Hey everyone!
I’m hoping someone out there can help me troubleshoot a super annoying issue I’m having with my gaming setup. I’ve got a GL502VSK laptop with a GTX 1070 8GB and an i7-7700HQ, running Garuda Linux. The problem hits when I’m trying to game through Bottles—my system just crashes. I’ve tried both X11 and Wayland sessions, and Wayland makes things even worse.
After a forced reboot when the system crashed, I checked the journal and found this mess:
May 18 11:33:57 cezer-gl502vsk kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.SAT0.PRT0], AE_ALREADY_EXISTS (20240827/dswload2-326)
May 18 11:33:57 cezer-gl502vsk kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240827/psobject-220)
May 18 11:33:57 cezer-gl502vsk kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.SAT0.PRT1], AE_ALREADY_EXISTS (20240827/dswload2-326)
May 18 11:33:57 cezer-gl502vsk kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.SAT0.PRT3], AE_ALREADY_EXISTS (20240827/dswload2-326)
May 18 11:33:57 cezer-gl502vsk kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.SAT0.PRT4], AE_ALREADY_EXISTS (20240827/dswload2-326)
May 18 11:33:57 cezer-gl502vsk kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.SAT0.PRT5], AE_ALREADY_EXISTS (20240827/dswload2-326)
May 18 11:33:57 cezer-gl502vsk kernel: ACPI: bus type drm_connector registered
May 18 11:33:57 cezer-gl502vsk kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
May 18 11:33:57 cezer-gl502vsk kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
May 18 11:33:57 cezer-gl502vsk kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
May 18 11:33:57 cezer-gl502vsk kernel: RAS: Correctable Errors collector initialized.
May 18 11:33:57 cezer-gl502vsk kernel: ata1.00: supports DRM functions and may not be fully accessible
May 18 11:33:57 cezer-gl502vsk systemd-vconsole-setup[187]: /usr/bin/setfont failed with a "system error" (EX_OSERR), ignoring.
May 18 11:33:57 cezer-gl502vsk systemd-vconsole-setup[187]: Setting source virtual console failed, ignoring remaining ones.
May 18 11:33:57 cezer-gl502vsk systemd-vconsole-setup[194]: setfont: ERROR kdfontop.c:212 put_font_kdfontop: Unable to load such font with such kernel version
May 18 11:33:57 cezer-gl502vsk kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
May 18 11:33:57 cezer-gl502vsk systemd-vconsole-setup[480]: /usr/bin/setfont failed with a "system error" (EX_OSERR), ignoring.
May 18 11:33:57 cezer-gl502vsk systemd-vconsole-setup[485]: setfont: ERROR kdfontop.c:212 put_font_kdfontop: Unable to load such font with such kernel version
May 18 11:33:57 cezer-gl502vsk systemd-vconsole-setup[480]: Setting source virtual console failed, ignoring remaining ones.
May 18 11:33:58 cezer-gl502vsk kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
May 18 11:33:59 cezer-gl502vsk kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
May 18 11:33:59 cezer-gl502vsk kernel: fbcon: nvidia-drmdrmfb (fb0) is primary device
May 18 11:33:59 cezer-gl502vsk kernel: nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
May 18 11:34:00 cezer-gl502vsk systemd[1]: Starting Load Kernel Module drm...
May 18 11:34:00 cezer-gl502vsk systemd[1]: modprobe@drm.service: Deactivated successfully.
May 18 11:34:00 cezer-gl502vsk systemd[1]: Finished Load Kernel Module drm.
May 18 11:34:01 cezer-gl502vsk kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
May 18 11:34:01 cezer-gl502vsk kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
May 18 11:34:01 cezer-gl502vsk kernel: asus_wmi: fan_curve_get_factory_default (0x00110032) failed: -19
May 18 11:34:01 cezer-gl502vsk (udev-worker)[653]: asus-nb-wmi: Process 'systemctl restart asusd.service' failed with exit code 1.
May 18 11:34:01 cezer-gl502vsk (udev-worker)[672]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
May 18 11:34:01 cezer-gl502vsk systemd-vconsole-setup[753]: setfont: ERROR kdfontop.c:212 put_font_kdfontop: Unable to load such font with such kernel version
May 18 11:34:01 cezer-gl502vsk systemd-vconsole-setup[748]: /usr/bin/setfont failed with a "system error" (EX_OSERR), ignoring.
May 18 11:34:01 cezer-gl502vsk systemd-vconsole-setup[748]: Setting source virtual console failed, ignoring remaining ones.
May 18 11:34:01 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: AER: Multiple Correctable error message received from 0000:00:1c.2
May 18 11:34:01 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
May 18 11:34:01 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: device [8086:a112] error status/mask=00000081/00002000
May 18 11:34:01 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: AER: Error of this Agent is reported first
May 18 11:34:01 cezer-gl502vsk kernel: ath10k_pci 0000:03:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Transmitter ID)
May 18 11:34:01 cezer-gl502vsk kernel: ath10k_pci 0000:03:00.0: device [168c:0042] error status/mask=00001181/00006000
May 18 11:34:01 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: AER: found no error details for 0000:00:1c.2
May 18 11:34:01 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: AER: Multiple Correctable error message received from 0000:03:00.0
May 18 11:34:01 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: device [8086:a112] error status/mask=00002001/00002000
May 18 11:34:01 cezer-gl502vsk asusd[825]: [ERROR asusd] FanCurves: Profile error: Not supported
May 18 11:34:01 cezer-gl502vsk asusd[825]: [ERROR asusd] Backlight: Missing functionality: No backlights found
May 18 11:34:01 cezer-gl502vsk asusd[825]: [ERROR rog_platform::error] PlatformError: got: Attribute not found: charge_control_end_threshold
May 18 11:34:01 cezer-gl502vsk asusd[825]: [ERROR rog_platform::error] PlatformError: got: Attribute not found: platform_profile
May 18 11:34:01 cezer-gl502vsk asusd[825]: [INFO asusd::ctrl_platform] inotify watch failed: Attribute not found: charge_control_end_threshold. You can ignore this if your device does not support the feature
May 18 11:34:01 cezer-gl502vsk systemd[1]: Starting Load Kernel Module drm...
May 18 11:34:01 cezer-gl502vsk systemd[1]: modprobe@drm.service: Deactivated successfully.
May 18 11:34:01 cezer-gl502vsk systemd[1]: Finished Load Kernel Module drm.
May 18 11:34:01 cezer-gl502vsk polkitd[832]: Error opening rules directory: Error opening directory “/run/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
May 18 11:34:02 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: AER: Multiple Correctable error message received from 0000:00:1c.2
May 18 11:34:02 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
May 18 11:34:02 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: device [8086:a112] error status/mask=00002001/00002000
May 18 11:34:02 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: device [8086:a112] error status/mask=00000001/00002000
May 18 11:34:02 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: device [8086:a112] error status/mask=00000081/00002000
May 18 11:34:05 cezer-gl502vsk dbus-broker-launch[823]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
May 18 11:34:05 cezer-gl502vsk systemd-xdg-autostart-generator[2691]: /etc/xdg/autostart/libinput-gestures.desktop: stat() failed, ignoring: No such file or directory
May 18 11:34:06 cezer-gl502vsk sddm-greeter-qt6[2696]: file:///usr/share/sddm/themes/Dr460nized/Login.qml:21: ReferenceError: units is not defined
May 18 11:34:07 cezer-gl502vsk sddm-greeter-qt6[2696]: file:///usr/share/sddm/themes/Dr460nized/Main.qml:320: ReferenceError: units is not defined
May 18 11:34:07 cezer-gl502vsk sddm-greeter-qt6[2696]: file:///usr/share/sddm/themes/Dr460nized/Login.qml:21: ReferenceError: units is not defined
May 18 11:35:04 cezer-gl502vsk sddm[946]: Error from greeter session: "Process crashed"
May 18 11:35:04 cezer-gl502vsk sddm[946]: Greeter stopped. SDDM::Auth::HELPER_AUTH_ERROR
May 18 11:35:09 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: AER: Multiple Correctable error message received from 0000:00:1c.2
May 18 11:35:09 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
May 18 11:35:09 cezer-gl502vsk kernel: pcieport 0000:00:1c.2: device [8086:a112] error status/mask=00000001/00002000
May 18 11:35:09 cezer-gl502vsk dbus-broker-launch[823]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
It looks like there are some NVIDIA module issues and a bunch of PCIe Bus Errors. Does anyone have any clue what might be going on here or how I can fix this? Any advice would be a lifesaver!
#LinuxGaming #GarudaLinux nvidia #SystemCrash #HelpNeeded
