Hi again!
My space information text in Dolphin, is obscured as show in photo. This happened a while back after a big issue with brtfs missing space for snapshots that I chose to solve manually, to learn.
I’m still green on Linux in general, so I have no clue how to fix this. This is theme specific, as changing it to any other Breeze default fixes the issue, but I really like the Dragonized theme.
Is there any way I can fully reinstall the default dragonized theme? At this point I don’t care about losing other configurations, I’d just rather have this info back in this easy to reach place.
Thank you in advance!
Kernel: 6.10.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b652edd7-a598-45e7-bbe6-99791107dfbd rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop Mobo: Gigabyte model: B550M AORUS ELITE
Megatrends LLC. v: F16a date: 11/03/2022
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2932 high: 3730 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3227
3: 3400 4: 3361 5: 2875 6: 2870 7: 2872 8: 2195 9: 2467 10: 3458 11: 3730
12: 2873 13: 2902 14: 2872 15: 2877 16: 2742 bogomips: 108594
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 05:00.0 chip-ID: 10de:1f06
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 3520x1080 s-dpi: 90 s-size: 993x301mm (39.09x11.85")
s-diag: 1038mm (40.85")
Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled pos: left
model: LG (GoldStar) E2060 built: 2012 res: 1600x900 hz: 60 dpi: 92
gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 515mm (20.3") ratio: 16:9
modes: max: 1600x900 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,right
model: Acer V226HQL serial: <filter> built: 2022 res: 1920x1080 hz: 60
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060
SUPER/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2060 SUPER driver: nvidia v: 555.58.02 device-ID: 10de:1f06
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256
bits) driver: mesa llvmpipe v: 24.1.5-arch1.2 (LLVM 18.1.8)
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 10de:10f9
bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.10.4-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br-209a26951ddc state: down mac: <filter>
v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:9
Local Storage: total: 1.78 TiB used: 1.48 TiB (83.2%)
model: WDS480G2G0C-00AJM0 size: 447.13 GiB block-size: physical: 512 B
fw-rev: 231800WD temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: K1B3 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000VM002-1CT162
tech: HDD rpm: 5900 serial: <filter> fw-rev: SC23 scheme: MBR
ID-1: / raw-size: 125.59 GiB size: 125.59 GiB (100.00%)
used: 90.62 GiB (72.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27.8 MiB (29.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 125.59 GiB size: 125.59 GiB (100.00%)
ID-4: /var/log raw-size: 125.59 GiB size: 125.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 125.59 GiB size: 125.59 GiB (100.00%)
System Temperatures: cpu: 51.4 C mobo: 33.0 C gpu: nvidia temp: 40 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 29%
Memory: total: 32 GiB available: 31.25 GiB used: 8.48 GiB (27.1%)
Processes: 414 Power: uptime: 10h 39m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: 1830 pm: pacman pkgs: 1802 libs: 470 tools: octopi,pamac,paru
pm: flatpak pkgs: 28 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2023-11-19
Last full system update: 2024-08-14
