Hello i switched from Manjaro, everything is better, but i can't run games with custom protons. I don't know why, only original versions Steam proton works. It stuck on loading. ![]()
Kernel: 5.9.4-zen1-1-zen x86_64 bits: 64 compiler: N/A
root=UUID=16a14def-0fae-41fa-bdf1-a20c7f53ffaa rw rootflags=subvol=@
quiet
cryptdevice=UUID=8d1971c2-542c-40d9-a376-9fdbfbe4022f:luks-8d1971c2-542c-40d9-a376-9fdbfbe4022f
root=/dev/mapper/luks-8d1971c2-542c-40d9-a376-9fdbfbe4022f splash
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
Mobo: Dell model: 065C71 v: A00 serial: <filter> UEFI: Dell v: 1.10.0
date: 05/17/2019
Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: D6
L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 44798
Speed: 3411 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3411
2: 3411 3: 3411 4: 3400 5: 3405 6: 3401 7: 3401 8: 3400
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
SMT vulnerable
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 455.38 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8c
Device-3: Realtek Integrated Webcam type: USB driver: uvcvideo
bus ID: 1-12:4 chip ID: 0bda:568a serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2)
v: 4.6 Mesa 20.2.1 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.9.4-zen1-1-zen
vendor: Dell driver: r8169 v: kernel port: d000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: d000
bus ID: 03:00.0 chip ID: 8086:3165
IF-ID-2: virbr0-nic state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 23.41 GiB (2.5%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM049-2GH172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: SDM1
v: 3.0 port: f060 bus ID: 00:17.0 chip ID: 8086.282a rev: 31
ID-1: / raw size: 931.21 GiB size: 931.21 GiB (100.00%)
used: 23.41 GiB (2.5%) fs: btrfs dev: /dev/dm-0
ID-2: /home raw size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-3: /var/log raw size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-4: /var/tmp raw size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 244.5 MiB used: 256 KiB (0.1%)
priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 244.5 MiB used: 256 KiB (0.1%)
priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 244.5 MiB used: 256 KiB (0.1%)
priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 244.5 MiB used: 256 KiB (0.1%)
priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 244.5 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 244.5 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 244.5 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 244.5 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram7
System Temperatures: cpu: 72.0 C mobo: 46.0 C sodimm: 46.0 C
Fan Speeds (RPM): cpu: 4926
Processes: 305 Uptime: 8m Memory: 7.64 GiB used: 2.79 GiB (36.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1551
lib: 474 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.06
