So I recently downloaded Garuda Linux on my Laptop (Lenovo Flexpad 5i and it was originally on chrome OS), and the sounds doesn't work on my laptop's speakers. I've been playing around with the sound/audio options in the settings, but no luck. Tried both the output options. I'll leave images on the sound settings too since I have no idea on what to try next.
Kernel: 5.19.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=de434a85-4453-4493-9058-01aaecdf53cc rw rootflags=subvol=@
Type: Laptop System: Google product: Akemi v: rev4 serial: <filter>
Chassis: type: 9 serial: N/A
Mobo: Google model: Akemi v: rev4 serial: <filter> UEFI: coreboot
v: MrChromebox-4.14 date: 07/25/2021
ID-1: BAT0 charge: 37.6 Wh (78.5%) condition: 47.9/51.1 Wh (93.6%)
volts: 8.4 min: 7.7 model: SMP L19M4PG type: Li-ion serial: <filter>
status: charging cycles: 33
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 built: 2018
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xC (12)
microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1450 high: 2100 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave ext-clock: 100 MHz cores: 1: 800
2: 2100 3: 2100 4: 2100 5: 800 6: 800 7: 2100 8: 800 bogomips: 33599
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 5986:212e class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: InfoVision Optronics/Kunshan 0x8544
built: 2019 res: 1920x1080 hz: 60 dpi: 168 gamma: 1.2
size: 290x170mm (11.42x6.69") diag: 337mm (13.3") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.19.4-zen1-1-zen running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 119.24 GiB used: 15.91 GiB (13.3%)
model: MZALQ128HBHQ-000L2 size: 119.24 GiB block-size: physical: 512 B
rev: AL2QFXV7 temp: 31.9 C scheme: GPT
SMART: yes health: PASSED on: 32 hrs cycles: 144 read-units: 6,402,411
[3.27 TB] written-units: 7,611,348 [3.89 TB]
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 15.91 GiB
(13.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
(0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 15.91
GiB (13.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 15.91
maj-min: 259:2
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 15.91
maj-min: 259:2
ID-1: swap-1 type: zram size: 7.64 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 42.0 C mobo: N/A
Processes: 283 Uptime: 11m wakeups: 336 Memory: 7.64 GiB used: 2.72 GiB
(35.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: 1658 pacman: 1653 lib: 384 flatpak: 5
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-22
Last full system update: 2022-08-27
