chip-ID: 0951:16df
bus-ID: 00:1f.3 class-ID: 0300 serial: <filter> chip-ID: 8086:06c8
Device-2: NVIDIA GA104 High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
Device-3: Kingston HyperX QuadCast type: USB
Device-4: Sony WF-1000XM3 [Wireless Noise-Canceling Headphones] type: USB
driver: hid-generic,usbhid bus-ID: 1-4:4 chip-ID: 054c:0ce0 class-ID: 0300
Sound API: ALSA v: k6.2.8-zen1-1-zen running: yes
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Sony WF-1000XM3 [Wireless Noise-Canceling Headphones] type: USB
bus-ID: 1-14:8 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 2.05 TiB used: 96.6 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK
SDBPNTY-256G-1106 size: 238.47 GiB block-size: physical: 512 B
rev: HPS2 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: VP01 scheme: GPT
used: 30.28 GiB (12.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.49 GiB used: 5.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 69.0 C pch: 58.0 C mobo: N/A gpu: nvidia
temp: 50 C
Fan Speeds (RPM): cpu: 0 fan-2: 0 gpu: nvidia fan: 30%
Processes: 388 Uptime: 54m wakeups: 1 Memory: 15.49 GiB
used: 7.2 GiB (46.5%) Init: systemd v: 253 default: graphical
pkgs: 1700 libs: 502 tools: octopi,pamac,paru,yay pm: flatpak pkgs: 0
inxi: 3.3.25
System install date:     2023-03-25
Last full system update: 2023-03-29 ↻
Relevant software:       timeshift(custom) NetworkManager dracut nvidia-dkms
Failed units:            plymouth-deactivate.service
Using the terminal to run the steam command I am confronted with this:
Steam
steam.sh[41116]: Running Steam on garuda Soaring 64-bit
steam.sh[41116]: STEAM_RUNTIME is enabled automatically
setup.sh[41188]: Steam runtime environment up-to-date!
steam.sh[41116]: Can't find 'steam-runtime-check-requirements', continuing anyway
[2023-03-29 12:05:57] Startup - updater built Feb 14 2023 00:47:09
[2023-03-29 12:05:57] Startup - Steam Client launched with: '/home/lalaraja/.local/share/Steam/ubuntu12_32/steam'
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
free(): invalid pointer
crash_20230329120557_2.dmp[41245]: Uploading dump (out-of-process)
/tmp/dumps/crash_20230329120557_2.dmp
/home/lalaraja/.local/share/Steam/steam.sh: line 798: 41242 Aborted                 (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
And then it is followed by this crash:
Crash
crash_20230329120557_2.dmp[41245]: Finished uploading minidump (out-of-process): success = yes
crash_20230329120557_2.dmp[41245]: response: CrashID=bp-48e63f6e-60ab-4297-a065-e23e92230329
crash_20230329120557_2.dmp[41245]: file ''/tmp/dumps/crash_20230329120557_2.dmp'', upload yes: ''CrashID=bp-48
e63f6e-60ab-4297-a065-e23e92230329''
I'm not sure what is causing this as I have tried to reinstall the OS altogether before and that worked but that was last week and now the same issue is occurring. If anyone could lend me a hand I would appreciate it!
I see that the latest Steam update is 3 March, so the problem should come from something else more recent (else you would have encountered the problem right after installation).
Among the Steam dependencies I see e.g. nvidia-utils and lib32-nvidia-utils for the vulkan-drivers part, both updated on 23 Mar.
Do you happen to still have a snapshot from before that update?
Please reboot. There may have been critical updates that will be applied after a reboot.
You have a restart required in your inxi. try a restart and a proper upgrade garuda-update with a reboot following and try again.
Unfortunately I don't.
I have tried using garuda-update but I was confronted with this issue:
A problem with the NVIDIA drivers has been detected
---> Building NVIDIA DKMS module for kernel 6.1.21-1-lts
Module nvidia 530.41.03 is not installed for kernel 6.1.21-1-lts (x86_64). Skipping...
Module nvidia 530.41.03 is not built for kernel 6.1.21-1-lts (x86_64). Skipping...
Sign command: /usr/lib/modules/6.1.21-1-lts/build/scripts/sign-file
Binary /usr/lib/modules/6.1.21-1-lts/build/scripts/sign-file not found, modules won't be signed
Error! Your kernel headers for kernel 6.1.21-1-lts cannot be found at /usr/lib/modules/6.1.21-1-lts/build or /
usr/lib/modules/6.1.21-1-lts/source.
Please install the linux-headers-6.1.21-1-lts package or use the --kernelsourcedir option to tell DKMS where i
t's located.
---> Failed to build NVIDIA DKMS module for kernel 6.1.21-1-lts
---> Building NVIDIA DKMS module for kernel 6.2.8-arch1-1
Module nvidia 530.41.03 is not installed for kernel 6.2.8-arch1-1 (x86_64). Skipping...
Module nvidia 530.41.03 is not built for kernel 6.2.8-arch1-1 (x86_64). Skipping...
Sign command: /usr/lib/modules/6.2.8-arch1-1/build/scripts/sign-file
Binary /usr/lib/modules/6.2.8-arch1-1/build/scripts/sign-file not found, modules won't be signed
Error! Your kernel headers for kernel 6.2.8-arch1-1 cannot be found at /usr/lib/modules/6.2.8-arch1-1/build or
/usr/lib/modules/6.2.8-arch1-1/source.
Please install the linux-headers-6.2.8-arch1-1 package or use the --kernelsourcedir option to tell DKMS where
it's located.
---> Failed to build NVIDIA DKMS module for kernel 6.2.8-arch1-1
It says I need to install linux-headers-6.2.8-arch1-1 package or use --kernelsourcedir option to tell DKMS where. However, I'm not sure where I find the linux header and the second option does not work.
That would be a
sudo pacman -S linux-headers
It successfully downloaded but when I try and run garuda-update I've got the same issue but now it's only appearing for kernel 6.1.21-1-lts.
I have also tried rebooting but the reboot symbol still remains on my inxi.
Reinstalling all packages via Garuda Assistant seems to have worked. I will create a snapshot and reboot my system just to make sure this is a permanent solution.
That would have been just a
sudo pacman -S linux-lts-headers
:wink:
All good anyway if it works now…
