Normally, I’m able to find a solution via research for my problems, but none of the threads I’ve come across have resolved my issues. Every game I launch, launches in my left monitor instead of my center. I’ve tried setting xandr via terminal, with no change, tried logically moving my monitor to the right with no change. I can move the app to my main monitor with hotkeys, however, since my far left monitor is 1080p and my other 2 are 1440p, a lot of games I can not set to the proper resolution with this method. If I disable the monitor I can get it to work, but that’s a pretty annoying workaround. Is there an actual fix for this?
I have Garuda Dragonized with KDE Plasma, latest patches applied, proprietary NVidia drivers installed through official repository.
I truthfully can’t find much short of the xandr command.
Thanks!
Kernel: 6.16.8-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=d7ae3ecb-bb98-468d-a4f6-02809d595c4d rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: Gigabyte model: X870 GAMING WIFI6 serial: N/A
uuid: 03ff0200-0400-0580-ee06-000700080009 UEFI: American Megatrends LLC.
v: F6a date: 05/05/2025
Info: model: AMD Ryzen 9 9950X3D socket: AM5 bits: 64 type: MT MCP
arch: Zen 5 gen: 5 level: v4 note: check built: 2024+ process: TSMC n4 (4nm)
family: 0x1A (26) model-id: 0x44 (68) stepping: 0 microcode: 0xB404023
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 2982 min/max: 624/5756 boost: enabled
base/boost: 4300/5750 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.3 V ext-clock: 100 MHz cores: 1: 2982 2: 2982 3: 2982 4: 2982
5: 2982 6: 2982 7: 2982 8: 2982 9: 2982 10: 2982 11: 2982 12: 2982
13: 2982 14: 2982 15: 2982 16: 2982 17: 2982 18: 2982 19: 2982 20: 2982
21: 2982 22: 2982 23: 2982 24: 2982 25: 2982 26: 2982 27: 2982 28: 2982
29: 2982 30: 2982 31: 2982 32: 2982 bogomips: 274709
ssse3 svm
Device-1: NVIDIA GB203 [GeForce RTX 5080] vendor: ZOTAC driver: nvidia
v: 580.82.09 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 5 speed: 32 GT/s lanes: 16
ports: active: DP-1,DP-2,DP-3 empty: HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2c02 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.8 with: Xwayland v: 24.1.8
alternate: fbdev,nouveau,nv,vesa gpu: nv_platform,nvidia,nvidia-nvswitch
display-ID: :1 screens: 1
Screen-1: 0 s-res: 7040x1649 s-dpi: 96 s-size: 1862x436mm (73.31x17.17")
s-diag: 1912mm (75.29")
Monitor-1: DP-1 pos: bottom-r model: HP OMEN 27i IPS serial: <filter>
built: 2020 res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-2 pos: bottom-l model: Dell S2721HGF serial: <filter>
built: 2020 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-3: DP-3 pos: primary,top-center model: C32C1S serial: <filter>
built: 2023 res: mode: 2560x1440 hz: 240 scale: 100% (1) dpi: 93 gamma: 1.2
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 5080/PCIe/SSE2
memory: 15.55 GiB
API: Vulkan v: 1.4.321 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 5080 driver: nvidia v: 580.82.09
device-ID: 10de:2c02 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM
de: kscreen-console,kscreen-doctor gpu: corectrl, lact, nvidia-settings,
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22e9 class-ID: 0403
lanes: 16 bus-ID: 74:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: SteelSeries ApS Arctis Nova Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 1038:12e0 class-ID: 0300
API: ALSA v: k6.16.8-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.8 status: n/a (root, process) with:
Device-1: Intel 82599 10 Gigabit Network vendor: Beijing Sinead
driver: ixgbe v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
lanes: 8 port: e000 bus-ID: 05:00.0 chip-ID: 8086:1557 class-ID: 0200
IF: enp5s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8851BE PCIe 802.11ax Wireless Network
driver: rtw89_8851be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 07:00.0 chip-ID: 10ec:b851 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-3: ASUSTek ROG STRIX SCOPE II 96 WIRELESS
driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 9-1.3:3 chip-ID: 0b05:1aae class-ID: 0300
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 0bda:b850
Local Storage: total: 3.68 TiB used: 1.23 TiB (33.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW020T8
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 5y 123d 6h cycles: 447
read-units: 397,480,325 [203 TB] written-units: 435,357,508 [222 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 174d 15h cycles: 161
read-units: 31,790,828 [16.2 TB] written-units: 54,023,306 [27.6 TB]
ID-1: / raw-size: 806.45 GiB size: 806.45 GiB (100.00%)
used: 516.82 GiB (64.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p6
maj-min: 259:7
used: 31.4 MiB (32.7%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:2
ID-3: /home raw-size: 806.45 GiB size: 806.45 GiB (100.00%)
maj-min: 259:7
ID-4: /var/log raw-size: 806.45 GiB size: 806.45 GiB (100.00%)
maj-min: 259:7
ID-5: /var/tmp raw-size: 806.45 GiB size: 806.45 GiB (100.00%)
maj-min: 259:7
ID-1: swap-1 type: zram size: 93.9 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.8 C mobo: 27.0 C
Memory: total: 96 GiB note: est. available: 93.9 GiB used: 10.28 GiB (10.9%)
Processes: 609 Power: uptime: 14h 46m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 37.45 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 258
Packages: 2015 pm: pacman pkgs: 1994 libs: 574 tools: octopi,paru,yay
pm: flatpak pkgs: 21 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash (sudo)
v: 5.3.3 running-in: konsole inxi: 3.3.39
Garuda (2.8.3-2):
System install date: 2025-09-23
Garuda release: 250916
Last full system update: 2025-09-27
Windows dual boot: Yes
24/24 checks run in 0.32 seconds ⌛
Powered by garuda-health 🦅
