Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d17f23b7-c01a-4836-8c51-f23eef7d0d89 rw rootflags=subvol=@
Type: Laptop System: Dell product: Latitude E5540 v: 01
Mobo: Dell model: 077XV9 v: A00 serial: <superuser required> BIOS: Dell
v: A06 date: 05/01/2014
ID-1: BAT0 charge: 38.1 Wh (100.0%) condition: 38.1/66.6 Wh (57.2%)
volts: 12.9 min: 11.1 model: Sanyo DELL M7T5F48 type: Li-ion
serial: <filter> status: Full
Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2405 high: 2435 min/max: 800/2700 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2395 2: 2435 3: 2395
4: 2396 bogomips: 19154
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.6:3 chip-ID: 0c45:64d0 class-ID: 0e02
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 1-1.8.2:5 chip-ID: 8087:07dc class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 931.51 GiB used: 25.84 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001
scheme: MBR
used: 25.84 GiB (2.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 3.74 GiB used: 41 MiB (1.1%) priority: 100
System Temperatures: cpu: 48.0 C mobo: 37.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3160
Processes: 219 Uptime: 6m wakeups: 1 Memory: 3.74 GiB
used: 2.13 GiB (57.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1700 lib: 510 Shell: fish
Garuda:
System install date: 2022-01-27
Last full system update: 2022-01-27
EFI variables are not supported on this system.
Using TLP: No
Whenever I launch a game from steam my screen goes black and when it comes back it is on the login screen. When I proceed to log in steam is closed and I have to reopen but does the same thing again when I retry launching the game.
