This is a pretty strange issue and I am not sure what to even search in the internet to resolve this… I will post pics to try and explain my problem.
How my terminal normally looks,
from inside tmux,
I am not sure why my fastfetch and starship prompt become blocky like this…
I have similar starship + fastfetch + fish/bash setup in wsl which works fine so my guess is something to do with foot itself then?
Edit:
No not foot’s problem even alacritty does the same…
does anybody have any idea what this weird effect is even called so that I can search the net for any results…
Thanks
Kernel: 6.11.6-0-clear arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@hypr/boot/vmlinuz-linux-clear
root=UUID=e0a08d20-208f-444a-a6f0-281ffd8a1e1b rw rootflags=subvol=@hypr
quiet console=tty0 console=ttyS0,115200n8 cryptomgr.notests
initcall_debug intel_iommu=igfx_off kvm-intel.nested=1 no_timer_check
noreplace-smp page_alloc.shuffle=1 rcupdate.rcu_expedited=1
rootfstype=btrfs tsc=reliable
resume=UUID=1824b554-dd46-4e14-a85d-6aafd14791a7 loglevel=3
acpi_backlight=video nvidia-drm.modeset=1 ibt=off
Desktop: Hyprland v: 0.44.0-117-g81ad218b with: waybar tools:
avail: swayidle,swaylock vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Convertible System: LENOVO product: 81X1 v: IdeaPad Flex 5 14IIL05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14IIL05
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
serial: <superuser required> part-nu: LENOVO_MT_81X1_BU_idea_FM_IdeaPad
Flex 5 14IIL05 uuid: <superuser required> UEFI: LENOVO v: ECCN41WW
date: 06/27/2022
ID-1: BAT0 charge: 12.6 Wh (35.6%) condition: 35.4/52.6 Wh (67.2%)
power: 18.4 W volts: 11.9 min: 11.5 model: Sunwoda L19D3PD6 type: Li-poly
serial: <filter> status: charging cycles: 2333
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC6
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB
desc: 4x512 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1189 min/max: 400/1300 scaling: driver: intel_pstate
governor: performance cores: 1: 1189 2: 1189 3: 1189 4: 1189 5: 1189 6: 1189
7: 1189 8: 1189 bogomips: 23961
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a52
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Lenovo driver: N/A
alternate: nvidiafb, nouveau, nvidia_drm, nvidia non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 01:00.0 chip-ID: 10de:1d16 class-ID: 0302
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 5986:212a
class-ID: 0e02
compositor: Hyprland v: 0.44.0-117-g81ad218b driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1406 built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 scale: 1.199219 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
API: Vulkan v: 1.3.295 layers: 12 device: 0 type: integrated-gpu
name: Intel Iris Plus Graphics (ICL GT2) driver: mesa intel
v: 24.2.6-arch1.1 device-ID: 8086:8a52 surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256 bits)
driver: mesa llvmpipe v: 24.2.6-arch1.1 (LLVM 18.1.8)
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-icl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_icl bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
API: ALSA v: k6.11.6-0-clear status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 36 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 476.94 GiB used: 92.91 GiB (19.5%)
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 3L1QFXV7 temp: 25.9 C scheme: GPT
ID-1: / raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
used: 92.91 GiB (20.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-4: /var/log raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.28 GiB used: 5.24 GiB (34.3%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc max-streams: 8
ID-2: swap-2 type: partition size: 16.82 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 51.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.28 GiB used: 7.5 GiB (49.1%)
Processes: 312 Power: uptime: 7d 23h 49m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 25 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.1 GiB services: thermald,upowerd
Packages: pm: pacman pkgs: 1480 libs: 449 tools: paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: foot inxi: 3.3.36
System install date: 2024-10-06
Last full system update: 2024-11-13 ↻
Failed units: archlinux-keyring-wkd-sync.service
