Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=64756c86-744a-4fa5-952b-1e2ddf6e70ec rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: LENOVO product: 21DA000WUS v: ThinkPad T15p Gen 3
Mobo: LENOVO model: 21DA000WUS v: SDK0T76538 WIN
serial: <superuser required> part-nu: LENOVO_MT_21DA_BU_Think_FM_ThinkPad
T15p Gen 3 uuid: <superuser required> UEFI: LENOVO v: N3EET35W (1.21 )
date: 11/08/2023
ID-1: BAT0 charge: 60.5 Wh (100.0%) condition: 60.5/68.0 Wh (88.9%)
volts: 12.8 min: 11.6 model: LGC 5B10W13960 type: Li-poly serial: <filter>
status: full cycles: 116
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
microcode: 0x430
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 456 high: 731 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 509 6: 400 7: 653 8: 400 9: 400 10: 400 11: 515 12: 724 13: 400 14: 400
15: 400 16: 731 17: 400 18: 400 19: 400 20: 400 bogomips: 107520
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a2
class-ID: 0302
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 5986:9106
class-ID: 0e02
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 422x237mm (16.61x9.33")
s-diag: 484mm (19.05")
Monitor-1: eDP-1 model: BOE Display 0x08e2 built: 2019 res: 1600x900
hz: 60 dpi: 118 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 30.33 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 24.0.2-arch1.2
device-ID: 8086:46a6 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia v: 550.54.14
device-ID: 10de:25a2 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
Local Storage: total: 953.87 GiB used: 247.49 GiB (25.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: 1108ANLA temp: 38.9 C
used: 247.47 GiB (26.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 21.8 MiB (7.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 2169
Memory: total: 32 GiB note: est. available: 31.05 GiB used: 9.92 GiB (31.9%)
Processes: 441 Power: uptime: 57m states: freeze,mem,disk suspend: s2idle
image: 12.38 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 2108 pm: pacman pkgs: 2088 libs: 598 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 20 Compilers: gcc: 13.2.1 alt: 12
Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-11-18
Last full system update: 2024-03-13
So here’s a new one – I had ran garuda-update on Friday morning and got a gaggle of updates; enough of them that I had to disable Wayland on login again, as Synergy (a software KVM) isn’t Wayland compatible yet.
Now, since said update, I sporadically lock up tighter than Fort Knox. The mouse freezes, or the cursor will move but the screen is locked where I can’t click on anything, or the screen blanks like going to sleep and won’t wake up.
I end up having to hard boot the system. This never happened before the last updates. I think the major – MAJOR update was Plasma to the latest revision. That’s about the only real difference I can see.
Thoughts?
