Steam (both regular and native) - audio is fine, but I got no microphone
Hi guys!
Got a weird issue with Steam games.
I’m playing Arc Raiders right now and thought I’d set up my microphone to talk to people. Got the gear connected, but there was no indication of there being any audio input in the game.
I ran Steam → Settings → Voice → “Start Microphone Test” and noticed that the input indicator does not budge.
Did some looking around the Net, however most issues I found were about audio in general not working in Steam, which is not my issue - mine is only the microphone. People suggested installing pavucontrol, which I did. I could now see that when I ran the mic test in Steam, my mic showed up under the “Recording” tab, so it seemed that everything is fine, even if the indicator in Steam didn’t budge.
However, when I used the push-to-talk button in the game, no such thing happened, there was no audio recording marked in pavucontrol at all.
I also checked the Arch Wiki and - based on a warning there - uninstalled Steam (Native) and installed Steam, but that didn’t change anything.
I’ve no idea what else to try… I’d appreciate any help!
Cheers!
EDIT: just noticed the “reboot pending” in the output - yes, although that has nothing to do with the issue, I already rebooted a bunch of times between everything I tried and writing this post.
❯ garuda-inxi
Kernel: 6.17.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=4b180926-8324-4dde-a4cb-0d695f021adf rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.2 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Desktop Mobo: Micro-Star model: B650 GAMING PLUS WIFI (MS-7E26) v: 1.0
Megatrends LLC. v: 1.J0 date: 03/13/2025
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4821 min/max: 426/5053 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4821 2: 4821 3: 4821
4: 4821 5: 4821 6: 4821 7: 4821 8: 4821 9: 4821 10: 4821 11: 4821 12: 4821
13: 4821 14: 4821 15: 4821 16: 4821 bogomips: 134400
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-4
code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-2,HDMI-A-2
empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
empty: DP-3, DP-4, DP-5, HDMI-A-3, Writeback-2 bus-ID: 13:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 31.0 C
gpu: amdgpu d-rect: 3840x1200 display-ID: 0
Monitor-1: DP-2 pos: primary,left model: MSI G241V E2 serial: <filter>
built: 2022 res: mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 93 gamma: 1.2
Monitor-2: HDMI-A-2 pos: right model: Samsung S24H65x serial: <filter>
built: 2020 res: mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 21.1.4 DRM 3.64 6.17.7-zen1-1-zen) device-ID: 1002:7550
memory: 15.62 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.328 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.2.6-arch1.1
device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 7800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 25.2.6-arch1.1 device-ID: 1002:164e surfaces: N/A
device: 2 type: cpu name: llvmpipe (LLVM 21.1.4 256 bits)
driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM 21.1.4)
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
[Rembrandt/Strix] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 13:00.1 chip-ID: 1002:1640
speed: 16 GT/s lanes: 16 bus-ID: 13:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.17.7-zen1-1-zen status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: down mac: <filter>
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0f:00.0 chip-ID: 14c3:0608
IF: wlp15s0 state: up mac: <filter>
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:6 chip-ID: 0e8d:0608
lmp-v: 12 status: discoverable: no pairing: yes class-ID: 6c0104
Local Storage: total: 2.73 TiB used: 1.12 TiB (41.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Crucial model: CT2000P3SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 28.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SKC2500M81000G
lanes: 4 tech: SSD serial: <filter> fw-rev: S7780100 temp: 37.9 C
used: 169.14 GiB (18.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 30.45 GiB used: 103.5 MiB (0.3%)
System Temperatures: cpu: 46.0 C mobo: 44.0 C
GPU: device: amdgpu temp: 35.0 C mem: 54.0 C fan: 0 watts: 15.00
device: amdgpu temp: 32.0 C
Memory: total: 32 GiB note: est. available: 30.45 GiB used: 8.11 GiB (26.6%)
Processes: 516 Power: uptime: 1h 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
Packages: 1431 pm: pacman pkgs: 1403 libs: 344 tools: octopi,pamac,paru
pm: appimage pkgs: 0 pm: flatpak pkgs: 28 Compilers: gcc: 15.2.1 Shell: Bash
v: 5.3.3 default: fish v: 4.1.2 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date:     2025-04-05
Last full system update: 2025-11-08 ↻
24/25 checks run in 0.84 seconds ⌛
Powered by garuda-health 🦅
--- INFO ---
