running that command as per suggestions::
garuda-update remote fix
[sudo] password for pc:
This will reset a few configuration files like pacman.conf š
Are you sure? (y/n)
y
--2024-01-12 20:40:04-- https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving pkgbuild.com (pkgbuild.com)... 78.46.178.133, 2a01:4f8:c2c:51e2::1
Connecting to pkgbuild.com (pkgbuild.com)|78.46.178.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 4606712 (4.4M) [application/octet-stream]
Saving to: ā/tmp/tmp.7goQkIs7Zeā
/tmp/tmp.7goQkIs7Ze 100%[=========================>] 4.39M 677KB/s in 7.3s
2024-01-12 20:40:13 (615 KB/s) - ā/tmp/tmp.7goQkIs7Zeā saved [4606712/4606712]
.--. Pacman v6.0.1 - libalpm v13.0.1
/ _.-' .-. .-. .-. Copyright (C) 2006-2021 Pacman Development Team
\ '-. '-' '-' '-' Copyright (C) 2002-2006 Judd Vinet
This program may be freely redistributed under
the terms of the GNU General Public License.
--2024-01-12 20:40:13-- https://gitlab.com/garuda-linux/tools/garuda-tools/-/raw/master/data/pacman-default.conf
Resolving gitlab.com (gitlab.com)... 172.65.251.78, 2606:4700:90:0:f22e:fbec:5bed:a9b9
Connecting to gitlab.com (gitlab.com)|172.65.251.78|:443... connected.
Length: 2514 (2.5K) [text/plain]
Saving to: ā/etc/pacman.confā
/etc/pacman.conf 100%[=========================>] 2.46K --.-KB/s in 0s
2024-01-12 20:40:13 (23.0 MB/s) - ā/etc/pacman.confā saved [2514/2514]
--2024-01-12 20:40:13-- https://archlinux.org/mirrorlist/all/
Resolving archlinux.org (archlinux.org)... 95.217.163.246, 2a01:4f9:c010:6b1f::1
Connecting to archlinux.org (archlinux.org)|95.217.163.246|:443... connected.
Length: 53685 (52K) [text/plain]
Saving to: ā/etc/pacman.d/mirrorlistā
/etc/pacman.d/mirrorl 100%[=========================>] 52.43K 149KB/s in 0.4s
2024-01-12 20:40:15 (149 KB/s) - ā/etc/pacman.d/mirrorlistā saved [53685/53685]
--2024-01-12 20:40:15-- https://aur.chaotic.cx/mirrorlist.txt
Resolving aur.chaotic.cx (aur.chaotic.cx)... 185.199.110.153, 185.199.111.153, 185.199.108.153, ...
Connecting to aur.chaotic.cx (aur.chaotic.cx)|185.199.110.153|:443... connected.
Length: 2237 (2.2K) [text/plain]
Saving to: ā/etc/pacman.d/chaotic-mirrorlistā
/etc/pacman.d/chaotic 100%[=========================>] 2.18K --.-KB/s in 0.006s
2024-01-12 20:40:15 (359 KB/s) - ā/etc/pacman.d/chaotic-mirrorlistā saved [2237/2237]
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/AB861BFFCC4DDB0C76BDC3B0F010937A1621D077.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 1u
==> Appending keys from archlinux.gpg...
==> Appending keys from chaotic.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signed 11 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
gpg: inserting ownertrust of 4
==> Disabling revoked keys in keyring...
-> Disabled 47 keys.
gpg: Note: third-party key signatures using the SHA1 algorithm are rejected
gpg: (use option "--allow-weak-key-signatures" to override)
gpg: depth: 0 valid: 1 signed: 9 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 9 signed: 99 trust: 0-, 0q, 0n, 9m, 0f, 0u
gpg: depth: 2 valid: 74 signed: 22 trust: 74-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2024-01-21
gpg: key A6234074498E9CEE: 4 duplicate signatures removed
gpg: key A6234074498E9CEE: 1 signature reordered
gpg: key A6234074498E9CEE: "Christian Hesse <eworm@archlinux.org>" 9 signatures cleaned
gpg: key FBA220DFC880C036: "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" not changed
gpg: Total number processed: 2
gpg: unchanged: 1
gpg: signatures cleaned: 9
-> Locally signed 2 keys.
gpg: depth: 0 valid: 1 signed: 10 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 10 signed: 98 trust: 1-, 0q, 0n, 9m, 0f, 0u
gpg: depth: 2 valid: 73 signed: 22 trust: 73-, 0q, 0n, 0m, 0f, 0u
garuda 95.7 KiB 29.0 KiB/s 00:03 [----------------------------] 100%
core 128.9 KiB 55.4 KiB/s 00:02 [----------------------------] 100%
extra 8.3 MiB 32.0 KiB/s 04:25 [----------------------------] 100%
community 45.0 B 25.0 B/s 00:02 [----------------------------] 100%
multilib 139.5 KiB 15.8 KiB/s 00:09 [----------------------------] 100%
chaotic-aur 2.6 MiB 510 KiB/s 00:05 [----------------------------] 100%
warning: archlinux-keyring-20231222-1 is up to date -- reinstalling
warning: chaotic-keyring-20230616-1 is up to date -- reinstalling
resolving dependencies...
Package (2) Old Version New Version Net Change Download Size
core/archlinux-keyring 20231222-1 20231222-1 0.00 MiB 1.16 MiB
chaotic-aur/chaotic-keyring 20230616-1 20230616-1 0.00 MiB 0.03 MiB
Total Download Size: 1.19 MiB
Total Installed Size: 1.68 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
chaotic-keyring-20... 28.6 KiB 2.65 KiB/s 00:11 [----------------------------] 100%
archlinux-keyring-... 1186.2 KiB 10.9 KiB/s 01:49 [----------------------------] 100%
Total (2/2) 1214.8 KiB 10.7 KiB/s 01:54 [----------------------------] 100%
(2/2) checking keys in keyring [----------------------------] 100%
(2/2) checking package integrity [----------------------------] 100%
(2/2) loading package files [----------------------------] 100%
(2/2) checking for file conflicts [----------------------------] 100%
(2/2) checking available disk space [----------------------------] 100%
snapper snapshots skipped
(1/2) reinstalling archlinux-keyring [----------------------------] 100%
(2/2) reinstalling chaotic-keyring [----------------------------] 100%
(1/8) Reloading system manager configuration...
(2/8) Arming ConditionNeedsUpdate...
(3/8) Foreign/AUR package notification
alacritty-themes 5.3.1-2
blackarch-keyring 20180925-5
blackarch-menus 10.5244eea-3
blackarch-mirrorlist 20231231-1
onevpl 2023.4.0-1
(4/8) Orphaned package notification...
=> No orphans found.
(5/8) Checking for .pacnew and .pacsave files...
(6/8) Reinstate Black Arch keyring
==> Appending keys from blackarch.gpg...
-> Locally signed 4 keys.
-> Disabled 1 keys.
gpg: depth: 0 valid: 1 signed: 14 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 14 signed: 98 trust: 1-, 0q, 0n, 13m, 0f, 0u
(7/8) Performing snapper post snapshots for the following configurations...
(8/8) Syncing all file systems...
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur.db failed to download
error: failed retrieving file 'chaotic-aur.db' from cdn-mirror.chaotic.cx : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'chaotic-aur.db' from br-mirror.chaotic.cx : Failed to connect to br-mirror.chaotic.cx port 443 after 9381 ms: Operation timed out
error: failed retrieving file 'chaotic-aur.db' from bg-mirror.chaotic.cx : Could not resolve host: bg-mirror.chaotic.cx
warning: too many errors from bg-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from ca-mirror.chaotic.cx : Could not resolve host: ca-mirror.chaotic.cx
warning: too many errors from ca-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from cl-mirror.chaotic.cx : Could not resolve host: cl-mirror.chaotic.cx
warning: too many errors from cl-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from de-2-mirror.chaotic.cx : Could not resolve host: de-2-mirror.chaotic.cx
warning: too many errors from de-2-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from de-3-mirror.chaotic.cx : Could not resolve host: de-3-mirror.chaotic.cx
warning: too many errors from de-3-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from de-4-mirror.chaotic.cx : Could not resolve host: de-4-mirror.chaotic.cx
warning: too many errors from de-4-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from gr-mirror.chaotic.cx : Could not resolve host: gr-mirror.chaotic.cx
warning: too many errors from gr-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from in-mirror.chaotic.cx : Could not resolve host: in-mirror.chaotic.cx
warning: too many errors from in-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from in-2-mirror.chaotic.cx : Could not resolve host: in-2-mirror.chaotic.cx
warning: too many errors from in-2-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from in-3-mirror.chaotic.cx : Could not resolve host: in-3-mirror.chaotic.cx
warning: too many errors from in-3-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from in-4-mirror.chaotic.cx : Could not resolve host: in-4-mirror.chaotic.cx
warning: too many errors from in-4-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from kr-mirror.chaotic.cx : Could not resolve host: kr-mirror.chaotic.cx
warning: too many errors from kr-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from es-mirror.chaotic.cx : Could not resolve host: es-mirror.chaotic.cx
warning: too many errors from es-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from es-2-mirror.chaotic.cx : Could not resolve host: es-2-mirror.chaotic.cx
warning: too many errors from es-2-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from us-mi-mirror.chaotic.cx : Could not resolve host: us-mi-mirror.chaotic.cx
warning: too many errors from us-mi-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from us-tx-mirror.chaotic.cx : Could not resolve host: us-tx-mirror.chaotic.cx
warning: too many errors from us-tx-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from us-ut-mirror.chaotic.cx : Could not resolve host: us-ut-mirror.chaotic.cx
warning: too many errors from us-ut-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed to synchronize all databases (invalid url for server)
āātactical@tactical in ~ via ī v21.5.0 took 8m3s
[š“] Ć garuda-update remote fix
[sudo] password for tactical:
Are you sure? (y/n)
y
--2024-01-12 20:48:53-- https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Saving to: ā/tmp/tmp.L20RSw4W8kā
/tmp/tmp.L20RSw4W8k 100%[=========================>] 4.39M 28.6KB/s in 4m 4s
2024-01-12 20:52:59 (18.5 KB/s) - ā/tmp/tmp.L20RSw4W8kā saved [4606712/4606712]
--2024-01-12 20:52:59-- https://gitlab.com/garuda-linux/tools/garuda-tools/-/raw/master/data/pacman-default.conf
2024-01-12 20:53:00 (21.2 MB/s) - ā/etc/pacman.confā saved [2514/2514]
--2024-01-12 20:53:00-- https://archlinux.org/mirrorlist/all/
/etc/pacman.d/mirrorl 100%[=========================>] 52.43K 227KB/s in 0.2s
2024-01-12 20:53:03 (227 KB/s) - ā/etc/pacman.d/mirrorlistā saved [53685/53685]
--2024-01-12 20:53:03-- https://aur.chaotic.cx/mirrorlist.txt
Resolving aur.chaotic.cx (aur.chaotic.cx)... 185.199.111.153, 185.199.109.153, 185.199.108.153, ...
Connecting to aur.chaotic.cx (aur.chaotic.cx)|185.199.111.153|:443... connected.
/etc/pacman.d/chaotic 100%[=========================>] 2.18K --.-KB/s in 0s
2024-01-12 20:53:05 (15.3 MB/s) - ā/etc/pacman.d/chaotic-mirrorlistā saved [2237/2237]
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/61DC0A92A040136B58498ABF79138E9DE9F8E3A0.rev'
gpg: Done
gpg: unchanged: 1
garuda 95.7 KiB 14.9 KiB/s 00:06 [----------------------------] 100%
core 128.9 KiB 6.29 KiB/s 00:20 [----------------------------] 100%
extra 8.3 MiB 32.3 KiB/s 04:22 [----------------------------] 100%
community 45.0 B 13.0 B/s 00:03 [----------------------------] 100%
multilib 139.5 KiB 5.35 KiB/s 00:26 [----------------------------] 100%
chaotic-aur 2.6 MiB 21.7 KiB/s 02:03 [----------------------------] 100%
chaotic-keyring-20... 28.6 KiB 10.8 KiB/s 00:03 [----------------------------] 100%
archlinux-keyring-... 1186.2 KiB 28.6 KiB/s 00:42 [----------------------------] 100%
Total (2/2) 1214.8 KiB 28.2 KiB/s 00:43 [----------------------------] 100%
onevpl 2023.4.0-1
-> Disabled 1 keys.
core is up to date
extra is up to date
chaotic-aur 2.6 MiB 506 KiB/s 00:05 [----------------------------] 100%
error: failed retrieving file 'core.db' from mirrors.kernel.org : Failed to connect to mirrors.kernel.org port 80 after 6119 ms: Operation timed out
warning: garuda-update-4.4.0-1 is up to date -- reinstalling
Package (1) Old Version New Version Net Change Download Size
garuda/garuda-update 4.4.0-1 4.4.0-1 0.00 MiB 0.01 MiB
Total Download Size: 0.01 MiB
Total Installed Size: 0.02 MiB
garuda-update-4.4.... 10.5 KiB 13.3 KiB/s 00:01 [----------------------------] 100%
(1/1) checking keys in keyring [----------------------------] 100%
(1/1) checking package integrity [----------------------------] 100%
(1/1) loading package files [----------------------------] 100%
(1/1) checking for file conflicts [----------------------------] 100%
(1/1) checking available disk space [----------------------------] 100%
(1/1) reinstalling garuda-update [----------------------------] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Foreign/AUR package notification
onevpl 2023.4.0-1
(3/6) Orphaned package notification...
(4/6) Checking for .pacnew and .pacsave files...
(5/6) Performing snapper post snapshots for the following configurations...
(6/6) Syncing all file systems...
core is up to date
extra is up to date
chaotic-aur is up to date
--> Refreshing mirrorlists using rate-mirrors, please be patient..šµ
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
error: failed retrieving file 'garuda.db' from cdn-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'core.db' from mirror.quantum5.ca : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'extra.db' from mirror.quantum5.ca : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'multilib.db' from mirror.quantum5.ca : Resolving timed out after 10001 milliseconds
warning: too many errors from mirror.quantum5.ca, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from cdn-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'garuda.db' from geo-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'core.db' from europe.mirror.pkgbuild.com : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'extra.db' from europe.mirror.pkgbuild.com : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'multilib.db' from europe.mirror.pkgbuild.com : Resolving timed out after 10001 milliseconds
warning: too many errors from europe.mirror.pkgbuild.com, skipping for the remainder of this transaction
error: failed retrieving file 'garuda.db' from br-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'core.db' from archlinux.mirror.server24.net : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'extra.db' from archlinux.mirror.server24.net : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'multilib.db' from archlinux.mirror.server24.net : Resolving timed out after 10001 milliseconds
warning: too many errors from archlinux.mirror.server24.net, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from br-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'garuda.db' from bg-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'core.db' from archlinux.mirror.garr.it : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'extra.db' from archlinux.mirror.garr.it : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'multilib.db' from archlinux.mirror.garr.it : Resolving timed out after 10001 milliseconds
warning: too many errors from archlinux.mirror.garr.it, skipping for the remainder of this transaction
error: failed retrieving file 'chaotic-aur.db' from bg-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'garuda.db' from ca-mirror.chaotic.cx : OpenSSL SSL_connect: Connection reset by peer in connection to ca-mirror.chaotic.cx:443
error: failed retrieving file 'chaotic-aur.db' from ca-mirror.chaotic.cx : OpenSSL SSL_connect: Connection reset by peer in connection to ca-mirror.chaotic.cx:443
error: failed retrieving file 'chaotic-aur.db' from cl-mirror.chaotic.cx : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'chaotic-aur.db' from de-2-mirror.chaotic.cx : Resolving timed out after 10002 milliseconds
error: failed retrieving file 'chaotic-aur.db' from de-3-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'chaotic-aur.db' from de-4-mirror.chaotic.cx : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'chaotic-aur.db' from gr-mirror.chaotic.cx : SSL connection timeout
error: failed to synchronize all databases (unexpected error)
Failed to update mirrorlist
lottsa errors connecting to mirrors
