I have been facing this issue since I installed garuda. If I play video on any application like browser or media player, it will run, but I am not able to hear the audio.
The only way to hear the audio is to click "play all audio using this device" in the audio devices section on the option "line out"
Once I pause the video for like 5 seconds, then I'll have to do it again to hear the audio
Essentially, I am tired of navigating and clicking that button every minute to hear some audio.
Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=64a567bd-23f6-43f2-bc2f-c579c56d78de rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: A320M-H v: N/A
Mobo: Gigabyte model: A320M-H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F50 date: 11/28/2019
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 built: 2019 process: GF 12nm
family: 0x17 (23) model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1610 high: 2293 min/max: 1400/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1253 2: 1494
3: 2293 4: 1400 bogomips: 28746
Type: retbleed mitigation: untrained return thunk; SMT disabled
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ZOTAC driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2023/24)
arch: Fermi 2 code: GF119/GK208 process: TSMC 28nm built: 2010-16 pcie:
gen: 2 speed: 5 GT/s lanes: 8 ports: active: HDMI-A-1
empty: DVI-D-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa gpu: nouveau display-ID: :0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Dell D1918H serial: <filter>
built: 2020 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 720x400
OpenGL: renderer: NV106 v: 4.3 Mesa 22.1.6 direct render: Yes
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel bus-ID: 1-5:3 pcie: chip-ID: 31b2:0011 class-ID: 0300 gen: 2
serial: <filter> speed: 5 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:0e0f class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: DCMT USB Condenser Microphone type: USB
Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
lanes: 1 port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 46.53 GiB (5.0%)
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 243.89 GiB size: 243.89 GiB (100.00%) used: 46.5 GiB
(19.1%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%) used: 27.6 MiB
(29.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 243.89 GiB size: 243.89 GiB (100.00%) used: 46.5
GiB (19.1%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 243.89 GiB size: 243.89 GiB (100.00%) used: 46.5
ID-5: /var/tmp raw-size: 243.89 GiB size: 243.89 GiB (100.00%) used: 46.5
ID-1: swap-1 type: zram size: 7.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.5 C mobo: N/A gpu: nouveau temp: 38.0 C
Processes: 233 Uptime: 3m wakeups: 0 Memory: 7.7 GiB used: 2.26 GiB (29.3%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1415 lib: 352 Shell: fish
v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-07-12
Last full system update: 2022-08-21
