Steam gui does not open
After closing the window the steam gui does not open again after the latest update. The tray icon is still there but i cant access my library the store or anything similar. It only opens up again after deleting config.vdf
On a unrelated note is there a way i can globally change the windows version for wine and proton without doing it from winecfg manually each time? Did not see this issue as something huge enough to make a post over
  Kernel: 6.4.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=e6088794-001d-4306-b60f-b8de88f9af6e rw rootflags=subvol=@
    resume=UUID=3a71adf5-560e-4927-bcfe-a7734552344a loglevel=3 ibt=off
  Type: Laptop System: GAME GARAJ product: TRACER XL v: REV:1.0
  Mobo: GAME GARAJ model: TRACER XL v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends v: E17F5IE2.100 date: 01/22/2021
  ID-1: BAT1 charge: 44.4 Wh (96.9%) condition: 45.8/51.3 Wh (89.4%)
    volts: 12.8 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: not charging
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 2 microcode: 0xF6
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1100 high: 2600 min/max: 800/5000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 2600 3: 800
    4: 2600 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
    bogomips: 62399
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Micro-Star MSI driver: nvidia v: 535.54.03
    alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: none empty: HDMI-A-1
    bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x978f built: 2020
    res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
    diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX 3060
    Laptop GPU/PCIe/SSE2 direct-render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
  Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
  API: ALSA v: k6.4.1-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
  IF-ID-1: br-5dba8f5c9f8d state: down mac: <filter>
  IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IF-ID-4: veth7e2e959 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0026
  Report: bt-adapter ID: hci0 rfk-id: 1 state: down
    address: <filter>
  Local Storage: total: 2.27 TiB used: 351.17 GiB (15.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
    lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z44101 temp: 44.9 C
    model: WD20JDRW-11C7VS0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 4800 serial: <filter> fw-rev: 1034 scheme: GPT
  ID-1: / raw-size: 448.46 GiB size: 448.46 GiB (100.00%)
    used: 351.17 GiB (78.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 900 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 448.46 GiB size: 448.46 GiB (100.00%)
  ID-4: /var/log raw-size: 448.46 GiB size: 448.46 GiB (100.00%)
  ID-5: /var/tmp raw-size: 448.46 GiB size: 448.46 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.45 GiB used: 482.8 MiB (3.1%)
  ID-2: swap-2 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
  System Temperatures: cpu: 75.0 C pch: 61.0 C mobo: N/A gpu: nvidia
    temp: 68 C
  Processes: 373 Uptime: 5m wakeups: 1 Memory: available: 15.45 GiB
  used: 6.38 GiB (41.3%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 3190 libs: 652 tools: octopi,paru pm: flatpak pkgs: 0 Shell: Zsh
  v: 5.9 running-in: kitty inxi: 3.3.27
  System install date:     2023-05-14
  Last full system update: 2023-07-04
Try reinstalling these libraries:
https://wiki.archlinux.org/title/Steam/Troubleshooting#Missing_taskbar_menu
Didnt do much. I did found the solution on the same wiki page so thanks anyway m8. Turns out it was the new steam ui not working well with the nvidia drivers. Using the old ui with the -vgui parameter or downgrading the nvidia driver solves the issue acording to arch wiki
You can also try disabling GPU accelerated rendering in web views in settings>interface in the new UI if it's not already disabled
