Hello,
this issue is not strictly Garuda related, when it happened the first time I was running Manjaro (but with btrfs and most Garuda tweaks enabled, such as zram, etc...) So, a few months ago, my ssd performance (SSD Crucial 1To SATA III - CT1000BX500SSD1 - BX500) suddenly dropped (wrting speed was divided by 40) and resulted in an almost unusable system. I re-formatted the ssd and reinstalled the system (Garuda replacing Manjaro), but no luck. I then had the idea to flash my motherboard (MSI B550M-A Pro), and it worked, I recovered a fast and responsive PC, ssd writing speed back to normal. But since then, this problem has happened 3 or 4 times, the last time this morning. So I re-flashed my mobo (with the same firmware...), and I'm back to normal. But one has to admit this is not a long term solution (I have to re-tweak my bios every time), and I am just writing this message to ask if anyone would have an idea about this weird situtation.
Thanks in advance for any suggestion.
tbg
November 24, 2022, 1:06pm
2
Be sure the firmware in your SSD is up to date, and also run some smartmon tests on the drive.
Test some different kernels as well.
You also need to include your garuda-inxi
output on your help request if you wish to receive further assistance.
Edit:
You might also want to save/backup your bios configuration. That way, you could try resetting your bios to the factory default, rather than flashing your bios repeatedly. Flashing your bios is inherently risky, so it's best to minimize the amount of times you have to do this. Perhaps simply resetting the bios will be enough to correct your speed issue, (without resorting to flashing the bios). Either way, saving your bios configuration and then restoring it saves a lot of time and effort reconfiguring your bios.
Are you dual booting Windows?
Is it possible this issue occurs in Linux after booting into Windows?
Thanks. garuda-inxi output below:
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=ae317a36-c8b0-4a76-9c00-4d179067a6a8 rw rootflags=subvol=@
nvidia-drm.modeset=1 quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3
Desktop: Cinnamon v: 5.6.1 tk: GTK v: 3.24.35 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B550M-A PRO (MS-7C96) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.90
date: 08/11/2022
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3145 high: 3200 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3200 2: 3200
3: 2613 4: 3200 5: 3132 6: 3200 7: 3200 8: 3200 9: 3200 10: 3200 11: 3200
12: 3200 bogomips: 76803
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4
ports: active: none off: HDMI-A-1 empty: DVI-D-1 bus-ID: 2b:00.0
chip-ID: 10de:1d01 class-ID: 0300
Device-2: SJ-180517-N 1080P Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-3.1:5 chip-ID: 0806:0806
class-ID: 0102
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 542x301mm (21.34x11.85")
s-diag: 620mm (24.41")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled
model: Idek Iiyama PL2530H serial: <filter> built: 2018 res: 1920x1080
dpi: 90 gamma: 1.2 size: 544x303mm (21.42x11.93") diag: 623mm (24.5")
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce GT
1030/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GP108 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 3-3.1:5 v: kernel chip-ID: 0806:0806 pcie:
class-ID: 0102 gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 2b:00.1
chip-ID: 10de:0fb8 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: SJ-180517-N 1080P Webcam type: USB
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
driver: btusb v: 0.8 bus-ID: 3-3.4:7 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.73 TiB used: 1.23 TiB (45.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 054 scheme: GPT
model: WD20EZBX-00AYRA0 size: 1.82 TiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 96 GiB size: 96 GiB (100.00%) used: 29.19 GiB (30.4%)
used: 588 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 835.01 GiB size: 835.01 GiB (100.00%)
used: 282.48 GiB (33.8%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 96 GiB size: 96 GiB (100.00%)
used: 29.19 GiB (30.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 96 GiB size: 96 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 32.2 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Processes: 382 Uptime: 4h 48m wakeups: 0 Memory: 15.54 GiB
used: 4.57 GiB (29.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 2038
pm: pacman pkgs: 2004 libs: 527 tools: pamac,paru,yay pm: appimage pkgs: 0
pm: flatpak pkgs: 22 pm: snap pkgs: 12 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-08-13
Last full system update: 2022-11-24 ↻
tbg
November 24, 2022, 3:29pm
4
See my above edit, and please answer the questions there. Please report on the results of all suggestions put to you.
Thanks for the suggestion to save the bios config, I'll have a look at this.
I am not dual booting windows. As for updating the SSD firmware, it seems that the only solution is to run their utility from a windows install. I was able to run the program through wine, but it doesn't detect any drive.
Concerning your suggestion to run a different kernel, well, this issue happens like every 6 weeks, and I am satisfied with the zen kernel. I would have to run another kernel continuously for two ot three months to have an answer. Not easy.
Finally:
sudo smartctl -l selftest /dev/sda
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.0.9-zen1-1-zen] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 3056 -
# 2 Short offline Completed without error 00% 2841 -
# 3 Short offline Completed without error 00% 2839 -
# 4 Short offline Completed without error 00% 59 -
=== START OF INFORMATION SECTION ===
Model Family: Crucial/Micron Client SSDs
Device Model: CT1000BX500SSD1
Serial Number: 2138E5D4D5DF
LU WWN Device Id: 5 00a075 1e5d4d5df
Firmware Version: M6CR054
User Capacity: 1 000 204 886 016 bytes [1,00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available
Device is: In smartctl database 7.3/5319
ATA Version is: ACS-3 T13/2161-D revision 4
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Nov 24 18:33:15 2022 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 120) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 0
5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 3609
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 952
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
173 Ave_Block-Erase_Count 0x0032 094 094 000 Old_age Always - 67
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 25
180 Unused_Reserve_NAND_Blk 0x0033 100 100 000 Pre-fail Always - 12
183 SATA_Interfac_Downshift 0x0032 100 100 000 Old_age Always - 0
184 Error_Correction_Count 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 074 050 000 Old_age Always - 26 (Min/Max 19/50)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_ECC_Cnt 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 1
202 Percent_Lifetime_Remain 0x0030 094 094 001 Old_age Offline - 6
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
210 Success_RAIN_Recov_Cnt 0x0032 100 100 000 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 30869642774
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 964676336
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 1618459712
249 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 0
250 Read_Error_Retry_Rate 0x0032 100 100 000 Old_age Always - 0
251 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 564880609
252 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 23
253 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 0
254 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 58
223 Unkn_CrucialMicron_Attr 0x0032 100 100 000 Old_age Always - 1
SMART Error Log not supported
Selective Self-tests/Logging not supported
system
Closed
December 8, 2022, 5:34pm
8
