Hello Garuda users.
For some reason I am unable to use "$super+Fn" shortcuts, which is supposed to open up browser.
All paths are correct in correlation to their variable. I think I am missing something obvious.
# i3 config file (v4)
# Please see http://i3wm.org/docs/userguide.html for a complete reference!
# set modifier
set $super Mod4
set $alt Mod1
### Commonly Used Variables: ###
# - Below defined are some of the very common variables that users like to customise
# - For Keybindings search: Commonly Used Keybindings in this document
# - Make sure that you give the absolute path to the binary / program / executable
# - You may specify any additional arguments required by the binary / executable
### Wallpaper: ###
# - You need to specify homescreen wallpaper using azote
set $lockScreenWallpaper /usr/share/wallpapers/garuda-wallpapers/Garuda-Desert.png
### Applications: ###
set $preferredTerminalEmulator /usr/bin/alacritty
set $preferredBrowser /usr/bin/firedragon
set $preferredFileManager /usr/bin/thunar
set $preferredMailClient /usr/bin/geary
set $preferredTextEditor /usr/bin/geany
set $preferredScreenCaptureTool /usr/bin/flameshot gui
### Commonly Used Application Keybinds: ###
bindsym $super+F1 exec $preferredBrowser;focus
bindsym $super+F2 exec $preferredMailClient;focus
bindsym $super+F3 exec $preferredFileManager;focus
bindsym $super+F4 exec $preferredTextEditor;focus
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8ac286fc-3a77-4f91-9eaf-1601b61de4c7 rw [email protected]
resume=UUID=7a18e269-a659-45c3-b623-36b457e501a4 loglevel=3 ibt=off
Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: G7 7590 v: N/A
Mobo: Dell model: 0MXHK3 v: A01 serial: <superuser required> UEFI: Dell
v: 1.17.1 date: 10/05/2021
ID-1: BAT0 charge: 42.7 Wh (85.7%) condition: 49.8/60.0 Wh (83.0%)
volts: 15.5 min: 15.2 model: SMP DELL JJPFK87 type: Li-poly serial: <filter>
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2150 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 800 3: 2600
4: 2600 5: 2600 6: 2600 7: 800 8: 2600 9: 800 10: 2600 11: 2600 12: 2600
bogomips: 62399
Type: itlb_multihit status: KVM: Split huge pages
vulnerable
PBRSB-eIBRS: Not affected
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 bus-ID: 0000:01:00.0 chip-ID: 10de:2191
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0bda:565a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-98a5c
driver: X: loaded: modesetting,nvidia unloaded: nouveau
Monitor-1: eDP-1 model: AU Optronics 0x24ed built: 2019 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
missing.
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
Device-2: NVIDIA TU116 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:1aeb
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Device-1: Realtek vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 0000:3b:00.0 chip-ID: 10ec:2502 class-ID: 0200
IF: enp59s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless-AC 9260 vendor: Rivet Networks driver: iwlwifi
v: kernel bus-ID: 0000:3c:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp60s0 state: up mac: <filter>
IF-ID-1: virbr0 state: up speed: 10 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet2 state: unknown speed: 10 Mbps duplex: full mac: <filter>
v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0025 class-ID: e001
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.47 GiB used: 19.4 GiB (8.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 11001101 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
used: 19.4 GiB (8.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
ID-4: /var/log raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.44 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 39.0 C pch: 45.0 C mobo: N/A
Processes: 316 Uptime: 1h 21m wakeups: 13388 Memory: 15.44 GiB
used: 2.63 GiB (17.0%) Init: systemd v: 252 default: graphical
pkgs: 1436 libs: 352 tools: pamac,paru Shell: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-29
Last full system update: 2022-11-29
