Static sound when no sound is played
Hello everyone!
When I stop playing any sound (music, video calls, games) after a few seconds (~30 seconds) a static sound starts sounding and it is really loud but just when I stop playing any sound.
I just have simple speakers connected to AUX of my PC, I've already updated it and reboot it but no solution.
Any help is really appreciated!
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9d892093-18dd-4af6-a4fc-9ab572fccea8 rw rootflags=subvol=@
resume=UUID=d6bfb161-f794-43c4-b539-3ac62c71322b loglevel=3 ibt=off
Type: Mini-pc System: LENOVO product: 10T8SSLP00 v: ThinkCentre M720q
serial: <superuser required> Chassis: type: 35 serial: <superuser required>
Mobo: LENOVO model: 312D v: SDK0J40697 WIN 3305369183414
serial: <superuser required> UEFI: LENOVO v: M1UKT62A date: 01/04/2021
Info: model: Intel Core i5-9500T bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
desc: 1x9 MiB
Speed (MHz): avg: 3489 high: 3585 min/max: 800/3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 3581 2: 3401 3: 3541
4: 3585 5: 3560 6: 3271 bogomips: 26399
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: HDMI-A-2,HDMI-A-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0300
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-2 mapped: HDMI-2 pos: primary,left
model: Lenovo LEN S24e-10 serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
Monitor-2: HDMI-A-3 mapped: HDMI-3 pos: right model: Lenovo LEN S24e-10
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 2b89:8761
Local Storage: total: 476.94 GiB used: 95.13 GiB (19.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800 size: 476.94 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 1A scheme: GPT
ID-1: / raw-size: 450.96 GiB size: 450.96 GiB (100.00%)
used: 95.13 GiB (21.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 450.96 GiB size: 450.96 GiB (100.00%)
ID-4: /var/log raw-size: 450.96 GiB size: 450.96 GiB (100.00%)
ID-5: /var/tmp raw-size: 450.96 GiB size: 450.96 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.34 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 25.68 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 67.0 C mobo: N/A
Processes: 245 Uptime: 8m wakeups: 0 Memory: total: 24 GiB
available: 23.34 GiB used: 5.77 GiB (24.7%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 15.0.7 Packages: pm: pacman pkgs: 1589 libs: 394 tools: octopi,paru
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.28
System install date:     2023-07-21
Last full system update: 2023-08-07
Has it always been like this since the installation?
Only later?
With headphones too?
M$ 10/11 shut down properly?
Thanks for the reply!
It has not being always like this, it happened after an update some days ago.
With headphones happens also, the sound it is not that loud on them but a loud click can be heard after a few seconds of stoping any sound.
Shut down multiple times properly.
Check what change some days ago.
Check sound settings.
Try other kernel.
Search the web.
Check log files at the time you stop the sound file, …
This could be HW related.. check your cables, and connections.
AUX outputs that came via cable to the top of the PC case are prone to picking up noise. Again, it depends on a lot of underlying factors. The source of distortion can be both common mode and EMI. In the PC case it could EMI because there are devices that can radiate EMF
Audio issues can come from noisy ground or ungrounded power outlets as well.
Some things to keep in mind.
Try disabling node suspension as described here: PipeWire - ArchWiki
With wireplumber, create a new file to overwrite the default configuration:
~/.config/wireplumber/main.lua.d/51-disable-suspension.lua
(or /etc/wireplumber/main.lua.d/51-disable-suspension.lua)
table.insert (alsa_monitor.rules, {
  matches = {
      -- Matches all sources.
      { "node.name", "matches", "alsa_input.*" },
      -- Matches all sinks.
      { "node.name", "matches", "alsa_output.*" },
  apply_properties = {
    ["session.suspend-timeout-seconds"] = 0,  -- 0 disables suspend
Trying a different kernel did it 6.4.5-1-cachyos-bore
Thanks!
