Hello again,
I have a new problem now. Most of the games I have tried to run on Steam either don’t launch or complain about having no connection to Steam. The one game I’ve tried that seems to work perfectly thus far is Armello. The rundown basically goes like this:
- Yu-Gi-Oh Duel Links Launches but immediately complains about having no connection to the Steam server.
- Sea of Theives complains of a “LlamaBeard” connection error.
- Deep Rock Galactic launches but immediately complains of being unable to connect to Steam.
- Armello, as mentioned, is the sole known game that launches and runs just fine. This may have to do with being a native Linux game but doesn’t explain the issues with TF2.
- Team Fortress 2 simply refuses to launch altogether.
- Digimon Story Cyber Sleuth also refuses to launch.
TF2 and Armello are both running their native Linux versions as far as I can tell. All other games are running through Proton.
I thought that following the instructions linked below would help me out but it just stopped my internet from working and I wound up just reverting to a previous snapshot.
https://wiki.archlinux.org/title/Systemd-resolved#DNS
Here is the obligatory garuda-inxi output:
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0c56ec49-20ad-4aa0-a88b-55b47e733bc9 rw rootflags=subvol=@
quiet rd.luks.uuid=d79b9435-2941-4ab1-b7b1-6436232809f7
rd.luks.uuid=49c27010-0fe7-452f-b43e-2b305ff69240
resume=/dev/mapper/luks-49c27010-0fe7-452f-b43e-2b305ff69240 loglevel=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASRock model: 970M Pro3 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P1.50 date: 01/11/2016
Info: model: AMD FX-4350 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2492 high: 3592 min/max: 1400/4200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 3585 4: 3592 bogomips: 33526
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: Tul / PowerColor driver: amdgpu
v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 58.0 C
gpu: amdgpu display-ID: 0
drv: radeonsi inactive: gbm
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 560 Series (polaris11
LLVM 16.0.6 DRM 3.54 6.6.3-zen1-1-zen) device-ID: 1002:67ef
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 560 Series (RADV POLARIS11) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:67ef surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: AMD SBx00 Azalia vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Tul / PowerColor driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aae0 class-ID: 0403
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api with: aoss
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 14e4:43a0 class-ID: 0280
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 2357:0604
Local Storage: total: 931.51 GiB used: 193.16 GiB (20.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
used: 193.16 GiB (20.9%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-d79b9435-2941-4ab1-b7b1-6436232809f7
ID-2: /home raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-3: /var/log raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-4: /var/tmp raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-0 maj-min: 254:0
mapped: luks-49c27010-0fe7-452f-b43e-2b305ff69240
ID-2: swap-2 type: zram size: 7.73 GiB used: 1.61 GiB (20.8%)
System Temperatures: cpu: 20.0 C mobo: N/A gpu: amdgpu temp: 59.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 553
Processes: 304 Uptime: 2h 16m wakeups: 1 Memory: total: 8 GiB
available: 7.73 GiB used: 4.37 GiB (56.5%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1913 libs: 507 tools: octopi,paru,yay Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-27
Last full system update: 2023-11-30
I’ve also attached some game screenshots if they are of any use.
Thanks.
