B.T.W
23 December 2021 12:52
1
Hi,
As the title says, Stem keeps dropping connection. When I open Steam I often get en error saying that it couldn't log me in. Doing steam --reset usually fixes that error. But as far as I can see it is random if I get it or not.
The other issue is when I already am logged in. I am downloading a game and it keeps dropping in and out constantly. Pic
I have tried disconnecting the Ethernet cable and used WiFi but that didn't do anything.
This is my first time using Linux as my main OS and I am dual-booting Win10 from another SSD for VR and unsupported games.
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=dce92b5f-b35c-4edc-a2c9-1ec0435caf6a rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: B550 AORUS PRO AC
serial: <superuser required> UEFI: American Megatrends LLC. v: F14e
date: 10/14/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3468 high: 4022 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3328 2: 3358
3: 3451 4: 3442 5: 3441 6: 3451 7: 3437 8: 3358 9: 3442 10: 3447 11: 4022
12: 3442 13: 3679 14: 3576 15: 3301 16: 3326 bogomips: 121368
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Gigabyte driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 09:00.0 chip-ID: 10de:2206
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-6.2:8 chip-ID: 046d:0892
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 6400x1440 s-dpi: 108 s-size: 1505x342mm (59.3x13.5")
s-diag: 1543mm (60.8")
Monitor-1: DP-4.1 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Monitor-2: DP-2 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-3: HDMI-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:1aef
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
Device-3: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:2 chip-ID: 1038:12ad
Device-4: Logitech C920 HD Pro Webcam type: USB
Device-5: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:2 chip-ID: 08bb:2902
Sound Server-1: ALSA v: k5.15.10-zen1-1-zen running: yes
port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel bus-ID: 08:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:3 chip-ID: 8087:0aa7 class-ID: e001
address: <filter>
Local Storage: total: 1.36 TiB used: 84.13 GiB (6.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
temp: 36.9 C scheme: GPT
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 30WD
used: 84.12 GiB (9.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.31 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 43%
Processes: 353 Uptime: 10h 16m wakeups: 0 Memory: 31.32 GiB
used: 4.37 GiB (14.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1857 lib: 533 Shell: fish v: 3.3.1
default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
If it is just Steam, then it is probably Steam's servers. They have their much anticipated Winter Sale going on, and everyone is home for the holidays....gaming it up. I am sure their servers are being taxed.
Do an internet speed test (just google it!) and see if you are getting good internet speeds outside of Steam. If so, then it is a Steam issue.
B.T.W
23 December 2021 17:41
6
I am pretty sure it isn't a server-side issue. I had the drop outs even before the winter sale and I am downloading on the Win10 install now and it is at my max internet speed without dropping out once.
Tried switching to another server and I had the same issue after a couple minutes.
I also found out that I get disconnected instantly when starting a download, and when I set it to stop trying I can log in again.
Yes but take steam out of the equation, as I directed above. How are your internet speeds, can you test?
Then that rules out any network issue with Garuda, which means it is Steam's server.
Not sure why Microsoft is faster when downloading, too many variables, different steam servers....which btw fluctuate depending on how many are connected at that time, so ???
If you are getting your ISP's internet speeds otherwise, it is not Garuda.
tbg
23 December 2021 19:06
10
You are the second person to bring this up in the last several days. A quick search on the forum suggests this was not a common issue in the past.
I am not a gamer and am totally unfamiliar with steam, however it might be worth downgrading steam to see if a recent update has caused this issue.
B.T.W
23 December 2021 19:49
11
I think it has something to with the download cache now. When I cleared it, it seems like it works as it should.
Thought about downgrading, but I don't know if that is possible since Steam automatically looks for a new version at startup
Are you using the 'beta' version of Steam? If so, try switching to the standard version inside Steam's preferences and downloading. See if that makes a difference. If you are using the standard version, then switch to 'beta" and see if it is better.
Also, try rebooting your computer. If it is a certificate issue, there has been past issues with Steam/waking from sleep/hibernation and losing the certificate, a reboot usually works.
B.T.W
23 December 2021 21:09
13
After I cleared the cache it works, but I will try the beta if it shows up again.
Thanks for your help guys!
B.T.W
25 December 2021 14:40
15
Well, the log in error is back. I couldn't even get into Steam yesterday or today. I tried logging in on a laptop with Arch installed and that worked.
I switched to the beta program yesterday on the machine with Garuda and that didn't help and now I can't log into Steam so I can't change it back.
I think I am logging in though because the remote play popup came on the laptop with Arch.
I also tried uninstalling Steam native/runtime and rebooting before reinstalling and that didn't work.
steam.sh[17219]: Running Steam on garuda Soaring 64-bit
steam.sh[17219]: STEAM_RUNTIME is enabled automatically
setup.sh[17292]: Steam runtime environment up-to-date!
steam.sh[17219]: Steam client's requirements are satisfied
[2021-12-25 15:34:12] Startup - updater built Dec 16 2021 22:39:04
[2021-12-25 15:34:12] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1639697812)
[2021-12-25 15:34:12] Loading cached metrics from disk (/home/computer/.local/share/Steam/package/steam_client_metrics.bin)
[2021-12-25 15:34:12] Using the following download hosts for Public, Realm steamglobal
[2021-12-25 15:34:12] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-12-25 15:34:12] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-12-25 15:34:12] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-12-25 15:34:12] Verifying installation...
[2021-12-25 15:34:12] Verification complete
Loaded SDL version 2.0.19-6963453
Gtk-Message: 15:34:13.526: Failed to load module "appmenu-gtk-module"
Gtk-Message: 15:34:13.536: Failed to load module "appmenu-gtk-module"
(steam:17373): Gtk-WARNING **: 15:34:13.537: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Sweet-Dark/gtk-2.0/main.rc:727: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Sweet-Dark/gtk-2.0/apps/chrome.rc:50: error: invalid string constant "button", expected valid string constant
/usr/share/themes/Sweet-Dark/gtk-2.0/apps/xfce.rc:79: error: invalid string constant "entry", expected valid string constant
steamwebhelper.sh[17377]: Runtime for steamwebhelper: defaulting to /home/btw/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
CAppInfoCacheReadFromDiskThread took 0 milliseconds to initialize
Proceed to auto login
Opted-in Controller Mask for AppId 0: 0
(steam:17373): Gtk-WARNING **: 15:34:15.576: gtk_disable_setlocale() must be called before gtk_init()
roaming config store loaded successfully - 7381 bytes.
migrating temporary roaming config store
BuildCompleteAppOverviewChange: 0
^CCWorkThreadPool::~CWorkThreadPool: work processing queue not empty: 1 items discarded.
Exiting workitem thread
(steam:17373): GLib-GObject-CRITICAL **: 15:35:00.906: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:17373): GLib-GObject-WARNING **: 15:35:00.907: invalid (NULL) pointer instance
(steam:17373): GLib-GObject-CRITICAL **: 15:35:00.907: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:17373): GLib-GObject-CRITICAL **: 15:35:00.907: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2021-12-25 15:35:00] Shutdown
B.T.W
26 December 2021 20:09
16
Fixed it again by uninstalling steam and steam-native-runtime, then deleting ./local/share/Steam, rebooting and reinstalling.
tbg
30 December 2021 20:05
17
Another fix was reported by a user with a similar problem:
Just found the solution in the solution in the arch wiki . Needed to enable nscd for dns local cacheing, for some reason. After running sudo systemctl enable --now nscd, Steam now connects without an issue. I’m not sure why this just cropped up now, but I’m glad it’s fixed.
B.T.W
31 December 2021 22:11
18
It didn't fix it for me, sadly.
steam --reset and steam-native --reset has worked for me the last couple of days
system
Closed
2 January 2022 22:12
19
