Kernel: 6.13.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f68be4c4-e170-4012-afea-e2a0787eaace rw rootflags=subvol=@
Desktop: KDE Plasma v: ERR-101 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: Gigabyte model: Z68AP-D3 serial: N/A
uuid: 00000000-0000-0000-0000-50e5494f36cd BIOS: Award v: F8
date: 03/21/2012
Info: model: Intel Core i5-2500 socket: 478 (1155) note: check bits: 64
type: MCP arch: Sandy Bridge gen: core 2 level: v2 built: 2010-12
process: Intel 32nm family: 6 model-id: 0x2A (42) stepping: 7
microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3292 min/max: 1600/3300 base/boost: 3300/4000 scaling:
driver: intel_cpufreq governor: performance volts: 1.0 V ext-clock: 100 MHz
cores: 1: 3292 2: 3292 3: 3292 4: 3292 bogomips: 26338
vendor: Gigabyte driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: VGA-1 empty: DP-1,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0380
Device-2: Advanced Micro Devices [AMD/ATI] Cape Verde PRO [Radeon HD
7750/8740 / R7 250E] vendor: Gigabyte driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-2,VGA-2
empty: DVI-D-1,DVI-D-2 bus-ID: 06:00.0 chip-ID: 1002:683f class-ID: 0300
temp: 47.0 C
Device-3: Arkmicro Webcam Carrefour driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.5:4
chip-ID: 18ec:3299 class-ID: 0102
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: radeonsi,crocus gpu: i915,radeon
display-ID: :1 screens: 1
Screen-1: 0 s-res: 4864x1080 s-dpi: 96 s-size: 1287x286mm (50.67x11.26")
s-diag: 1318mm (51.91")
Monitor-1: HDMI-A-2 pos: top-center model: Samsung built: 2010 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 305 gamma: 1.4
size: 160x90mm (6.3x3.54") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1360x768 min: 720x400
Monitor-2: VGA-1 pos: bottom-r res: mode: 1024x768 hz: 60 scale: 100% (1)
size: N/A modes: max: 1024x768 min: 640x480
Monitor-3: VGA-2 pos: primary,top-left model: Dell E2211H serial: <filter>
built: 2010 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2
API: EGL v: 1.5 hw: drv: intel crocus drv: amd radeonsi platforms:
device: 0 drv: radeonsi device: 1 drv: crocus device: 2 drv: swrast gbm:
drv: radeonsi surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: VERDE (radeonsi LLVM 19.1.7 DRM
2.50 6.13.4-zen1-1-zen) device-ID: 1002:683f memory: 1.95 GiB unified: no
API: Vulkan v: 1.4.303 layers: 8 device: 0 type: cpu name: llvmpipe (LLVM
19.1.7 256 bits) driver: N/A device-ID: 10005:0000 surfaces: xcb,xlib
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: Advanced Micro Devices [AMD/ATI] Oland/Hainan/Cape
Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.1
chip-ID: 1002:aab0 class-ID: 0403
API: ALSA v: k6.13.4-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.7 status: n/a (root, process) with:
lanes: 1 port: ce00 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: TP-Link 802.11ac NIC driver: rtw_8822bu type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.6:3 chip-ID: 2357:012e
IF: wlp0s29u1u6 state: down mac: <filter>
v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.3:3
Local Storage: total: 3.18 TiB used: 961.44 GiB (29.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EADS-00W4B0
family: Caviar Green size: 1.82 TiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 1.5 Gb/s tech: N/A serial: <filter>
fw-rev: 0A01 temp: 35 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 237d 15h cycles: 6742
model: WD10EFRX-68FYTN0 family: Red size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 0A82 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 364d 9h cycles: 407
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500418AS
family: Barracuda 7200.12 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: HP35 temp: 40 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 297d 13h cycles: 46606
Pre-Fail: reallocated sector: 99 threshold: 36 attribute: Spin_Retry_Count
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 18.55 GiB (4.0%) fs: btrfs block-size: 4096 B dev: /dev/sdc1
maj-min: 8:33
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
maj-min: 8:33
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
maj-min: 8:33
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
maj-min: 8:33
ID-1: swap-1 type: zram size: 15.54 GiB used: 240.2 MiB (1.5%)
max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 49.0 C mobo: N/A gpu: radeon temp: 47.0 C
Memory: total: 16 GiB available: 15.54 GiB used: 5.14 GiB (33.1%)
Processes: 274 Power: uptime: 6h 18m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1918 libs: 575 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
Garuda (2.6.26-1.1):
System install date: 2025-02-27
Last full system update: 2025-02-28
First let me apologize for my fopar about posting from different accounts in different catorgories.
I tried a sugestion about turning off shader in steam and all I got was a black box. Have tried running other games and they seem to work ok.
The intergrated gpu is not working
Again sorry for the mis-understanding
