Steam game (proton) does not start, skipping destruction (fork without exec?)
this is the exist message from the crash log:
pid 276275 != 276274, skipping destruction (fork without exec?)
Here my inxi -Faz
  Host: user-user-099-19 Kernel: 5.15.14-1-lts x86_64 bits: 64 compiler: gcc
    v: 11.1.0
    parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-08-14_18-57-58/@/boot/vmlinuz-linux-lts
    root=UUID=267ac74c-64a6-4376-90ae-e5a106ca6b70 rw
    rootflags=subvol=timeshift-btrfs/snapshots/2021-08-14_18-57-58/@ quiet
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
  Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 1202
    date: 10/22/2020
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3742 high: 4642 min/max: 2200/4650 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3815 2: 3295
    3: 3089 4: 4642 5: 4222 6: 3486 7: 4398 8: 3089 9: 3091 10: 4641 11: 3523
    12: 3619 bogomips: 88639
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: ASUSTeK
    driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 06:00.0
    chip-ID: 10de:1f06 class-ID: 0300
  Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
    loaded: nvidia display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
    s-diag: 583mm (23")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 94
    size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
  OpenGL: renderer: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
    v: 4.6.0 NVIDIA 495.46 direct render: Yes
  Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 10de:10f9
    driver: snd_hda_intel v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487
  Device-3: C-Media Auna Mic CM900 type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 0d8c:0134
  Sound Server-1: ALSA v: k5.15.14-1-lts running: yes
  Sound Server-2: JACK v: 1.9.20 running: no
  Sound Server-4: PipeWire v: 0.3.43 running: no
    port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp5s0 state: down mac: 3c:7c:3f:c3:4c:48
  Device-2: AVM FRITZ!WLAN AC 860 type: USB driver: mt76x2u bus-ID: 1-9:5
    chip-ID: 057c:8503 class-ID: 0000 serial: 3431C4DB6DA9
  IF: wlp1s0f0u9 state: up mac: 34:31:c4:db:6d:a9
  Local Storage: total: 1.07 TiB used: 233.61 GiB (21.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDA-1T00
    type: SSD serial: 19502B803401 rev: 40RL scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: ExcelStor model: J8160S
    size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: N/A serial: PVF904Q4A62MUB rev: ABEA scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 type: USB model: N/A size: 14.65 GiB
    block-size: physical: 512 B logical: 512 B type: N/A
    serial: 0509471264159500757 rev: 2.00 scheme: MBR
  ID-1: / raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
    used: 233.61 GiB (25.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
    used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
  ID-4: /var/log raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
  ID-5: /var/tmp raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.57 GiB used: 1.11 GiB (7.1%)
  System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 53 C
  Processes: 384 Uptime: 10h 0m wakeups: 0 Memory: 15.57 GiB
  used: 5.12 GiB (32.9%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: pacman: 1482 lib: 466 Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.12
Might want to restore the snapshot you booted from, reboot, update, and try again…
Which game was it by the way?
Some folks have been able to fix this issue (or similar) by setting up a sym link to point to the correct library.
See here: [SOLVED] Steam - Company of Heroes 2 does not start / Multimedia and Games / Arch Linux Forums
Or here: https://www.linuxquestions.org/questions/linux-games-33/mad-max-not-wanting-to-run-at-all-steam-4175613920/
It's generally better to either install the missing library or use the Steam runtime (rather than Steam Native) to get things running. Symlinks to system libraries are fragile at best.
