Hello, when i ran a command with sudo earlier today i noticed that the starship prompt used a mage emoji to show that the command was ran using sudo, and it didnt use that character before. I have looked in the starship.toml config file and the only parameter under the sudo section is
disabled=false
The garuda icon in the left is also not showing anymore, which might be related.
Kernel: 5.17.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=3d7f37ea-6ec9-4e7c-abfb-36c47e2e627b rw rootflags=subvol=@
intel_iommu=on i915.enable_guc=0 i915.enable_gvt=1
Type: Laptop System: Dell product: Latitude E7470 v: N/A
Mobo: Dell model: 0T6HHJ v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: 1.31.3 date: 10/13/2021
ID-1: BAT0 charge: 30.0 Wh (62.5%) condition: 48.0/55.0 Wh (87.4%)
volts: 8.2 min: 7.6 model: SMP DELL MC34Y51 type: Li-poly serial: <filter>
status: charging
ID-2: hidpp_battery_0 charge: 15% condition: N/A volts: 3.7 min: N/A
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 951 high: 1167 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 1040
4: 1167 bogomips: 19999
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell Latitude E7470
driver: i915 v: kernel ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Microsoft Microsoft LifeCam Cinema type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.1:4 chip-ID: 045e:0812
class-ID: 0102
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-2:3 chip-ID: 0bda:5686 class-ID: 0e02 serial: <filter>
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right model: Dell U2417H
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x0653 built: 2015
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.0.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell Latitude E7470
class-ID: 0102
Device-3: Logitech G935 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:7 chip-ID: 046d:0a87
Sound Server-1: ALSA v: k5.17.3-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
Device-1: Intel Ethernet I219-LM vendor: Dell Latitude E7470 driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-8:9 chip-ID: 8087:0a2b class-ID: e001
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 465.76 GiB used: 103.84 GiB (22.3%)
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 103.84 GiB (22.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 103.84Before you open a new help request, read relevant sections of the Arch and Garuda wiki.
Thoroughly search your issue and any error messages in the forum and on the web. GiB (22.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C pch: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3329
Processes: 224 Uptime: 14m wakeups: 3 Memory: 15.3 GiB
used: 3.6 GiB (23.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1603 lib: 467 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-01-30
Last full system update: 2022-04-19 ↻
