I am a newbie and i recently (3 to4 day) installed garuda ,while installation i connected to my university wifi which was working perfectly fine.
After finish and updating, the university wifi got disconnected, but when i connect to my hotspot it is connecting fine , it is also working under usb tethering .
the wifi is not connecting specifically to the university wifi after the update
can somebody please tell me why is this problem occuring.
**Kernel**: 6.4.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=91af0b39-ea8c-4c70-88e6-bf47795d06a8 rw rootflags=subvol=@
**Desktop**: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
**Machine**:
Type: Laptop System: Dell product: Vostro 3400 v: N/A
Mobo: Dell model: 0GGCMJ v: A01 serial: <superuser required> UEFI: Dell
v: 1.19.0 date: 09/06/2022
**Battery**:
ID-1: BAT0 charge: 23.1 Wh (70.0%) condition: 33.0/42.0 Wh (78.6%)
volts: 11.5 min: 11.4 model: BYD DELL 1VX1H14 type: Li-poly serial: <filter>
**CPU**:
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xAA
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1452 high: 2400 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 1200 3: 1206
4: 1116 5: 1086 6: 2400 7: 1200 8: 1015 bogomips: 38707
**Graphics**:
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0c45:671e
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x453d built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
**Audio**:
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.4.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
**Network**:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
IF: wlp0s20f3 state: down mac: <filter>
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:01:00.0
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
**Bluetooth**:
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3
Device-2: Samsung Galaxy series misc. (tethering mode) driver: rndis_host
v: kernel type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-2:11 chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
**RAID**:
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
**Drives**:
Local Storage: total: 1.14 TiB used: 21.95 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KDI model: OM3PDP3-AD NVMe 256GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 10100002 temp: 47.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 02 scheme: GPT
**Partition**:
used: 21.95 GiB (9.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 732 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
**Swap**:
ID-1: swap-1 type: zram size: 7.49 GiB used: 0 KiB (0.0%) priority: 100
**Sensors**:
System Temperatures: cpu: 58.0 C mobo: 49.0 C
Fan Speeds (RPM): cpu: 3013
**Info**:
Processes: 285 Uptime: 1h 3m wakeups: 3848 Memory: total: 8 GiB note: est.
available: 7.49 GiB used: 4.29 GiB (57.2%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1861 libs: 551 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
