Because of the recent issues I had with Gnome not starting, I want to make sure the snapshots are working correctly. When I tried starting a snapshot I got saw a few errors from Tor I think and that was it. Gnome didn't start.
I was able to CTRL+ALT+F2 to go into another text only login prompt to log in.
Are the snapshots supposed to boot into the Gnome GUI?
Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=746085a3-1efd-44d0-9e3f-bea3af666d4d rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 nvidia-drm.modeset=1
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F3
date: 08/08/2018
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2370 high: 3623 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3124 2: 3623
3: 2077 4: 2077 5: 2144 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 86395
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-2,HDMI-A-1
empty: DP-1,DP-3,Unknown-1 bus-ID: 09:00.0 chip-ID: 10de:1f02
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-10:7 chip-ID: 046d:082d
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
display-ID: 0
Monitor-1: DP-2 model: Acer X34 serial: <filter> built: 2013
res: 3440x1440 dpi: 109 gamma: 1.2 size: 798x335mm (31.42x13.19")
diag: 865mm (34.1") modes: max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-1 model: Sony TV 01 serial: <filter> built: 2013
res: 1920x1080 dpi: 47 gamma: 1.2 size: 1040x585mm (40.94x23.03")
diag: 1193mm (47") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 1-10:7 v: kernel chip-ID: 046d:082d pcie:
gen: 3 class-ID: 0102 serial: <filter> speed: 8 GT/s lanes: 16
bus-ID: 09:00.1 chip-ID: 10de:10f9 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: Logitech HD Pro Webcam C920 type: USB
Sound API: ALSA v: k6.0.7-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
Local Storage: total: 2.75 TiB used: 477.74 GiB (17.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7
temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 2T00
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 238.87 GiB
(12.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 580 KiB
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 238.87 GiB
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 238.87
GiB (12.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 238.87
ID-1: swap-1 type: zram size: 62.75 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 376 Uptime: 11m wakeups: 1 Memory: 62.75 GiB used: 7.79 GiB
(12.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 alt: 11 Packages: 2552 pm: nix-default pkgs: 138
pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 490 libs: 132 pm: pacman pkgs: 1924
libs: 472 tools: pamac,paru pm: flatpak pkgs: 0 Shell: fish v: 3.5.1
running-in: tmux: inxi: 3.3.22
e[1;34mGaruda (2.6.9-1):e[0m
e[1;34m System install date:e[0m 2021-12-26
e[1;34m Last full system update:e[0m 2022-11-05
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m bluetooth-autoconnect.service
